That recipe worked perfectly for me when I tried it.DirkS wrote: https://frillip.com/using-your-raspberr ... h-hostapd/
It works.
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Re: [Tutorial] Using the RasPi as a WiFi hostspot (8 Nov 12)
Thanks, I'll try it later. I guess I didn't find it because I was searching for "hotspot" instead of "access point".
the nl80211 driver hasn't been compiled into hostapd.
At this point you should be able to use the nl80211 driver
As well, you'll probably want to add
ieee80211n=1 to your hostapd.conf file
Also possibly
wme_enabled=1
There is also ht_capab=.. You'll want to like at iw list and see what capabilities you can add that your card supports
mine says
ht_capab=[HT40-] [HT40+] [SHORT-GI-40] [RX-STBC1]
Good luck.
wget http://w1.fi/releases/hostapd-2.0.tar.gz
tar -zxvf hostapd-2.0.tar.gz
cd hostapd-2.0
cd hostapd
(note, the following command copies defconfig to a dotfile .config)
cp defconfig .config
nano .config
uncomment the line: CONFIG_DRIVER_NL80211=Y
Also uncomment the line: CONFIG_IEEE80211N=y
make
If there are errors, you most likely need to install some packages
sudo apt-get install libnl-dev
sudo apt-get install libssl-dev
Then try again
make
sudo make install
Also possibly
wme_enabled=1
mine says
Good luck.
Not sure what I actually have to do, to fix this:
Configuration file: /etc/hostapd/hostapd.conf
Line 2: invalid/unknown driver 'nl80211'
1 errors found in configuration file '/etc/hostapd/hostapd.conf'
I have the WI-PI wi-fi dongle, which appear as:
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
and use the nl80211 driver if i'm not mistaken ??
-thx
can someone please help me with this.
I think I'm in the right forum
ive been trying to convert the rpi to a wifi router. the rpi is shows a network but no internet.
- Attachments
- dif.png (25.55 KiB) Viewed 7718 times
when I input sudo /usr/sbin/hostapd /etc/hostapd/hostapd.conf I get this
Configuration file: etc/hostapd/hostapd.conf
Failed to create interface mon.wlan0: -95 (Operation not supported)
wlan0: Could not connect to kernel driver
Using interface wlan0 with hwaddr b8:27:eb:a7:e1:cc and ssid "Pi3-AP"
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
wlan0: AP-ENABLED
Please how can i creat a 3G acces point with my raspberry pi b+
I have create an access point with ethernet but now i should replace ethernet connexion by 3g connexion
Help please
Help please
I am trying to set up my Raspberry Pi 3 as a Wireless hotspot following the instructions here but without any success:
I get exactly the same error message as Kritharth. I've extensively Googled it and found several places where people report the same problem, but nobody ever replies with an answer or any clarification.
Can anybody help?
Can anybody help?
"when I input sudo /usr/sbin/hostapd /etc/hostapd/hostapd.conf I get this
wlan0: AP-ENABLED"
Same, no internet access when i try to connect it, still no answer to this problem please ?
wlan0: AP-ENABLED"
i too have the same error:
Using interface wlan0 with hwaddr b8:27:eb:70:72:35 and ssid "My_AP"
wlan0: AP-ENABLED
with other devices i can not 'see' the wifi connection 'My_AP'.
what can i do?
wlan0: AP-ENABLED
what can i do?
i read through this post:
and found that i needed to add this:
now i see my app ssid
and i also could be due to that i forgot to turn off my wlan in the interface:
driver=nl80211
nano /etc/dhcpcd.conf
denyinterfaces wlan0
nano /etc/network/interfaces
allow-hotplug wlan0
iface wlan0 inet static
address 172.24.1.1
netmask 255.255.255.0
network 172.24.1.0
broadcast 172.24.1.255
I finally got my hotspot working on my Pi Zero with a RT5370 dongle, but my Nexus 5X (Android 6.0) refuses to connect to the hotspot because it has no internet access (this is intentional, I don't need internet access, nor do I have access where I'm going to use it). Does anyone know how I can solve this?
i have dnsmasq so i can deliver the dns and have nginx to serve a simple web page. with these setup any device will think there is internet.
Does this work with the Pi 2? Does it have to be Raspbian?
not sure if you can install the apps (dnsmasq etc..) than it should be no problem
- Contact: Website
The date of the comments are from a long time ago. I just started trying to use the raspberry pi as a replacement for many objects around my home, in cluding surveillance. I want to replace my router with a RP router. Using the intstructions I've been able to make a working hot spot. I using a R3pi and it works well.
I want to use a r3pi b plus and a tp-WN722N adapter. I will try to make the switch to the rp2 tomorrow.
- DougieLawson
That's much too old and should have expired years ago.
works with an RPi3
- Contact: Website
I have an old NOOBS card with wheezy and I'm trying to make it work with a pi 2. I'm using a TP-LINK TL-WN722N.GamingStar wrote:Does this work with the Pi 2? Does it have to be Raspbian?
I'm assuming non-systemd.
With the pi 3 the wrong wlan0 ip address comes up - 169.254.237.97
I'm doing something wrong or out of sequence.
- Contact: Website
I probably am breaking in to this discussion, but is it possible to set up an access point on a Pi3 without routing it over ethernet to internet? I run a minecraft server on a Pi at home for my kid and his school mates. That connects to my router and the internet. It would be great if I could set the WiFi to AP and put it standalone at school, so they can connect to it wireless.
Best regards, Peter
Best regards, Peter
Got this working on Raspberry Pi 3 using the steps here: https://frillip.com/using-your-raspberr ... h-hostapd/
This one uses dnsmasq and raspbian's own dhcpd. The other tutorial at http://elinux.org/RPI-Wireless-Hotspot uses udhcpd instead.
Hi All,
Got the pi working as standalone minecraft server with access point
My son will have a ball at school with this project
Peter
Peter
I have followed the directions at http://elinux.org/RPI-Wireless-Hotspot#Instructions. I can get the access point to appear but when I try to connect with my phone and/or tablet it never progresses past "Obtaining IP address." I'm still a noob at some of this so I have no idea how to fix this. Any help?
Hi,drew1028 wrote:I have followed the directions at http://elinux.org/RPI-Wireless-Hotspot#Instructions. I can get the access point to appear but when I try to connect with my phone and/or tablet it never progresses past "Obtaining IP address." I'm still a noob at some of this so I have no idea how to fix this. Any help?
That link assumes you will get your ip from somwhere further up the chain. If there is no dhcp overthere, you will never get an ip. I followed https://frillip.com/using-your-raspberr ... h-hostapd/ where hostapd will create the actual wireless access point and dnsmasq to provide a dhcp server, giving you ip numbers.
My link got me a working system.
Have fun,
Peter
following this guide and failing... rpi is either not broadcasting or i do not know the problem. i did everything step by step, nothing works. figured might be onboard wifi module so i bought ralink 5572, as it shows up as wlan1 i configured everything accordingly... still no joy. anyone can help out? although when i use start service hostapd udhcpd there are no errors popping up, which makes it so much harder to determine what is going on...
