Mekai
Re: [Tutorial] Using the RasPi as a WiFi hostspot (8 Nov 12)
Tue Apr 02, 2013 11:41 am
hunternet93 wrote: After looking at the pic again, you have "wlan" instead of "wlan0", and parts of the file don't seem to be indented correctly. You may want to take another look at the tutorial and copy the file exactly as shown.
After learning how to read this is what i ended up with !
Thank you so much Hunternet93 !
http://rovfuld.blogspot.dk/2013/04/raspblaster.html
pipuppy
Mon Apr 08, 2013 1:35 pm
Hi again,
Success and a question.
The quest to build a small stand-alone wi-fi web-server has been successful and I now have a my wi-fi server up and running thanks to all the advice from this and other forums.
I should like to add a captive portal feature such that whatever page a users browser is initially set to the user will be re-directed to the start page of my wi-fi server. Currently, the user has to type in 192.168.1.38 in order to reach the index page, this is ok but it would be much better if the users browser was automatically directed to the index.
Does anyone know how this might be implemented ?
Regards to all,
pipuppy
pipuppy wrote:Hi poing,
poing wrote:Tony here made a menu with which you can install everything needed: http://www.raspberrypi.org/phpBB3/viewt ... 66&t=31408
You'll need Apache or lighttpd as webserver, if you want to make a real site also php (server side programming), MySQL (database) and phpmyadmin (database administration) but these have a bit of a steep learning curve.
Also use the menu to make /var/www writable for the pi user, otherwise you can't change the webpages.
That should have you well on the way in minutes.
Thanks for the pointers though I think it will take more than a few minutes, a few days might be nearer the mark ;-) Linux is still very new to me though I have read about a LAMP stack so the terms you have used make sense.
To be honest though my initial goal is to simply get the server part working with simple web-pages, pure html with a few hyperlinks to additional pages and perhaps a few images etc, this is something I can do :-) Nothing fancy to start with. I doubt I will need MySQL or PHP until much later on.
Thanks for responding I will have a closer look at Tony's installation menu, looks like a handy utility in its own right.
Best wishes,
pipuppy
PabloCR
Mon Apr 08, 2013 3:26 pm
In case anyone is still having trouble setting up the hostapd using the Edimax EW-7811Un EW-7811Un
I can confirm this works :)
http://blog.sip2serve.com/post/38010690 ... -rtl8192cu
hagiz
Wed Apr 17, 2013 8:35 pm
First and foremost thank you for putting all the effort in publicicing this guide after you gone through it. Great idea!
When doing the iw list command, I got hit by the well bespoken:
nl80211 not found.
I did purceede with the tutorial anyway(why not try).
I have followed the steps many times, over and over again. Also reinstalled hostapd.
I configured a open network that I can't see at all. I don't think the wifi is even starting up(since it's not blinking blue). And I know the wifi adapter is correctly recognized, since I checked that from the beginning.
Am I screwed with this wifi adapter or what are my options? Other drivers? Different OS?
Now I did it once more, but I see another result:
Starting advanced IEEE 802.11 management: hostapdSegmentation fault
 failed!
I basically want to be able to connect to the RaspBMC with a smartphone. I know that my phone can supply a wifi, but it's draining my phones battery. Any thoughts are super duper welcome
-I have a thread started for my project
So you easier can help me out:
  • Pie: Rev B.
    OS: RaspBMC (for now)
    Power: 12000mAh Battery OR Phone Charger
    SDHC: 32GB Samsung (Class 10) [MB-SSBGA/EU]
    Wifi USB: Belkin N300 Micro [F7D2102az]
    16GB USB: SanDisk Cruzer Fit (USB 2.0) [SDCZ33-016G-B35]
RichCranney
Sun Apr 21, 2013 1:04 pm
Hi there,
Thanks for such a great informative tutorial on how to create this wifi hotspot.
Is it possible to only create the hotspot after a wifi connection hasn't been made? For example, RPi starts up, finds a save wifi SSID in range and connects, no hotspot created. But, no saved SSIDs in range, it then processes and creates the hotspot.
That would be great, meaning I could use my RPi at home connected to my WIFI network, but when in my car, it would create the Hotspot network.
hunternet93
Mon Apr 22, 2013 11:26 pm
RichCranney wrote:Hi there,
I'm sure it's possible, but it would require either writing a script or using NetworkManager to scan for SSIDs in range and create an ad-hoc connection if no access points are available.
beeedy
Thu Apr 25, 2013 4:02 pm
I followed the tutorial on the wiki and got a a network that I am able to connect to from multipul devices. I have been able to send files and such over the network, so I can verify that everything is working. HOWEVER after going through the tutorial my pi will no longer connect to the internet, and thus none of the devices connected to the pi can acces the internet through it. Any help would be extremely appreciated!
hunternet93
Thu Apr 25, 2013 6:13 pm
beeedy wrote:I followed the tutorial on the wiki and got a a network that I am able to connect to from multipul devices. I have been able to send files and such over the network, so I can verify that everything is working. HOWEVER after going through the tutorial my pi will no longer connect to the internet, and thus none of the devices connected to the pi can acces the internet through it. Any help would be extremely appreciated!
How are you connecting to the internet? if your Pi is connecting wirelessly then you'll need a second wireless dongle. If you're connecting through wired, start the hotspot and post the output of the following command:
sudo ifconfig
This will give information about your Pi's network interfaces, and hopefully shed light on the issue.
beeedy
Thu Apr 25, 2013 6:54 pm
Here is the output of ifconfig
eth0          Link encap:Ethernet  HWaddr f0:dc:e2:28:2c:fc
                  inet addr:10.38.1.148  Bcast:10.38.127.255  Mask:255.255.128.0
                  UP BROADCAST RUNNING MULTICAST MTU:1500  Metric:1
                  RX packets:182 errors:0 dropped:0 overruns:0 frame:0
                  TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
                  collisions:0 txqueuelen:1000
                  RX bytes:10690 (10. 4KiB) TX bytes:700 (700.0 B)
lo               Link encap: Local Loopback
                  inet addr:127.0.0.1  Mask 255.0.0.0
                  UP LOOPBACK RUNNING  MTU:16436
                  RX packets:0 errors:0 dropped:0 overruns:0 frame:0
                  TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
                  RX bytes:0 (0 B) TX bytes:0 (0 B)
mon.wlan0 Link encap:UNSPEC HWaddr C8-3A-35-C7-81-75-00-00-00-00-00-00-00-00-00-00
                  RX packets:1227 errors:0 dropped:0 overruns:0 frame:0
                  RX bytes:229640 (224.2 KiB) TX bytes:0 (0.0 B)
wlan0       Link encap:Ethernet  HWaddr c8:3a:35:c7:81:75
                  inet addr:192.168.42.1  Bcast: 192.168.42.255  Mask:255.255.255.0
                  RX packets:102 errors:0 dropped:13 overruns:0 frame:0
                  TX packets:74 errors:0 dropped:0 overruns:0 carrier:0
                  RX bytes:11556 (11.2 KiB) TX bytes:11401 (11.1 KiB)
hunternet93
Thu Apr 25, 2013 7:00 pm
beeedy wrote:Here is the output of ifconfig
Everything looks good there. Try a couple more commands, and post the output:
sudo ip route show
sudo cat /etc/resolv.conf
The first command shows the Pi's routing table that tells it where to send network traffic, the second command outputs the file that defines the Pi's DNS settings.
beeedy
Thu Apr 25, 2013 7:12 pm
ip route show:
10.38.0.0/17 dev eth0 proto kernel scope link src 10.38.1.148
192.168.42.0/24 dev wlan0 proto kernel scope link src 192.168.42.1
cat /etc/resolv.conf:
domain stthomas.edu
search stthomas.edu
nameserver 140.209.1.17
nameserver 140.209.1.5
nameserver 137.192.2.3
nameserver 206.9.64.101
It is connected to my campus network, but as stated before it had access to the internet before. Also, I previously changed the MAC address for the pi to the MAC address of my phone. This was done to bypass the need to log into the network. It still had internet access after changing the MAC address
krish13
Thu Apr 25, 2013 7:18 pm
hey nice try i am trying to get connect to wifi and also i will try your application hotspot i think this is easy to share internet locally and seems to be easy configurable steps thanks for sharing..
hunternet93
Thu Apr 25, 2013 7:19 pm
[quote="beeedy"]ip route show:
This is probably the problem -- Your default gateway is not set. The default gateway should be set to your campus's router, most likely 10.38.1.1. You can find the default gateway by connecting to the internet and running "ip route show" again, the first line will have the IP address of the default gateway. To set the default gateway, edit /etc/network/interfaces and add this line under the section "iface eth0 inet static":
  gateway 10.38.1.1
Replace 10.38.1.1 with the IP address of your campus' router and reboot.
beeedy
Thu Apr 25, 2013 7:29 pm
In /etc/network/interfaces I am not seeing "iface eth0 inet static". Are you referring to "iface wlan0 inet static" or possibly "iface eth0 inet dhcp"?
EDIT: It appears the ethernet wall port was faulty! After switching wall ports it appears to all work! Thank you for all your help and rapid responses!
bqzero
Tue Apr 30, 2013 2:36 pm
Hi Guys
I have to say the tutorial is very easy and covers it pretty good.
I follwed the steps in the wiki and everything is working fine, except NAT.
DHCPD and HOSTPAD are doing good. also connecting devices to the WiFi Hotspot works like a charm, but when I try to access the internet through the PI AP no NAT.
I also checked the iptables -L -n to see if the 3 entries according to tutorial are present, but they arent.
I tried to reenter them again, but it does not work neither with sudo ... or opening terminal with su. iptables seems to be empty.
the save however has correct entries.
Does anyone know what the issue could be?
Best regards,
Christian
SirLagz
Tue Apr 30, 2013 3:12 pm
What comes up when you try to enter the iptable rules ?
d42
Sun May 05, 2013 10:56 am
thanks for the tutorial. It works great and my PI is now an accesspoint. By the way, I am using a TP-Link TL-WN725N as wireless adapter.
However, I have the problem that after each restart it isn't working anymore :cry:
I think the problem is that the wlan0 interface doesn't have an IP address. After
sudo ifconfig wlan0 192.168.42.1
and the restart of the DNS server it works just fine.
I already tried to uninstall network-manager and wicd but none of them was installed.
/etc/network/interfaces is:
auto lo
iface lo inet loopback
address 192.168.42.1
netmask 255.255.255.0
#allow-hotplug wlan0
#wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
#iface default inet dhcp
up iptables-restore < /etc/iptables.ipv4.nat
Do you have any ideas? Thanks for your help!
Cheers
Torsten
SirLagz
Sun May 05, 2013 2:47 pm
d42 wrote:Hi,
auto lo
Cheers
Torsten
is ifplugd running ?
run this -
ps aux | grep ifplugd
and paste the output
if ifplugd is running on wlan0, it messes with the IP addresses.
Antonio Corrado
Wed May 08, 2013 2:40 pm
Hi all,
sorry for not reading all the posts. What I would like to accomplish is to have to PIs connected together, basically the "master" PI will have the WIFI usb dongle and the "slave" PI will connect to the internet trough an Ethernet cable linked to the master PI.
Is that doable?
Something like that:
INTERNET <== ROUTER <===WIFI== MASTER PI <==CABLE ==> SLAVE PI
Thanks in advance,
Antonio
SirLagz
Thu May 09, 2013 12:54 am
Antonio Corrado wrote:Hi all,
Is that doable?
Thanks in advance,
Antonio
Yes, that is doable.
You need to turn the Master Pi into a router and run a dhcp server on it so that the Slave Pi can access the internet.
d42
Thu May 09, 2013 10:23 am
SirLagz wrote: is ifplugd running ?
run this -
Hi SirLagz,
thanks for your answer. I ran the command and it says:
pi@raspberrypi ~ $ ps aux | grep ifplugd
root      1444  0.0  0.1   1744   504 ?        S    12:16   0:00 /usr/sbin/ifplugd -i lo -q -f -u0 -d10 -w -I
root      1478  0.1  0.1   1744   516 ?        S    12:16   0:00 /usr/sbin/ifplugd -i wlan0 -q -f -u0 -d10 -w -I
root      1490  0.0  0.1   1744   512 ?        S    12:16   0:00 /usr/sbin/ifplugd -i eth0 -q -f -u0 -d10 -w -I
pi        2096  0.0  0.2   4140   912 pts/0    S+   12:19   0:00 grep --color=auto ifplugd
SirLagz
Fri May 10, 2013 2:23 am
run this -
Hi SirLagz,
Yep, ifplugd is running on wlan0 which will bugger things up.
http://sirlagz.net/2013/02/10/how-to-us ... r-part-3b/ <-- how to disable ifplugd for wlan0 :)
d42
Sat May 11, 2013 10:12 am
SirLagz wrote: Yep, ifplugd is running on wlan0 which will bugger things up.
Hi SirLagz,
thanks for your reply. Unfortunately it doesn't work :cry:
I added the lines as written on your website but still the same, wlan0 doesn't have an IP address on startup. Do you have any other ideas?
Cheers
Torsten
rocketjeremy
Sat May 11, 2013 8:40 pm
Hello all,
New lover of the Pi and moving on to another project. I've started with a fresh raspbian install and followed the wiki step by step. I'm using the Ratlink RT5370 usb stick. I get a great connection to the wireless and the IP address I'm expecting that works along with how I have other things assigned on the network. However when I go to visit a website I get nothing, DNS failed. Any thoughts on what might be going wrong or things to check? I've doubled checked that the Pi itself has internet but I'm not sure what else to check. Thanks! ~Jeremy
SirLagz
Sun May 12, 2013 2:59 pm
Hi SirLagz,
Cheers
Torsten
Do you have a static IP address set ?
