Shaken_Earth
ifconfig on RPi 3 not returning an IPv4 address
Mon Aug 07, 2017 7:42 pm
Hi, I've been following this tutorial (https://diyhacking.com/raspberry-pi-web-server/) to set up my Pi as a web server. However, once I use
ifconfig
to try and find
inet
Bcast
, and
Mask
under the
eth0
section, all I get is an
inet6
MAC address.
wlan0
includes all of this information however and I'm of course able to access the server from any device connected to my WiFi router. However, how do I go about getting the proper information from
eth0
? Thanks in advance!
This is the full information returned by
ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:0c:df:b2
          inet6 addr: fe80::e6d4:d65c:4b80:a222/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:172 errors:0 dropped:0 overruns:0 frame:0
          TX packets:172 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:14112 (13.7 KiB)  TX bytes:14112 (13.7 KiB)
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:59:8a:e7
          inet addr:192.168.86.36  Bcast:192.168.86.255  Mask:255.255.255.0
          inet6 addr: fe80::e28b:9beb:6c8b:60b1/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1708 errors:0 dropped:7 overruns:0 frame:0
          TX packets:1670 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1327896 (1.2 MiB)  TX bytes:298195 (291.2 KiB)
elkberry
Re: ifconfig on RPi 3 not returning an IPv4 address
Mon Aug 07, 2017 8:17 pm
You seem to neither have an IPv6 router running, nor an DHCPv4 server. No IPv6 router, because all you get on eth0 is the usual fe80:: IPv6 SLAAC LLA, that's an automatic link-local address. And as you don't see any IPv4 address, then there's also no DHCPv4 server responding on your eth0 network. So what do you want to achieve here at all?
From ZX81 to Raspberry Pi, but wait ... where's the 7805 gone?
Mon Aug 07, 2017 9:39 pm
Is your RPi connected to anything? Is the cable from eth0 faulty (check for green lights on both ends)? Is dhcpcd still installed and running?
That FE80::e6d4:d65c:4b80:a222/64 IPv6 link-local address is assigned by the Linux kernel when the interface comes up during boot up. I'm surprised you've not got a 169.254.xxx.yyy IPv4 link-local address which is why it looks like dhcpcd may have failed.
elkberry
Tue Aug 08, 2017 6:18 am
Just a minor note, as far as I remember having seen the behavior (but I may be wrong): the LLA only appears if eth0 has carrier, but not when it comes up.
Tue Aug 08, 2017 8:02 am
I'm not sure it works that way for IPv6 which has much better zero configuration options. I've not tested it.
