geppetto
Using a Pi to store images from a security camera
Wed Jun 21, 2017 10:28 am
Sorry guys I'm new to all this.... :oops:
I have a security camera on my home network and I want to store the images generated by motion alert on a Pi which will have an attatched WD hard drive...
So could somebody point me in the right direction so I can read up and start the project.
Will I need to install say an FTP server on the Pi to achieve this or is that not the correct approach?
Thanks for any pointers
Phil
RaTTuS
Contact: Twitter YouTube
Re: Using a Pi to store images from a security camera
Wed Jun 21, 2017 10:37 am
What type of camera ?
how do you log into it to get images
what software is provided
is it an IP camera or analogue
what streams does it provide
Covfefe
geppetto
Wed Jun 21, 2017 12:14 pm
Hi
It's a Foscam WIFI IP camera and I use either the app on my iPad or the provided Windows software to view it's output.
What I need, is some where to store the snippets of video or single image snapshots generated by the camera when it
detects motion.
I was looking in the "save" settings on the camera GUI and it can save to an SD card inside the camera but that goes if
somebody steals it. Also, I noticed that I can set it up to FTP these captures and so my interest in using a Pi to receive and
store them..
As I say, I'm not to technical but if I'm on the right lines, I'm prepaired to put the work and learning in..
Thanks for your response
Phil
jgreen71
Wed Jun 21, 2017 12:24 pm
geppetto wrote: Also, I noticed that I can set it up to FTP these captures and so my interest in using a Pi to receive and
store them.
I would say that this is your best bet. Set up an FTP server on the PI to store the images, and have the camera push the images there.
A quick Google also shows that the camera may have its own internal web server. A bit of peeking around might let the PI scrape the images from the camera that way.
geppetto
Wed Jun 21, 2017 12:35 pm
Thank you
Forgot to post the model of the camera......FOSCAM FI9900P Outdoor HD WiFi IP Camera
They do a fairly cheap (£54) NVR for it which needs a hard drive adding but to access that needs a mouse/keyboard and monitor.
I guess it's Linux based but the Pi will be much cheaper to run 24/7.
Looking forward to getting stuck into this project as I have a spare Pi3 and an original unused WD 314G drive that WD brought out for the Pi
Phil
geppetto
Sun Jun 25, 2017 10:31 am
YAY!
Got it working...
Used a Pi3 with latest Raspian.
Installed a basic setuo of VSTPD as per instructions here..
http://choccyhobnob.com/tutorials/setti ... pberry-pi/
Setup the Foscam and it started uploading motion captures to the Pi in it's Home folder.
Next, I installed a Raspian image on my WD Pi drive (314Gb) and followed instructions here to
run my Pi from the drive...
https://www.raspberrypi.org/documentati ... des/msd.md
So, I now have no SD card in the Pi, it boots from the WD drive and the Foscam now has over 289Gb to
fill up :)
I monitor what's on the images using FileZilla..
All easy peasy to most of you folk but to this 71 year old Linux numpty it was a task but good outcome.
Going to learn now how to maybe tweak/improve it all..
Phil
