girish_kumar
Rpi as Wifi AP in isolated private network
Thu Jun 01, 2017 4:42 am
:D Folks,
I have a question about creating a standalone Intranet (private wireless network with any connection to public internet) with Rpi
as the WiFi Access point
I had followed all the instructions given in https://www.raspberrypi.org/documentati ... s-point.md
and the access point came up. Using the WiFi signals I am able to connect to the new access point through which I was able to access the public internet.
Now my next step is to disconnect RPi from the public internet, so I disconnected the ethernet cable from Rpi and rebooted it.
I connected few computers to the Rpi Access point. They were all able to authenticate and connect.
Now comes the problem.
The computers connected to Rpi Access point is not able an IP address from Rpi. I understand than the dnsmasq is the responsible for giving IP address to the computers. But for some reason this is not working. During the connection process, I Can see the message "Obtaining IP address" and it waits after some time it times out.
Not able to figure out what is going wrong here. When I connect the Ethernet cable back, all computers all get IP address
Going one step deeper I found computers are getting IP address from a DHCP server outside (Rpi) that is DHCP server within my main Wireless network. (not from DNSmasq)
1. To debug futhrer, I checked the syslog files I see some issues, not able to understand what exactly the problem is
2. Checked the dnsmasq.cong using dnsmasq -test option and it showing everything OK
3. As per the instructions I tried to ssh [email protected] and this is not reachable, this we can understand.
I am attaching the Syslog files as a separate file can any give me a clue to debug this issue ?
Few lines I noticed when I booted WITHOUT ETHERNET CABLE
Jun 1 09:05:58 raspberrypi networking[208]: All rights reserved.
Jun 1 09:05:58 raspberrypi networking[208]: For info, please visit https://www.isc.org/software/dhcp/
Jun 1 09:05:58 raspberrypi dhclient: Listening on LPF/br0/b8:27:eb:e8:f1:fa
Jun 1 09:05:58 raspberrypi dhclient: Sending on LPF/br0/b8:27:eb:e8:f1:fa
Jun 1 09:05:58 raspberrypi dhclient: Sending on Socket/fallback
Jun 1 09:05:58 raspberrypi dhclient: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 5
Jun 1 09:05:58 raspberrypi networking[208]: Listening on LPF/br0/b8:27:eb:e8:f1:fa
Jun 1 09:05:58 raspberrypi networking[208]: Sending on LPF/br0/b8:27:eb:e8:f1:fa
Jun 1 09:05:58 raspberrypi networking[208]: Sending on Socket/fallback
Jun 1 09:05:58 raspberrypi networking[208]: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 5
Jun 1 09:05:58 raspberrypi dhclient: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 10
Jun 1 09:05:58 raspberrypi networking[208]: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 10
Jun 1 09:05:58 raspberrypi dhclient: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 12
Jun 1 09:05:58 raspberrypi networking[208]: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 12
Jun 1 09:05:58 raspberrypi dhclient: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 11
Jun 1 09:05:58 raspberrypi networking[208]: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 11
Jun 1 09:05:58 raspberrypi dhclient: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 14
Jun 1 09:05:58 raspberrypi networking[208]: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 14
Jun 1 09:05:58 raspberrypi dhclient: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 9
Jun 1 09:05:58 raspberrypi networking[208]: DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 9
Jun 1 09:05:58 raspberrypi dhclient: No DHCPOFFERS received.
Jun 1 09:05:58 raspberrypi dhclient: No working leases in persistent database - sleeping.
Jun 1 09:05:58 raspberrypi networking[208]: No DHCPOFFERS received.
Jun 1 09:05:58 raspberrypi networking[208]: No working leases in persistent database - sleeping.
Jun 1 09:05:58 raspberrypi networking[208]: done.
Jun 1 09:05:58 raspberrypi systemd[1]: Started LSB: Raise network interfaces..
Jun 1 09:05:58 raspberrypi systemd[1]: Starting ifup for wlan0...
Jun 1 09:05:58 raspberrypi systemd[1]: Started ifup for wlan0.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting System Initialization.
Jun 1 09:05:58 raspberrypi systemd[1]: Reached target System Initialization.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 1 09:05:58 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting D-Bus System Message Bus Socket.
Jun 1 09:05:58 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Sockets.
Jun 1 09:05:58 raspberrypi systemd[1]: Reached target Sockets.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Daily Cleanup of Temporary Directories.
Few lines which I noticed (This is with ethernet cable connected)
Jun 1 09:17:28 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Jun 1 09:17:28 raspberrypi systemd[1]: Starting Network.
Jun 1 09:17:28 raspberrypi systemd[1]: Reached target Network.
Jun 1 09:17:28 raspberrypi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server.
Jun 1 09:17:28 raspberrypi systemd[1]: Starting Network is Online.
Jun 1 09:17:28 raspberrypi systemd[1]: Reached target Network is Online.
Jun 1 09:17:28 raspberrypi systemd[1]: Starting LSB: Start NTP daemon...
Jun 1 09:17:28 raspberrypi dnsmasq[643]: dnsmasq: syntax check OK.
Jun 1 09:17:28 raspberrypi systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon...
Jun 1 09:17:28 raspberrypi systemd[1]: Starting Permit User Sessions...
Jun 1 09:17:29 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Jun 1 09:17:29 raspberrypi systemd[1]: Started Permit User Sessions.
Jun 1 09:17:29 raspberrypi ntpd[679]: ntpd [email protected] Mon Jul 25 22:35:28 UTC 2016 (1)
Jun 1 09:17:29 raspberrypi ntp[649]: Starting NTP server: ntpd.
Jun 1 09:17:29 raspberrypi ntpd[680]: proto: precision = 1.000 usec
Jun 1 09:17:30 raspberrypi ntpd[680]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Jun 1 09:17:30 raspberrypi systemd[1]: Started LSB: Start NTP daemon.
Jun 1 09:17:30 raspberrypi ntpd[680]: Listen and drop on 1 v6wildcard :: UDP 123
Jun 1 09:17:30 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Jun 1 09:17:30 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Jun 1 09:17:30 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 168 (plymouthd).
Jun 1 09:17:30 raspberrypi kernel: [ 35.402493] ==> rtl8188e_iol_efuse_patch
Jun 1 09:17:30 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Jun 1 09:17:30 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Jun 1 09:17:31 raspberrypi systemd[1]: Starting Getty on tty1...
Jun 1 09:17:31 raspberrypi systemd[1]: Started Getty on tty1.
Jun 1 09:17:31 raspberrypi systemd[1]: Starting Serial Getty on ttyAMA0...
Jun 1 09:17:31 raspberrypi systemd[1]: Started Serial Getty on ttyAMA0.
Jun 1 09:17:31 raspberrypi systemd[1]: Starting Login Prompts.
Jun 1 09:17:31 raspberrypi systemd[1]: Reached target Login Prompts.
Jun 1 09:17:31 raspberrypi kernel: [ 36.269687] RTL871X: nolinked power save leave
Jun 1 09:17:31 raspberrypi ntpd[680]: Listen normally on 2 lo 127.0.0.1 UDP 123
Jun 1 09:17:31 raspberrypi ntpd[680]: Listen normally on 3 br0 192.168.1.108 UDP 123
Jun 1 09:17:31 raspberrypi ntpd[680]: Listen normally on 4 lo ::1 UDP 123
Jun 1 09:17:31 raspberrypi kernel: [ 36.308368] br0: port 2(wlan0) entered blocking state
Jun 1 09:17:31 raspberrypi kernel: [ 36.308390] br0: port 2(wlan0) entered disabled state
Jun 1 09:17:31 raspberrypi kernel: [ 36.313215] device wlan0 entered promiscuous mode
Jun 1 09:17:31 raspberrypi ntpd[680]: Listen normally on 5 br0 fe80::ba27:ebff:fee8:f1fa UDP 123
Jun 1 09:17:31 raspberrypi ntpd[680]: peers refreshed
Jun 1 09:17:31 raspberrypi ntpd[680]: Listening on routing socket on fd #22 for interface updates
Jun 1 09:17:31 raspberrypi dnsmasq[689]: started, version 2.76 cachesize 150
Jun 1 09:17:31 raspberrypi dnsmasq[689]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Jun 1 09:17:31 raspberrypi dnsmasq[689]: warning: interface wlan0 does not currently exist
Jun 1 09:17:31 raspberrypi dnsmasq-dhcp[689]: DHCP, IP range 192.168.0.2 -- 192.168.0.20, lease time 1d
Jun 1 09:17:31 raspberrypi dnsmasq[689]: reading /run/dnsmasq/resolv.conf
Jun 1 09:17:31 raspberrypi dnsmasq[689]: using nameserver 202.83.21.28#53
Jun 1 09:17:31 raspberrypi dnsmasq[689]: using nameserver 202.83.21.24#53
Jun 1 09:17:31 raspberrypi dnsmasq[689]: using nameserver 8.8.8.8#53
Jun 1 09:17:31 raspberrypi dnsmasq[689]: read /etc/hosts - 5 addresses
Jun 1 09:17:31 raspberrypi systemd[1]: dnsmasq.service: Supervising process 689 which is not our child. We'll most likely not notice when it exits.
Jun 1 09:17:32 raspberrypi kernel: [ 37.148712] RTL871X: assoc success
Jun 1 09:17:32 raspberrypi kernel: [ 37.152527] br0: port 2(wlan0) entered blocking state
Jun 1 09:17:32 raspberrypi kernel: [ 37.152555] br0: port 2(wlan0) entered forwarding state
Jun 1 09:17:32 raspberrypi kernel: [ 37.167546] RTL871X: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:AES
Jun 1 09:17:32 raspberrypi hostapd[651]: Starting advanced IEEE 802.11 management: hostapd.
Jun 1 09:17:32 raspberrypi systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon.
Jun 1 09:17:33 raspberrypi systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Jun 1 09:17:33 raspberrypi systemd[1]: Starting Multi-User System.
Jun 1 09:17:33 raspberrypi systemd[1]: Reached target Multi-User System.
Jun 1 09:17:33 raspberrypi systemd[1]: Starting Graphical Interface.
Jun 1 09:17:33 raspberrypi systemd[1]: Reached target Graphical Interface.
Jun 1 09:17:33 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jun 1 09:17:33 raspberrypi systemd[1]: Starting Host and Network Name Lookups.
Jun 1 09:17:33 raspberrypi systemd[1]: Reached target Host and Network Name Lookups.
Jun 1 09:17:33 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Jun 1 09:17:33 raspberrypi systemd[1]: Startup finished in 3.737s (kernel) + 34.743s (userspace) = 38.480s.
Copy paste of whole syslog file
Jun 1 09:05:58 raspberrypi systemd[1]: Mounted Configuration File System.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Apply Kernel Variables.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Jun 1 09:05:58 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Copy rules generated while the root was ro...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting LSB: Set preliminary keymap...
Jun 1 09:05:58 raspberrypi systemd-fsck[83]: e2fsck 1.42.12 (29-Aug-2014)
Jun 1 09:05:58 raspberrypi systemd-fsck[83]: /dev/mmcblk0p2: clean, 41373/451232 files, 331776/1928960 blocks
Jun 1 09:05:58 raspberrypi fake-hwclock[87]: Thu 1 Jun 03:33:52 UTC 2017
Jun 1 09:05:58 raspberrypi systemd[1]: Started Copy rules generated while the root was ro.
Jun 1 09:05:58 raspberrypi keyboard-setup[120]: Setting preliminary keymap...done.
Jun 1 09:05:58 raspberrypi systemd[1]: Started LSB: Set preliminary keymap.
Jun 1 09:05:58 raspberrypi systemd[1]: Found device /dev/ttyAMA0.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
Jun 1 09:05:58 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 170 (plymouthd).
Jun 1 09:05:58 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Paths.
Jun 1 09:05:58 raspberrypi systemd[1]: Reached target Paths.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Forward Password Requests to Plymouth Directory Watch.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Various fixups to make systemd work better on Debian.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Local File Systems (Pre).
Jun 1 09:05:58 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Jun 1 09:05:58 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/8bc64c53-01.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Load/Save Random Seed.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/8bc64c53-01...
Jun 1 09:05:58 raspberrypi systemd-fsck[184]: fsck.fat 3.0.27 (2014-11-12)
Jun 1 09:05:58 raspberrypi systemd-fsck[184]: /dev/mmcblk0p1: 138 files, 42766/82644 clusters
Jun 1 09:05:58 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/8bc64c53-01.
Jun 1 09:05:58 raspberrypi systemd[1]: Mounting /boot...
Jun 1 09:05:58 raspberrypi systemd[1]: Mounted /boot.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Local File Systems.
Jun 1 09:05:58 raspberrypi systemd[1]: Reached target Local File Systems.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Remote File Systems.
Jun 1 09:05:58 raspberrypi systemd[1]: Reached target Remote File Systems.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting LSB: Prepare console...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting LSB: Raise network interfaces....
Jun 1 09:05:58 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Jun 1 09:05:58 raspberrypi kbd[205]: Setting console screen modes.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jun 1 09:05:58 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Jun 1 09:05:58 raspberrypi kbd[205]: setterm: $TERM is not defined.
Jun 1 09:05:58 raspberrypi systemd[1]: Started LSB: Prepare console.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting LSB: Set console font and keymap...
Jun 1 09:05:58 raspberrypi raspi-config[206]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
Jun 1 09:05:58 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Sound Card.
Jun 1 09:05:58 raspberrypi systemd[1]: Reached target Sound Card.
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Linux version 4.9.24+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #993 Wed Apr 26 17:56:54 BST 2017
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] OF: fdt:Machine model: Raspberry Pi Model B Rev 2
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] cma: Reserved 8 MiB at 0x1b400000
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Memory policy: Data cache writeback
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] On node 0 totalpages: 114688
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0914814, node_mem_map db010000
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Normal zone: 1008 pages used for memmap
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Normal zone: 0 pages reserved
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Normal zone: 114688 pages, LIFO batch:31
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] pcpu-alloc: [0] 0
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113680
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Kernel command line: bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=8bc64c53-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Memory: 435948K/458752K available (5942K kernel code, 489K rwdata, 1948K rodata, 404K init, 734K bss, 14612K reserved, 8192K cma-reserved)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] Virtual kernel memory layout:
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] vmalloc : 0xdc800000 - 0xff800000 ( 560 MB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] .text : 0xc0008000 - 0xc05d5d7c (5944 kB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] .init : 0xc083f000 - 0xc08a4000 ( 404 kB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] .data : 0xc08a4000 - 0xc091e6c8 ( 490 kB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] .bss : 0xc091e6c8 - 0xc09d5ec8 ( 734 kB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jun 1 09:05:58 raspberrypi kernel: [ 0.000000] NR_IRQS:16 nr_irqs:16 16
Jun 1 09:05:58 raspberrypi kernel: [ 0.000030] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Jun 1 09:05:58 raspberrypi kernel: [ 0.000073] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Jun 1 09:05:58 raspberrypi kernel: [ 0.000171] bcm2835: system timer (irq = 27)
Jun 1 09:05:58 raspberrypi kernel: [ 0.000635] Console: colour dummy device 80x30
Jun 1 09:05:58 raspberrypi kernel: [ 0.001394] console [tty1] enabled
Jun 1 09:05:58 raspberrypi kernel: [ 0.001451] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Jun 1 09:05:58 raspberrypi kernel: [ 0.060348] pid_max: default: 32768 minimum: 301
Jun 1 09:05:58 raspberrypi kernel: [ 0.060806] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.060876] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.061976] Disabling cpuset control group subsystem
Jun 1 09:05:58 raspberrypi kernel: [ 0.062247] CPU: Testing write buffer coherency: ok
Jun 1 09:05:58 raspberrypi kernel: [ 0.062358] ftrace: allocating 21708 entries in 64 pages
Jun 1 09:05:58 raspberrypi kernel: [ 0.179053] Setting up static identity map for 0x8200 - 0x8238
Jun 1 09:05:58 raspberrypi kernel: [ 0.181105] devtmpfs: initialized
Jun 1 09:05:58 raspberrypi kernel: [ 0.189729] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Jun 1 09:05:58 raspberrypi kernel: [ 0.190239] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Jun 1 09:05:58 raspberrypi kernel: [ 0.190340] futex hash table entries: 256 (order: -1, 3072 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.191647] pinctrl core: initialized pinctrl subsystem
Jun 1 09:05:58 raspberrypi kernel: [ 0.193151] NET: Registered protocol family 16
Jun 1 09:05:58 raspberrypi kernel: [ 0.195605] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Jun 1 09:05:58 raspberrypi kernel: [ 0.205331] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Jun 1 09:05:58 raspberrypi kernel: [ 0.205425] hw-breakpoint: maximum watchpoint size is 4 bytes.
Jun 1 09:05:58 raspberrypi kernel: [ 0.205569] Serial: AMBA PL011 UART driver
Jun 1 09:05:58 raspberrypi kernel: [ 0.208354] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Jun 1 09:05:58 raspberrypi kernel: [ 0.255380] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
Jun 1 09:05:58 raspberrypi kernel: [ 0.258072] SCSI subsystem initialized
Jun 1 09:05:58 raspberrypi kernel: [ 0.258400] usbcore: registered new interface driver usbfs
Jun 1 09:05:58 raspberrypi kernel: [ 0.258574] usbcore: registered new interface driver hub
Jun 1 09:05:58 raspberrypi kernel: [ 0.258817] usbcore: registered new device driver usb
Jun 1 09:05:58 raspberrypi kernel: [ 0.269109] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-04-27 17:19
Jun 1 09:05:58 raspberrypi kernel: [ 0.271073] clocksource: Switched to clocksource timer
Jun 1 09:05:58 raspberrypi kernel: [ 0.325383] VFS: Disk quotas dquot_6.6.0
Jun 1 09:05:58 raspberrypi kernel: [ 0.325580] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.325916] FS-Cache: Loaded
Jun 1 09:05:58 raspberrypi kernel: [ 0.326331] CacheFiles: Loaded
Jun 1 09:05:58 raspberrypi kernel: [ 0.345820] NET: Registered protocol family 2
Jun 1 09:05:58 raspberrypi kernel: [ 0.347237] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.347395] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.347527] TCP: Hash tables configured (established 4096 bind 4096)
Jun 1 09:05:58 raspberrypi kernel: [ 0.347658] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.347724] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jun 1 09:05:58 raspberrypi kernel: [ 0.348082] NET: Registered protocol family 1
Jun 1 09:05:58 raspberrypi kernel: [ 0.348871] RPC: Registered named UNIX socket transport module.
Jun 1 09:05:58 raspberrypi kernel: [ 0.348948] RPC: Registered udp transport module.
Jun 1 09:05:58 raspberrypi kernel: [ 0.348987] RPC: Registered tcp transport module.
Jun 1 09:05:58 raspberrypi kernel: [ 0.349022] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 1 09:05:58 raspberrypi kernel: [ 0.350137] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Jun 1 09:05:58 raspberrypi kernel: [ 0.352752] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Jun 1 09:05:58 raspberrypi kernel: [ 0.372504] FS-Cache: Netfs 'nfs' registered for caching
Jun 1 09:05:58 raspberrypi kernel: [ 0.374283] NFS: Registering the id_resolver key type
Jun 1 09:05:58 raspberrypi kernel: [ 0.374406] Key type id_resolver registered
Jun 1 09:05:58 raspberrypi kernel: [ 0.374450] Key type id_legacy registered
Jun 1 09:05:58 raspberrypi kernel: [ 0.378887] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Jun 1 09:05:58 raspberrypi kernel: [ 0.379355] io scheduler noop registered
Jun 1 09:05:58 raspberrypi kernel: [ 0.379419] io scheduler deadline registered (default)
Jun 1 09:05:58 raspberrypi kernel: [ 0.379895] io scheduler cfq registered
Jun 1 09:05:58 raspberrypi kernel: [ 0.385983] BCM2708FB: allocated DMA memory 5b500000
Jun 1 09:05:58 raspberrypi kernel: [ 0.386115] BCM2708FB: allocated DMA channel 0 @ dc80d000
Jun 1 09:05:58 raspberrypi systemd[1]: Starting system-systemd\x2drfkill.slice.
Jun 1 09:05:58 raspberrypi systemd[1]: Created slice system-systemd\x2drfkill.slice.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status of rfkill0...
Jun 1 09:05:58 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status of rfkill0.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting system-ifup.slice.
Jun 1 09:05:58 raspberrypi systemd[1]: Created slice system-ifup.slice.
Jun 1 09:05:58 raspberrypi console-setup[261]: Setting up console font and keymap...done.
Jun 1 09:05:58 raspberrypi systemd[1]: Started LSB: Set console font and keymap.
Jun 1 09:05:58 raspberrypi networking[208]: Configuring network interfaces...can't add wlan0 to bridge br0: Operation not supported
Jun 1 09:05:58 raspberrypi networking[208]: Waiting for br0 to get ready (MAXWAIT is 32 seconds).
Jun 1 09:05:58 raspberrypi dhclient: Internet Systems Consortium DHCP Client 4.3.1
Jun 1 09:05:58 raspberrypi dhclient: Copyright 2004-2014 Internet Systems Consortium.
Jun 1 09:05:58 raspberrypi dhclient: All rights reserved.
Jun 1 09:05:58 raspberrypi dhclient: For info, please visit https://www.isc.org/software/dhcp/
Jun 1 09:05:58 raspberrypi networking[208]: Internet Systems Consortium DHCP Client 4.3.1
Jun 1 09:05:58 raspberrypi networking[208]: Copyright 2004-2014 Internet Systems Consortium.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Timers.
Jun 1 09:05:58 raspberrypi systemd[1]: Reached target Timers.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Restore Sound Card State...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Basic System.
Jun 1 09:05:58 raspberrypi systemd[1]: Reached target Basic System.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Regular background program processing daemon...
Jun 1 09:05:58 raspberrypi systemd[1]: Started Regular background program processing daemon.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Jun 1 09:05:58 raspberrypi kernel: [ 0.432076] Console: switching to colour frame buffer device 228x61
Jun 1 09:05:58 raspberrypi kernel: [ 0.468977] bcm2835-rng 20104000.rng: hwrng registered
Jun 1 09:05:58 raspberrypi kernel: [ 0.469403] vc-cma: Videocore CMA driver
Jun 1 09:05:58 raspberrypi kernel: [ 0.469582] vc-cma: vc_cma_base = 0x00000000
Jun 1 09:05:58 raspberrypi kernel: [ 0.469774] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.469982] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.470654] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Jun 1 09:05:58 raspberrypi kernel: [ 0.499103] brd: module loaded
Jun 1 09:05:58 raspberrypi kernel: [ 0.513048] loop: module loaded
Jun 1 09:05:58 raspberrypi kernel: [ 0.513249] Loading iSCSI transport class v2.0-870.
Jun 1 09:05:58 raspberrypi kernel: [ 0.514453] usbcore: registered new interface driver smsc95xx
Jun 1 09:05:58 raspberrypi kernel: [ 0.514733] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jun 1 09:05:58 raspberrypi kernel: [ 0.741453] Core Release: 2.80a
Jun 1 09:05:58 raspberrypi kernel: [ 0.741635] Setting default values for core params
Jun 1 09:05:58 raspberrypi kernel: [ 0.741868] Finished setting default values for core params
Jun 1 09:05:58 raspberrypi kernel: [ 0.942582] Using Buffer DMA mode
Jun 1 09:05:58 raspberrypi kernel: [ 0.942763] Periodic Transfer Interrupt Enhancement - disabled
Jun 1 09:05:58 raspberrypi kernel: [ 0.942991] Multiprocessor Interrupt Enhancement - disabled
Jun 1 09:05:58 raspberrypi kernel: [ 0.943207] OTG VER PARAM: 0, OTG VER FLAG: 0
Jun 1 09:05:58 raspberrypi kernel: [ 0.943463] Dedicated Tx FIFOs mode
Jun 1 09:05:58 raspberrypi kernel: [ 0.944227] WARN::dwc_otg_hcd_init:1053: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
Jun 1 09:05:58 raspberrypi kernel: [ 0.944575] FIQ FSM acceleration enabled for :
Jun 1 09:05:58 raspberrypi kernel: [ 0.944575] Non-periodic Split Transactions
Jun 1 09:05:58 raspberrypi kernel: [ 0.944575] Periodic Split Transactions
Jun 1 09:05:58 raspberrypi kernel: [ 0.944575] High-Speed Isochronous Endpoints
Jun 1 09:05:58 raspberrypi kernel: [ 0.944575] Interrupt/Control Split Transaction hack enabled
Jun 1 09:05:58 raspberrypi kernel: [ 0.945235] dwc_otg: Microframe scheduler enabled
Jun 1 09:05:58 raspberrypi kernel: [ 0.945340] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0450738
Jun 1 09:05:58 raspberrypi kernel: [ 0.954184] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0450a14 length 36
Jun 1 09:05:58 raspberrypi kernel: [ 0.962551] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
Jun 1 09:05:58 raspberrypi kernel: [ 0.971358] dwc_otg 20980000.usb: DWC OTG Controller
Jun 1 09:05:58 raspberrypi kernel: [ 0.979847] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Jun 1 09:05:58 raspberrypi kernel: [ 0.988846] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Jun 1 09:05:58 raspberrypi kernel: [ 0.997379] Init: Port Power? op_state=1
Jun 1 09:05:58 raspberrypi kernel: [ 1.006070] Init: Power Port (0)
Jun 1 09:05:58 raspberrypi kernel: [ 1.014766] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun 1 09:05:58 raspberrypi kernel: [ 1.023607] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 1 09:05:58 raspberrypi kernel: [ 1.032031] usb usb1: Product: DWC OTG Controller
Jun 1 09:05:58 raspberrypi kernel: [ 1.040605] usb usb1: Manufacturer: Linux 4.9.24+ dwc_otg_hcd
Jun 1 09:05:58 raspberrypi kernel: [ 1.048939] usb usb1: SerialNumber: 20980000.usb
Jun 1 09:05:58 raspberrypi kernel: [ 1.059046] hub 1-0:1.0: USB hub found
Jun 1 09:05:58 raspberrypi kernel: [ 1.067737] hub 1-0:1.0: 1 port detected
Jun 1 09:05:58 raspberrypi kernel: [ 1.077509] dwc_otg: FIQ enabled
Jun 1 09:05:58 raspberrypi kernel: [ 1.077521] dwc_otg: NAK holdoff enabled
Jun 1 09:05:58 raspberrypi kernel: [ 1.077527] dwc_otg: FIQ split-transaction FSM enabled
Jun 1 09:05:58 raspberrypi kernel: [ 1.077547] Module dwc_common_port init
Jun 1 09:05:58 raspberrypi kernel: [ 1.078059] usbcore: registered new interface driver usb-storage
Jun 1 09:05:58 raspberrypi kernel: [ 1.087463] mousedev: PS/2 mouse device common for all mice
Jun 1 09:05:58 raspberrypi kernel: [ 1.097789] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Jun 1 09:05:58 raspberrypi kernel: [ 1.107206] bcm2835-cpufreq: min=700000 max=700000
Jun 1 09:05:58 raspberrypi kernel: [ 1.116419] sdhci: Secure Digital Host Controller Interface driver
Jun 1 09:05:58 raspberrypi kernel: [ 1.125206] sdhci: Copyright(c) Pierre Ossman
Jun 1 09:05:58 raspberrypi kernel: [ 1.134101] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Jun 1 09:05:58 raspberrypi kernel: [ 1.143474] sdhci-pltfm: SDHCI platform and OF driver helper
Jun 1 09:05:58 raspberrypi kernel: [ 1.152690] ledtrig-cpu: registered to indicate activity on CPUs
Jun 1 09:05:58 raspberrypi kernel: [ 1.161526] hidraw: raw HID events driver (C) Jiri Kosina
Jun 1 09:05:58 raspberrypi kernel: [ 1.170499] usbcore: registered new interface driver usbhid
Jun 1 09:05:58 raspberrypi kernel: [ 1.179024] usbhid: USB HID core driver
Jun 1 09:05:58 raspberrypi kernel: [ 1.189552] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
Jun 1 09:05:58 raspberrypi kernel: [ 1.201614] Initializing XFRM netlink socket
Jun 1 09:05:58 raspberrypi kernel: [ 1.211759] NET: Registered protocol family 17
Jun 1 09:05:58 raspberrypi kernel: [ 1.221302] Key type dns_resolver registered
Jun 1 09:05:58 raspberrypi kernel: [ 1.232152] registered taskstats version 1
Jun 1 09:05:58 raspberrypi kernel: [ 1.241710] vc-sm: Videocore shared memory driver
Jun 1 09:05:58 raspberrypi kernel: [ 1.250274] [vc_sm_connected_init]: start
Jun 1 09:05:58 raspberrypi kernel: [ 1.260397] [vc_sm_connected_init]: end - returning 0
Jun 1 09:05:58 raspberrypi kernel: [ 1.277094] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Jun 1 09:05:58 raspberrypi kernel: [ 2.118613] console [ttyAMA0] enabled
Jun 1 09:05:58 raspberrypi kernel: [ 2.134054] sdhost: log_buf @ db513000 (5b513000)
Jun 1 09:05:58 raspberrypi kernel: [ 2.169465] Indeed it is in host mode hprt0 = 00021501
Jun 1 09:05:58 raspberrypi kernel: [ 2.245932] random: fast init done
Jun 1 09:05:58 raspberrypi kernel: [ 2.271225] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Jun 1 09:05:58 raspberrypi kernel: [ 2.285879] of_cfs_init
Jun 1 09:05:58 raspberrypi kernel: [ 2.318113] of_cfs_init: OK
Jun 1 09:05:58 raspberrypi kernel: [ 2.332043] Waiting for root device PARTUUID=8bc64c53-02...
Jun 1 09:05:58 raspberrypi kernel: [ 2.381210] usb 1-1: new high-speed USB device number 2 using dwc_otg
Jun 1 09:05:58 raspberrypi kernel: [ 2.397845] Indeed it is in host mode hprt0 = 00001101
Jun 1 09:05:58 raspberrypi kernel: [ 2.541416] mmc0: host does not support reading read-only switch, assuming write-enable
Jun 1 09:05:58 raspberrypi kernel: [ 2.562156] mmc0: new high speed SDHC card at address e624
Jun 1 09:05:58 raspberrypi kernel: [ 2.578338] mmcblk0: mmc0:e624 SU08G 7.40 GiB
Jun 1 09:05:58 raspberrypi kernel: [ 2.594982] mmcblk0: p1 p2
Jun 1 09:05:58 raspberrypi kernel: [ 2.641638] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
Jun 1 09:05:58 raspberrypi kernel: [ 2.657387] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 1 09:05:58 raspberrypi kernel: [ 2.675004] hub 1-1:1.0: USB hub found
Jun 1 09:05:58 raspberrypi kernel: [ 2.688001] hub 1-1:1.0: 3 ports detected
Jun 1 09:05:58 raspberrypi kernel: [ 2.726961] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jun 1 09:05:58 raspberrypi kernel: [ 2.744462] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Jun 1 09:05:58 raspberrypi kernel: [ 2.770297] devtmpfs: mounted
Jun 1 09:05:58 raspberrypi kernel: [ 2.784097] Freeing unused kernel memory: 404K (c083f000 - c08a4000)
Jun 1 09:05:58 raspberrypi kernel: [ 2.799991] This architecture does not have kernel memory protection.
Jun 1 09:05:58 raspberrypi kernel: [ 3.021223] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Jun 1 09:05:58 raspberrypi kernel: [ 3.161808] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Jun 1 09:05:58 raspberrypi kernel: [ 3.178370] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 1 09:05:58 raspberrypi kernel: [ 3.200630] smsc95xx v1.0.5
Jun 1 09:05:58 raspberrypi kernel: [ 3.343857] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:e8:f1:fa
Jun 1 09:05:58 raspberrypi kernel: [ 3.461208] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
Jun 1 09:05:58 raspberrypi kernel: [ 3.491420] NET: Registered protocol family 10
Jun 1 09:05:58 raspberrypi kernel: [ 3.642636] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8179
Jun 1 09:05:58 raspberrypi kernel: [ 3.659749] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 1 09:05:58 raspberrypi kernel: [ 3.677030] usb 1-1.2: Product: 802.11n NIC
Jun 1 09:05:58 raspberrypi kernel: [ 3.691247] usb 1-1.2: Manufacturer: Realtek
Jun 1 09:05:58 raspberrypi kernel: [ 3.705347] usb 1-1.2: SerialNumber: 00E04C0001
Jun 1 09:05:58 raspberrypi kernel: [ 3.799122] uart-pl011 20201000.serial: no DMA platform data
Jun 1 09:05:58 raspberrypi kernel: [ 3.911279] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
Jun 1 09:05:58 raspberrypi kernel: [ 4.080125] usb 1-1.3: New USB device found, idVendor=1c4f, idProduct=0002
Jun 1 09:05:58 raspberrypi kernel: [ 4.097362] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun 1 09:05:58 raspberrypi kernel: [ 4.114771] usb 1-1.3: Product: USB Keyboard
Jun 1 09:05:58 raspberrypi kernel: [ 4.129087] usb 1-1.3: Manufacturer: SIGMACHIP
Jun 1 09:05:58 raspberrypi kernel: [ 4.186515] input: SIGMACHIP USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1C4F:0002.0001/input/input0
Jun 1 09:05:58 raspberrypi kernel: [ 4.282489] hid-generic 0003:1C4F:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-20980000.usb-1.3/input0
Jun 1 09:05:58 raspberrypi kernel: [ 4.328173] input: SIGMACHIP USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1C4F:0002.0002/input/input1
Jun 1 09:05:58 raspberrypi kernel: [ 4.421747] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-20980000.usb-1.3/input1
Jun 1 09:05:58 raspberrypi kernel: [ 8.617362] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Jun 1 09:05:58 raspberrypi kernel: [ 9.750181] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jun 1 09:05:58 raspberrypi kernel: [ 13.218741] 8188eu: loading out-of-tree module taints kernel.
Jun 1 09:05:58 raspberrypi kernel: [ 13.565986] RTL871X: module init start
Jun 1 09:05:58 raspberrypi kernel: [ 13.566008] RTL871X: rtl8188eu v4.3.0.8_13968.20150417
Jun 1 09:05:58 raspberrypi kernel: [ 13.566014] RTL871X: build time: May 12 2017 19:24:47
Jun 1 09:05:58 raspberrypi kernel: [ 13.631711] bFWReady == _FALSE call reset 8051...
Jun 1 09:05:58 raspberrypi kernel: [ 13.885511] RTL871X: rtw_ndev_init(wlan0)
Jun 1 09:05:58 raspberrypi kernel: [ 13.926399] usbcore: registered new interface driver rtl8188eu
Jun 1 09:05:58 raspberrypi kernel: [ 13.926422] RTL871X: module init ret=0
Jun 1 09:05:58 raspberrypi kernel: [ 15.684236] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Jun 1 09:05:58 raspberrypi kernel: [ 15.782553] br0: port 1(eth0) entered blocking state
Jun 1 09:05:58 raspberrypi kernel: [ 15.782578] br0: port 1(eth0) entered disabled state
Jun 1 09:05:58 raspberrypi kernel: [ 15.783154] device eth0 entered promiscuous mode
Jun 1 09:05:58 raspberrypi kernel: [ 15.894882] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Jun 1 09:05:58 raspberrypi kernel: [ 15.928330] IPv6: ADDRCONF(NETDEV_UP): br0: link is not ready
Jun 1 09:05:58 raspberrypi kernel: [ 22.056763] random: crng init done
Jun 1 09:05:58 raspberrypi kernel: [ 128.941874] ==> rtl8188e_iol_efuse_patch
Jun 1 09:05:58 raspberrypi systemd[1]: Started Turn on SSH if /boot/ssh is present.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Login Service...
Jun 1 09:05:58 raspberrypi systemd[1]: Started getty on tty2-tty6 if dbus and logind are not available.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting LSB: triggerhappy hotkey daemon...
Jun 1 09:05:58 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Jun 1 09:05:58 raspberrypi cron[1747]: (CRON) INFO (pidfile fd = 3)
Jun 1 09:05:58 raspberrypi cron[1747]: (CRON) INFO (Running @reboot jobs)
Jun 1 09:05:58 raspberrypi dhcpcd[1749]: version 6.7.1 starting
Jun 1 09:05:58 raspberrypi dhcpcd[1749]: dev: loaded udev
Jun 1 09:05:58 raspberrypi dhcpcd[1749]: br0: adding address fe80::481c:3202:1333:db80
Jun 1 09:05:58 raspberrypi systemd[1]: Starting D-Bus System Message Bus...
Jun 1 09:05:58 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: Found user 'avahi' (UID 105) and group 'avahi' (GID 110).
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: Successfully dropped root privileges.
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: avahi-daemon 0.6.31 starting up.
Jun 1 09:05:58 raspberrypi dphys-swapfile[1754]: Starting dphys-swapfile swapfile setup ...
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: Successfully called chroot().
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: Successfully dropped remaining capabilities.
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: No service file found in /etc/avahi/services.
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: Joining mDNS multicast group on interface br0.IPv6 with address fe80::481c:3202:1333:db80.
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: New relevant interface br0.IPv6 for mDNS.
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: Network interface enumeration completed.
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: Registering new address record for fe80::481c:3202:1333:db80 on br0.*.
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: Registering HINFO record with values 'ARMV6L'/'LINUX'.
Jun 1 09:05:58 raspberrypi dbus[1764]: [system] Successfully activated service 'org.freedesktop.systemd1'
Jun 1 09:05:58 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Jun 1 09:05:58 raspberrypi systemd[1]: Starting System Logging Service...
Jun 1 09:05:58 raspberrypi systemd[1]: Started Restore Sound Card State.
Jun 1 09:05:58 raspberrypi systemd[1]: Started LSB: triggerhappy hotkey daemon.
Jun 1 09:05:58 raspberrypi systemd[1]: Started System Logging Service.
Jun 1 09:05:58 raspberrypi systemd[1]: Started Login Service.
Jun 1 09:05:58 raspberrypi dphys-swapfile[1754]: want /var/swap=100MByte, checking existing: keeping it
Jun 1 09:05:58 raspberrypi kernel: [ 131.281347] RTL871X: nolinked power save enter
Jun 1 09:05:58 raspberrypi avahi-daemon[1759]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 3040011817.
Jun 1 09:05:58 raspberrypi kernel: [ 131.907868] Adding 102396k swap on /var/swap. Priority:-1 extents:5 across:200700k SSFS
Jun 1 09:05:58 raspberrypi dhcpcd[1749]: br0: waiting for carrier
Jun 1 09:05:58 raspberrypi dphys-swapfile[1754]: done.
Jun 1 09:05:58 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Jun 1 09:06:28 raspberrypi dhcpcd[1749]: timed out
Jun 1 09:06:28 raspberrypi dhcpcd[1749]: forked to background, child pid 1849
Jun 1 09:06:28 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Jun 1 09:06:28 raspberrypi systemd[1]: Starting Network.
Jun 1 09:06:28 raspberrypi systemd[1]: Reached target Network.
Jun 1 09:06:28 raspberrypi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Jun 1 09:06:28 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Jun 1 09:06:29 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Jun 1 09:06:29 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Jun 1 09:06:29 raspberrypi systemd[1]: Starting Network is Online.
Jun 1 09:06:29 raspberrypi systemd[1]: Reached target Network is Online.
Jun 1 09:06:29 raspberrypi systemd[1]: Starting LSB: Start NTP daemon...
Jun 1 09:06:29 raspberrypi systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon...
Jun 1 09:06:29 raspberrypi dnsmasq[1850]: dnsmasq: syntax check OK.
Jun 1 09:06:29 raspberrypi systemd[1]: Starting Permit User Sessions...
Jun 1 09:06:29 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Jun 1 09:06:29 raspberrypi systemd[1]: Started Permit User Sessions.
Jun 1 09:06:30 raspberrypi ntpd[1879]: ntpd [email protected] Mon Jul 25 22:35:28 UTC 2016 (1)
Jun 1 09:06:30 raspberrypi ntp[1853]: Starting NTP server: ntpd.
Jun 1 09:06:30 raspberrypi ntpd[1880]: proto: precision = 1.000 usec
Jun 1 09:06:30 raspberrypi ntpd[1880]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Jun 1 09:06:30 raspberrypi systemd[1]: Started LSB: Start NTP daemon.
Jun 1 09:06:30 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Jun 1 09:06:30 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Jun 1 09:06:30 raspberrypi ntpd[1880]: Listen and drop on 1 v6wildcard :: UDP 123
Jun 1 09:06:30 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 170 (plymouthd).
Jun 1 09:06:30 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Jun 1 09:06:30 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Jun 1 09:06:31 raspberrypi systemd[1]: Starting Getty on tty1...
Jun 1 09:06:31 raspberrypi systemd[1]: Started Getty on tty1.
Jun 1 09:06:31 raspberrypi systemd[1]: Starting Serial Getty on ttyAMA0...
Jun 1 09:06:31 raspberrypi systemd[1]: Started Serial Getty on ttyAMA0.
Jun 1 09:06:31 raspberrypi systemd[1]: Starting Login Prompts.
Jun 1 09:06:31 raspberrypi systemd[1]: Reached target Login Prompts.
Jun 1 09:06:31 raspberrypi kernel: [ 164.572167] ==> rtl8188e_iol_efuse_patch
Jun 1 09:06:31 raspberrypi kernel: [ 165.138955] RTL871X: nolinked power save leave
Jun 1 09:06:31 raspberrypi ntpd[1880]: Listen normally on 2 lo 127.0.0.1 UDP 123
Jun 1 09:06:31 raspberrypi ntpd[1880]: Listen normally on 3 lo ::1 UDP 123
Jun 1 09:06:31 raspberrypi ntpd[1880]: peers refreshed
Jun 1 09:06:31 raspberrypi kernel: [ 165.172637] br0: port 2(wlan0) entered blocking state
Jun 1 09:06:31 raspberrypi kernel: [ 165.172660] br0: port 2(wlan0) entered disabled state
Jun 1 09:06:31 raspberrypi kernel: [ 165.174470] device wlan0 entered promiscuous mode
Jun 1 09:06:31 raspberrypi ntpd[1880]: Listening on routing socket on fd #20 for interface updates
Jun 1 09:06:31 raspberrypi dnsmasq[1889]: started, version 2.76 cachesize 150
Jun 1 09:06:31 raspberrypi dnsmasq[1889]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Jun 1 09:06:31 raspberrypi dnsmasq[1889]: warning: interface wlan0 does not currently exist
Jun
drgeoff
Re: Rpi as Wifi AP in isolated private network
Thu Jun 01, 2017 7:15 am
girish_kumar wrote::D Folks,
That last sentence suggests to me that you have not "followed all the instructions" correctly.
The first half of the page https://www.raspberrypi.org/documentati ... s-point.md, from the heading "SETTING UP A RASPBERRY PI AS AN ACCESS POINT IN A STANDALONE NETWORK" to and including the paragraph "By this point, the Raspberry Pi is acting as an access point, and other devices can associate with it. Associated devices can access the Raspberry Pi access point via its IP address for operations such as rsync, scp, or ssh" should not give access to the public internet.
girish_kumar
Thu Jun 01, 2017 10:56 am
If you look at one page
https://www.raspberrypi.org/documentati ... /wireless/
You can see three options
1. PIXEL Desktop.
A guide to setting up wireless networking using the PIXEL desktop.
2.Command line.
A guide to setting up wireless networking from the command line.
3.Access point.
A guide to setting the Raspberry Pi up as an access point, and as a internet sharing device.
Look at the item no 3 what does it say ""setting up Rpi as internet sharing device"" This is the link
I had clicked and it took me to
This is what exactly I had followed and my Rpi works as internet sharing device very well but, it does not create a stand alone network that is exactly my problem. As per my analysis in the stand alone mode the dnsmasq is suppose to give IP address to computer, that is not happening. This is what I am trying to debug.
Regards
Girish
B.Goode
Thu Jun 01, 2017 11:27 am
Maybe the webpage has changed recently...
When I look at https://www.raspberrypi.org/documentati ... /wireless/ the text with the final option says:
The comma in that text looks significant.
In the linked resource the first section is titled
That seems to be what you need to do.
The second section of the resource is titled
USING THE RASPBERRY PI AS AN ACCESS POINT TO SHARE AN INTERNET CONNECTION
Although you have no need to do so, it seems you may have also followed this part of the resource, because you would not have internet connectivity otherwise. But doing so has probably 'broken' the stand-alone functionality that you were hoping for.
I suggest a fresh start, re-implement the stand-alone access point, and then Stop without going on to the Internet Sharing section.
girish_kumar
Mon Jun 05, 2017 6:10 am
Folks,
Thanks a lot to all who helped me, with access point.
I was able to setup Rpi as access point in the stand alone network, outside my home without access to public internet. I had tested it for two days and it is working very well.
I did only the first portion and that was it
It worked fine.
Earlier I did the second section too and look like if I do the section section, thinking that once I remove the ethernet cable it will become a stand alone network. I understood that it does not work that way, that was the wrong assumption I had made
Once again thanks a lot of your help and guidence
Regards
Girish
