girish_kumar
Raspberry Pi as WiFi Access point
Mon May 29, 2017 3:42 pm
Folks,
I am trying to configure, Raspberry Pi as WiFi access point
I am following the instructions given at
http://raspberrypihq.com/how-to-turn-a- ... fi-router/
I followed all the instructions, at the final stage I am getting an error
while starting the DHCP server
sudo service isc-dhcp-server start
[email protected]:~ $ sudo service isc-dhcp-server start
Job for isc-dhcp-server.service failed. See 'systemctl status isc-dhcp-server.se rvice' and 'journalctl -xn' for details.
I tried many option to fix this, but none has helped
Can anyone in the group give any clues
Regards
Girish
B.Goode
Re: Raspberry Pi as WiFi Access point
Mon May 29, 2017 3:46 pm
Is there anything relevant in the places mentioned?
If you don't understand what is there, paste it here in case someone more knowledgeable can interpret it.
Mon May 29, 2017 3:52 pm
girish_kumar wrote:Folks,
Regards
Girish
Why are you following a 4 year old Rasphian Wheezy tutorial ???
What is wrong with the tutorial in the Raspberry Pi Website Help Section ???
https://www.raspberrypi.org/documentati ... s-point.md
Retired disgracefully.....
bensimmo
Mon May 29, 2017 5:10 pm
From memory of battling that error once upon a while back, picking up an old SD card and updating it.
When you debug using what it says and searching..
You may find it's because you are using a broken hostapd. Remove everything you have done (easiest if you start fresh really) and follow the official one given above.
That or remove hostapd you installed and get the normal one back.
girish_kumar
Tue May 30, 2017 5:22 pm
Hello fruitoftheloom
>>https://www.raspberrypi.org/documentati ... s-point.md[/quote]
The reason I had followed the 4 years post is, I am NOT using raspberry pi3 instead I am using the first version of
raspberry pi with the latest images. REmember those Rpi with just 2 USB port, I have one lying around so decided build
a product out of it where it acts as wifi access point
Another question I have is : I am using TP-Link Wifi adapter it uses Realtek chip inside
does this support wifi access point ?
HOw do I know whether my wifi adapter can work as Wifi access or not ?
Regards
Girish
Tue May 30, 2017 5:57 pm
girish_kumar wrote:The reason I had followed the 4 years post is, I am NOT using raspberry pi3 instead I am using the first version of
It doesn't matter which Pi you use. The old post only applies to the old images. If you are using the latest images you need to use newer instructions.
Probably. Which Realtek chip?
bensimmo
Tue May 30, 2017 6:45 pm
You will know when you do it the raspberrypi way and it complains.
But you may find you need to set some of the /etc/hostapd/hostapd.conf options a bit differently, I have to for one of my chipsets (RT????), iirc it was, for me, rsn_pairwise=CCMP needed removing as it didn't like it. Found after digging through debugging info stuff.
Just see how it goes, the WiFi adaptor is only reliant on the 'hostapd' file. The rest is just the same.
Tue May 30, 2017 6:47 pm
girish_kumar wrote: The reason I had followed the 4 years post is, I am NOT using raspberry pi3 instead I am using the first version of
So you are then running Raspbian Wheezy 2015-09-28 release ? and NOT Raspbian Jessie 2017-04-10 ?
girish_kumar
Wed May 31, 2017 2:34 am
>> So you are then running Raspbian Wheezy 2015-09-28 release ? and NOT Raspbian Jessie 2017-04-10 ?[/quote]
I am not using Raspbian Wheezy 2015-09-28 release (This is a very old one)
instead I am using RASPBIAN JESSIE LITE 2017-04-10 downloaded recently from raspberry site
Regards
Girish
girish_kumar
Wed May 31, 2017 2:37 am
Probably. Which Realtek chip?[/quote]
The device I am having is: TP-LINK: TL-WN723N V3
After attaching the device I did lsmod and I see the following output
[email protected] ~ $ lsusb
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
Does this device support wifi access point feature ?
Regards
Girish
Wed May 31, 2017 6:19 am
girish_kumar wrote: I am not using Raspbian Wheezy 2015-09-28 release (This is a very old one)
Regards
Girish
Therefore my question stands as to why you are following a 4 year old Wheezy Tutorial ?
When the RPF provide a Tutorial for Jessie, model of RPi is immaterial !!
Wed May 31, 2017 6:25 am
Regards
Girish
Your WiFi requires driver / firmware: viewtopic.php?f=28&t=62371
Last edited by fruitoftheloom on Wed May 31, 2017 7:22 am, edited 1 time in total.
girish_kumar
Wed May 31, 2017 7:13 am
Regards
Girish
To be frank, I started with a clean slate, downloaded the latest rasbian images and started with the instructions in RPF, but it did not work. So I started reading into the each and every line of the document, thinking that I had missed some step or did something wrong, that is when I noticed the one sentence" Note that this documentation was tested on a Raspberry Pi 3"""
This made me to think that I should try alternate instructions and went with the four year old, page.
Since you had confirmed that Pi model does not matter and what matters in version of JESSIE image, I am confident that something has gone wrong either with my setting or my Wifi Adapter needs some special settings which is not mentioned in the step. Will try again and let you know
Thanks a lot for confirming that fact that Pi version is a not problem I am really happy to know that,
Regards
Girish
girish_kumar
Wed May 31, 2017 6:38 pm
Regards
Girish
Regards
Girish
Folks,
Thanks to everyone who helped me to solve the problem, now it solved, I am able to see the wifi signals from raspberry pi on my mobile and it is able to connect to it
There were two problems
1. The driver for my Wifi Adapter was missing in Rasbian, so I installed it as per the suggestion from fruitoftheloom
2. *Still I get a error*: When I create a bridge I get the following error
[email protected]:~ $ sudo systemctl stop hostapd
[email protected]:~ $ sudo vi /etc/dhcpcd.conf
[email protected]:~ $ sudo brctl addbr br0
[email protected]:~ $ sudo brctl addif br0 eth0 wlan0
can't add wlan0 to bridge br0: Operation not supported
Googled a lot to find out the reason, but did not help. Finally did a reboot and did the above steps again and it worked
In short the problem is solved
Regards
Girish
drgeoff
Thu Jun 01, 2017 7:33 am
girish_kumar wrote: In short the problem is solved
Girish
Is it? viewtopic.php?f=36&t=185053
girish_kumar
Thu Jun 01, 2017 10:43 am
Girish
Related to this itself
AS described access point work well as a internet sharing device.
but it does not work as stand alone device. More specifically the computers are not getting IP address from DNSmasq in standalone mode, this is explained in detail at viewtopic.php?f=36&t=185053
Regards
Girish
julien.launay
Sat Jun 09, 2018 11:51 am
Can you give me a step by step tutorial to setup a raspberry as an access point on stretch?
I try to follow these tuto, but nothing works!
https://raspberrypi.stackexchange.com/q ... an-stretch
Thanks to help me.
Julien
SurferTim
Sat Jun 09, 2018 12:09 pm
This is the one I edited for Stretch. It works for me.
