Fixnode
iPhone USB Tethering on Raspberry Pi
Mon Sep 24, 2012 10:51 pm
Hello Everyone,
Recently I followed the instructions found here: http://www.youtube.com/watch?v=x_yhJ_QBfaU
I was able to use my iPhone 4S to tether using USB on the Raspberry Pi (using USB powered hub). I did this by finding out that my iPhone uses eth1 as its main port and then doing dhclient eth1.
However, when I download a large(r) file (7,000KB), my Raspberry Pi cuts out the internet and seems to stop transmitting data through USB. I then have to unplug the iPhone from the USB port and re-plug it in to achieve a internet connection again.
Could this be a problem with the USB drivers?
I will post my terminal screenshot (later today) to show you how it cuts off (and what I mean by that).
In the meantime, please give me some suggestions on how to overcome this problem.
Thanks,
Phillip K
elatllat
Re: iPhone USB Tethering on Raspberry Pi
Thu Sep 27, 2012 8:50 pm
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Gary Littlemore
Wed Oct 31, 2012 10:17 am
I'll try this later, cheers
3b+, 2b, b+, b, Zero & Zero-W
notarat
Wed Oct 31, 2012 1:49 pm
Speaking as someone who understands that a new product may attract people who have little to no prior Linux experience, (who, therefore need a little more verbose help) I gotta say that your post is only about 1% better than "RTFM, n00b!"
ErFillion
Sun May 12, 2013 9:28 pm
How do you connect the idevice to usb tether internet from and to the raspberry pi?
Thijxx
Mon May 13, 2013 12:00 pm
Well spoken.
"It may be that severe load (using the tether) crashes the Pi. This may be caused by the turbo_mode. Here you can find how to turn it off: http://www.raspberrypi.org/phpBB3/viewt ... 4&p=182703
My guess is that it's clear from running dmesg that turbo_mode is utilised or not. Dmesg is a command to show the message buffer of the kernel.
What I found here: http://www.jorgensen.org.uk/computers/2 ... -in-debian
apt-get install ipheth-utils
Mimi: Where'd you come from?
Doyle: My mom and the authorities are still trying to figure that out.
sderbyshire
Thu Apr 27, 2017 7:26 am
Hi guys.
I am a relative noob, but managed to tether my iphone for internet access on Wheezy.
Starting afresh with the latest Jessie download, either full or lite, i cannot get the pi to recognose the iphone for tethering
I download all the additional components, but on connecting the iphone via usb i do not get the 'trust' question on the iphone and nor is 'eth1' appearing.
Something has changed in Jessie i guess?
How do i get around this.
My goal is to use the tethered iphone for mobile internet access, shared via the wifi dongle as a hotspot. This works under wheezy.
Thanks in advance
Steve
172pilot
Tue May 02, 2017 11:09 pm
I'm getting the same problem.. I haven't used it before, but based on reading online, I should expect an ETH1 after plugging in the phone but it's not happening.. Fresh install of latest version of Raspbian Jessie with all updates.. (ie new install 30 minutes ago).. Any help would be awesome!
Tue May 02, 2017 11:41 pm
Removed unhelpful response :oops: :oops:
Last edited by fruitoftheloom on Wed May 03, 2017 5:27 pm, edited 1 time in total.
adieu
sderbyshire
Wed May 03, 2017 4:15 pm
I had the same problem, eth1 appeared automatically under wheezy but not jessie
Try installing usbmuxd
Sudo apt-get install usbmuxd
After this the iphone was recognised and eth1 appeared, turn on personal hotspot 'usb only' and you have a connection
Hth
Steve
wkeeling
Contact: Facebook YouTube
Fri Aug 25, 2017 3:10 pm
I have not been able to get this to work with iPhone 6 and iOS 10.3.3 with the following packages:
gvfs ipheth-utils libimobiledevice-utils gvfs-backends gvfs-bin gvfs-fuse.
When USB is connected to the Pi see the usb but does not know what it is. The source I have found for ipheth-utils looks to only support iPhone 5 and below. ifconfig -s never shows the new network interface.
following these cookbooks:
https://www.daveconroy.com/how-to-tethe ... -iphone-5/
https://www.daveconroy.com/ditch-your-c ... pberry-pi/
Any help or ideas is are appreciated!
Willie Keeling
wkeeling
Sun Sep 03, 2017 9:09 pm
I got it to work half way by installing and reinstall the packages. now the tethering will only work if the iPhone hotspot is bounced (or USB disconnected/reconnected) after the Pi is started/restarted. Also I am unable to mount the phone using ifuse.
if I get this message (paired or unpaired):
GnuTLS error: Error in the push function.
Failed to connect to lockdownd service on the device.
Try again. If it still fails try rebooting your device.
Willie Keeling
