OMID-313
Problem connecting with D-Link DWM-157 3G USB Modem
Sun Apr 30, 2017 4:09 pm
Hi everybody,
I want to connect to the internet using D-Link DWM-157 3G USB Modem, with RPi 3 and Raspbian Jessie latest version.
I've tried billions of methods without success!!
This is so far where I have gone:
Fortunately, the modem has been switched to modem mode, and lsusb confirms that. Also, it has registered 4 ttyUSB devices, ttyUSB0~3.
Now, the internet icon at the top-right corner of the desktop with two top-down arrows, is blinking, which probably means it's trying to connect (but no success!)
I've tried to connect with wvdial and also sakis3g.
The following is /etc/wvdial.conf :
[Dialer Defaults]
Init1 = ATZ
Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
Init3 = AT+CGDCONT=1,"IP","mcinet"
Stupid Mode = 1
Modem Type = Analog Modem
Baud = 9600
New PPPD = yes
Modem = /dev/ttyUSB0
ISDN = 0
Phone = *99#
Username = { }
Password = { }
and also the following is /etc/sakis3g.conf :
APN="mcinet"
Here are the output:
sudo wvdial
Modem initialized.
Sending ATDT*99#
Waiting for carrier.
ATDT*99#
ERROR
OK
Invalid dial command.
Disconnecting at .....
and also:
sudo ./sakis3g --interactive
Preparing Modem ...
Registering Network ...
Modem unable to register a network.
So, what should I do!?
Any help is highly appreciated.
chriscn
Re: Problem connecting with D-Link DWM-157 3G USB Modem
Sun Apr 30, 2017 8:41 pm
As the modem does not have an ethernet port the only method I can think of is;
Setup a laptop to broadcast the internet from the modem to a Wifi Connect and then connect through the raspberry pi. Or buy a router that has a usb port on the back that will allow you to plug in this modem.
With the router connection you can setup your PI to run in ethernet mode so no need to buy a wifi dongle if you do not have one already.
Hope this helps
OMID-313
Mon May 01, 2017 7:50 am
chriscn wrote:As the modem does not have an ethernet port the only method I can think of is;
Hope this helps
Thanks @chriscn for your reply.
This is an alternative solution, but not the solution to my problem!
The 3G USB modem is an standard way of connection.
Anyone any other suggestions !?
Mon May 01, 2017 8:05 am
Hope this helps
I have used several USB 3/4G Modems over the years with varying success, therefore now use a MiFi from Thee Mobile UK:
http://www.three.co.uk/Discover/Devices ... lour=White
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
OMID-313
Mon May 01, 2017 8:10 am
Thanks @fruitoftheloom for your reply.
I know that one alternative is to change this modem.
But for now, I want to diagnose this problem, and make this modem connect to the internet.
And due to the logs above, you can see that the device is in modem mode, and is only a few steps away from connecting to the network.
Any suggestions on how to solve this modem's problem !?
OMID-313
Mon May 01, 2017 8:18 am
Edit1
I've tried this modem on Win7, and it works without problem.
OMID-313
Mon May 01, 2017 9:30 am
Edit2
Here's a debug log of sakis3g :
[email protected]:/usr/bin/modem3g $ sudo ./sakis3g connect --pppd --debug
Sakis3G 0.2.0e running on DEBUG mode.
Sun 30 Apr 21:56:11 IRDT 2017
Command line was: /tmp/sakis3gz.20928.sakis3g "connect" "--pppd" "--debug"
Running with PID: 20958
Environment is:
DEBUG='on'
DESKTOP=''
DISPLAY=':0.0'
EXTRACTED='/tmp/sakis3gz.20928.sakis3g'
HOME='/root'
IFS='
LANG='en_GB.UTF-8'
LOGNAME='root'
LS_COLORS='rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:'
MAIL='/var/mail/root'
MEGZ='./sakis3g'
MYVERSION='0.2.0e'
NOFUNCNAME='1'
OPTIND='1'
PATH='/bin:/sbin:/usr/bin:/usr/sbin'
PPID='20928'
PROVIDER='./sakis3g'
PS1='# '
PS2='> '
PS4='+ '
PWD='/usr/bin/modem3g'
SHELL='/bin/bash'
SUDO_COMMAND='./sakis3g connect --pppd --debug'
SUDO_GID='1000'
SUDO_UID='1000'
SUDO_USER='pi'
TERM='xterm'
TRAPS='cleanscreen '
USER='root'
USERNAME='root'
XAUTHORITY='/home/pi/.Xauthority'
allargs='"connect" "--pppd" "--debug"'
binaryvariable='grep'
cutbin='/usr/bin/cut'
direct_pppd='yes'
grepbin='/bin/grep'
lastverbosetext='Starting up'
me='/tmp/sakis3gz.20928.sakis3g'
printfbin='/usr/bin/printf'
sedbin='/bin/sed'
trbin='/usr/bin/tr'
verbosecurrentcount='7'
whichbin='/bin/which'
Will now proceed with Sakis3G execution.
[20958] [21:56:11] Located "echo" within PATH (/bin/echo).
[20958] [21:56:11] Level 1 dependencies met.
[20958] [21:56:11] Dir "/bin" exists in PATH.
[20958] [21:56:11] Dir "/usr/bin" exists in PATH.
[20958] [21:56:11] Dir "/sbin" exists in PATH.
[20958] [21:56:11] Dir "/usr/sbin" exists in PATH.
[20958] [21:56:11] Done setting up PATH.
[20958] [21:56:11] Located "readlink" within PATH (/bin/readlink).
[20958] [21:56:11] My location is "/usr/bin/modem3g/sakis3g".
[20958] [21:56:11] Located "wc" within PATH (/usr/bin/wc).
[20958] [21:56:12] Located "cat" within PATH (/bin/cat).
[20958] [21:56:12] Located "tail" within PATH (/usr/bin/tail).
[20958] [21:56:12] Located "head" within PATH (/usr/bin/head).
[20958] [21:56:12] Located "sort" within PATH (/usr/bin/sort).
[20958] [21:56:12] Located "uniq" within PATH (/usr/bin/uniq).
[20958] [21:56:12] Located "ls" within PATH (/bin/ls).
[20958] [21:56:12] Located "setsid" within PATH (/usr/bin/setsid).
[20958] [21:56:12] Located "getent" within PATH (/usr/bin/getent).
[20958] [21:56:12] Located "ps" within PATH (/bin/ps).
[20958] [21:56:12] Located "chmod" within PATH (/bin/chmod).
[20958] [21:56:12] Located "chown" within PATH (/bin/chown).
[20958] [21:56:12] Located "touch" within PATH (/bin/touch).
[20958] [21:56:12] Located "expr" within PATH (/usr/bin/expr).
[20958] [21:56:12] Located "seq" within PATH (/usr/bin/seq).
[20958] [21:56:12] Located "cp" within PATH (/bin/cp).
[20958] [21:56:12] Located "rm" within PATH (/bin/rm).
[20958] [21:56:12] Located "who" within PATH (/usr/bin/who).
[20958] [21:56:12] Located "mv" within PATH (/bin/mv).
[20958] [21:56:12] Located "basename" within PATH (/usr/bin/basename).
[20958] [21:56:12] Located "dirname" within PATH (/usr/bin/dirname).
[20958] [21:56:12] Level 2 dependencies met.
[20958] [21:56:12] Basic binaries are resolved.
[20958] [21:56:12] Parent process is: sudo
[20958] [21:56:12] Running by user request.
[20958] [21:56:12] Person behind screen is pi.
[20958] [21:56:12] Configuration file /etc/default/sakis3g does not exist or is not readable.
[20958] [21:56:12] Configuration file /etc/sysconfig/sakis3g does not exist or is not readable.
[20958] [21:56:12] Loading system-wide configuration file /etc/sakis3g.conf.
[20958] [21:56:12] Will now display contents of: \'/etc/sakis3g.conf\'
OTHER=CUSTOM_TTY
CUSTOM_TTY="/dev/ttyUSB0"
APN=CUSTOM_APN
CUSTOM_APN="mcinet"
APN_USER="a"
APN_PASS="a"
SIM_PIN="3436"
-rw-r--r-- 1 root root 119 Apr 30 21:39 /etc/sakis3g.conf
[20958] [21:56:12] Configuration arguments are: "OTHER=CUSTOM_TTY" "CUSTOM_TTY=/dev/ttyUSB0" "APN=CUSTOM_APN" "CUSTOM_APN=mcinet" "APN_USER=a" "APN_PASS=a" "SIM_PIN=3436"
[20958] [21:56:12] Parsing configuration value: OTHER=CUSTOM_TTY.
[20958] [21:56:12] Command line set variable OTHER to "CUSTOM_TTY".
[20958] [21:56:12] Parsing configuration value: CUSTOM_TTY=/dev/ttyUSB0.
[20958] [21:56:13] Command line set variable CUSTOM_TTY to "/dev/ttyUSB0".
[20958] [21:56:13] Parsing configuration value: APN=CUSTOM_APN.
[20958] [21:56:13] Command line set variable APN to "CUSTOM_APN".
[20958] [21:56:13] Parsing configuration value: CUSTOM_APN=mcinet.
[20958] [21:56:13] Command line set variable CUSTOM_APN to "mcinet".
[20958] [21:56:13] Parsing configuration value: APN_USER=a.
[20958] [21:56:13] Command line set variable APN_USER to "a".
[20958] [21:56:13] Parsing configuration value: APN_PASS=a.
[20958] [21:56:13] Command line set variable APN_PASS to "a".
[20958] [21:56:13] Parsing configuration value: SIM_PIN=3436.
[20958] [21:56:13] Command line set variable SIM_PIN to "3436".
[20958] [21:56:13] Finished loading file /etc/sakis3g.conf.
[20958] [21:56:13] Configuration file(s) loaded.
[20958] [21:56:13] Will attempt to get access to display :0.
[20958] [21:56:13] Located "xauth" within PATH (/usr/bin/xauth).
[20958] [21:56:13] Already granted access to display :0.
[20958] [21:56:13] Will be using display :0.
[20958] [21:56:13] Selecting GUI.
[20958] [21:56:13] Unable to locate "kdialog" within PATH.
[20958] [21:56:13] Located "zenity" within PATH (/usr/bin/zenity).
[20958] [21:56:13] zenity selected as GUI.
[20958] [21:56:13] Locale en_GB.UTF-8 found in environment.
[20958] [21:56:13] Will attempt to get translation file from package: messages/en_GB.UTF-8.
[20958] [21:56:13] Loaded default value for foldwrapping: 60
[20958] [21:56:13] No translations retrieved from file. Will not be using translations.
[20958] [21:56:13] Located "ifconfig" within PATH (/sbin/ifconfig).
[20958] [21:56:13] Root level dependencies met.
[20958] [21:56:13] Loading Usb-ModeSwitch device database.
[20958] [21:56:13] Embedded device database loaded.
[20958] [21:56:13] Switchable devices within embedded device database:
0421:0610 0471:1210 0471:1237 0482:024d 04e8:f000 057c:84ff 05c6:1000 05c6:2001 05c6:f000 072f:100d 0930:0d46 0ace:2011 0ace:20ff 0af0:6711 0af0:6731 0af0:6751 0af0:6771 0af0:6791 0af0:6811 0af0:6911 0af0:6951 0af0:6971 0af0:7011 0af0:7031 0af0:7051 0af0:7071 0af0:7111 0af0:7211 0af0:7251 0af0:7271 0af0:7301 0af0:7311 0af0:7361 0af0:7381 0af0:7401 0af0:7501 0af0:7601 0af0:7701 0af0:7801 0af0:7901 0af0:8200 0af0:8201 0af0:8300 0af0:8302 0af0:8304 0af0:8400 0af0:c031 0af0:c100 0af0:d013 0af0:d031 0af0:d033 0af0:d035 0af0:d055 0af0:d057 0af0:d058 0af0:d155 0af0:d157 0af0:d255 0af0:d257 0af0:d357 0b3c:c700 0fce:d0cf 0fce:d0e1 0fce:d103 1004:1000 1004:607f 1004:613a 1004:613f 1033:0035 106c:3b03 106c:3b06 1076:7f40 1199:0fff 1266:1000 12d1:1001 12d1:1003 12d1:101e 12d1:1414 12d1:1446 12d1:1520 12d1:1521 12d1:1557 1410:5010 1410:5020 1410:5030 1410:5031 1410:5041 148f:2578 16d8:6803 16d8:700a 16d8:f000 198f:bccd 19d2:0003 19d2:0026 19d2:0040 19d2:0053 19d2:0083 19d2:0101 19d2:0103 19d2:0115 19d2:1001 19d2:1007 19d2:1009 19d2:2000 19d2:fff5 19d2:fff6 1a8d:1000 1ab7:5700 1b7d:0700 1bbb:f000 1c9e:1001 1c9e:9200 1c9e:f000 1dd6:1000 1e0e:f000 1f28:0021 1fac:0130
[20958] [21:56:13] Switched devices within embedded device database:
0421:0612 0471:1206 0471:1234 04e8:6601 057c:8401 05c6:9000 072f:90cc 0930:0d45 0af0:6600 0af0:6701 0af0:6901 0b3c:c000 0b3c:c001 0b3c:c002 1004:6114 1004:6124 1004:6141 106c:3715 106c:3717 1076:7f00 1199:0017 1199:0018 1199:0019 1199:0020 1199:0021 1199:0022 1199:0024 1199:0026 1199:0027 1199:0028 1199:0029 1199:0112 1199:0120 1199:0218 1199:0220 1199:0224 1199:6802 1199:6803 1199:6804 1199:6805 1199:6808 1199:6809 1199:6812 1199:6813 1199:6815 1199:6816 1199:6820 1199:6821 1199:6822 1199:6832 1199:6833 1199:6834 1199:6835 1199:6838 1199:6839 1199:683a 1199:683b 1199:683c 1199:683d 1199:683e 1199:6850 1199:6851 1199:6852 1199:6853 1199:6855 1199:6856 1199:6859 1199:685a 1266:1002 1266:1003 1266:1004 1266:1005 1266:1006 1266:1007 1266:1008 1266:1009 1266:100a 1266:100b 1266:100c 1266:100d 1266:100e 1266:100f 1266:1011 1266:1012 12d1:1001 12d1:1003 12d1:1406 12d1:140c 12d1:141b 12d1:1464 12d1:1465 12d1:14a5 12d1:14ac 1410:4100 1410:4400 1410:6000 1410:6002 1410:7001 1410:7003 148f:9021 16d5:6502 16d8:6006 16d8:680a 198f:0220 19d2:0001 19d2:0002 19d2:0015 19d2:0016 19d2:0017 19d2:0022 19d2:0031 19d2:0037 19d2:0052 19d2:0055 19d2:0063 19d2:0064 19d2:0094 19d2:0104 19d2:0116 19d2:0124 19d2:0128 19d2:1003 19d2:1008 19d2:1010 19d2:fff1 19d2:ffff 1a8d:1002 1a8d:1009 1ab7:5731 1b7d:0001 1bbb:0000 1c9e:6061 1c9e:9000 1c9e:9063 1c9e:9202 1c9e:9603 1dbc:0005 1dd6:1002 1e0e:9000 1e0e:9200 1e0e:ce16 1e0e:cefe 1f28:0020 1fac:0131 1fe7:0100
[20958] [21:56:13] Embedded Usb-ModeSwitch device database contains 260 entries.
[20958] [21:56:13] Folder "/etc/usb_modeswitch.d" exists. Will check if it contains configuration files.
[20958] [21:56:13] Loading system supplied device database.
[20958] [21:56:14] Switchable devices within system device database:
[20958] [21:56:14] Switched devices within system device database:
[20958] [21:56:14] Finished starting up.
[20958] [21:56:14] Loaded default value for pppint: ppp0
[20958] [21:56:14] Verbosing: 7% Locating device
[20958] [21:56:14] Located "kill" within PATH (/bin/kill).
[20958] [21:56:14] Establishing zenity verbose helper.
[20958] [21:56:14] Will now run command: \'/bin/touch /tmp/sakis3g.zenity.pipe\'
[20958] [21:56:14] Command returned 0.
[20958] [21:56:14] Will now run command: \'/bin/chmod 666 /tmp/sakis3g.zenity.pipe\'
[20958] [21:56:14] PID 22151 is still running.
[20958] [21:56:14] Fetching connected USB devices by using "/sys/bus/usb/devices".
[20958] [21:56:14] Connected USB devices are:
0424:9514:BUSNUM=001
0424:ec00:BUSNUM=001
1a2c:0c21:USB Keyboard
1d6b:0002:DWC OTG Controller
2001:7d0e:D-Link DWM-157
214b:7000:USB2.0 HUB
2188:0ae1:USB OPTICAL MOUSE
** (zenity:22151): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
[20958] [21:56:14] No plugged modems found.
[20958] [21:56:14] Asking user to select: OTHER Please select modem type Select modem category that best fits your 3G modem. Select Cancel USBMODEM USB device BLUETOOTH Bluetooth modem CUSTOM_TTY Custom tty...
[20958] [21:56:14] OTHER=CUSTOM_TTY
[20958] [21:56:14] USBMODEM!=CUSTOM_TTY
[20958] [21:56:14] BLUETOOTH!=CUSTOM_TTY
[20958] [21:56:14] CUSTOM_TTY==CUSTOM_TTY.
[20958] [21:56:14] User has already selected OTHER="CUSTOM_TTY". Returning 3.
[20958] [21:56:14] Asking user to enter: CUSTOM_TTY Please enter tty Enter tty node where your 3G modem resides, or leave empty to abort OK Cancel
[20958] [21:56:14] CUSTOM_TTY=/dev/ttyUSB0
[20958] [21:56:14] User has already entered CUSTOM_TTY="/dev/ttyUSB0". Returning 0.
[20958] [21:56:14] Using device node "/dev/ttyUSB0".
[20958] [21:56:14] Setting up modem.
[20958] [21:56:14] We are root already. Proceeding.
[20958] [21:56:14] Setting up custom modem on /dev/ttyUSB0.
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged.
[20958] [21:56:14] Attempting to setup custom tty modem on "/dev/ttyUSB0".
[20958] [21:56:14] Custom tty "/dev/ttyUSB0" exists. Nothing more to do for setting it up.
[20958] [21:56:14] Modem is now setup and resides on /dev/ttyUSB0.
[20958] [21:56:14] Located "wvdial" within PATH (/usr/bin/wvdial).
[20958] [21:56:14] Located "pppd" within PATH (/usr/sbin/pppd).
[20958] [21:56:15] Loaded default value for PPPD_PEERS: /etc/ppp/peers
[20958] [21:56:15] Located "chat" within PATH (/usr/sbin/chat).
[20958] [21:56:15] Verbosing: 14% Preparing modem
[20958] [21:56:15] PID 22151 is still running.
[20958] [21:56:15] Loaded default value for CHAT_ABORT_STRINGS: ABORT BUSY ABORT ERROR ABORT BLOCKED ABORT NOCARRIER
[20958] [21:56:15] Unknown command "STAGE0".
[20958] [21:56:15] Command "PROBEGSM" refers to AT commands: ATI OK 'AT+GCAP' OK 'AT+CGSN' OK
[20958] [21:56:15] Will send PROBEGSM commands to tty /dev/ttyUSB0: "" '\pAT' OK ATI OK 'AT+GCAP' OK 'AT+CGSN' OK '\pAT' OK
[20958] [21:56:15] We are root already. Proceeding.
[20958] [21:56:15] Device /dev/ttyUSB0 is not busy.
[20958] [21:56:15] Got response from tty:
OK
MTK2
MOLY.WR8.W1244.DNR.WG.MP.V7
OK
+GCAP: +FCLASS, +CGSM
OK
355621056029709
OK
OK
[20958] [21:56:15] Found GSM capabilities on tty /dev/ttyUSB0.
[20958] [21:56:15] Command "IDENTIFY" refers to AT commands: AT+CGMM OK
[20958] [21:56:15] Will send IDENTIFY commands to tty /dev/ttyUSB0: "" '\pAT' OK AT+CGMM OK '\pAT' OK
OK
+CGMM: MTK2
OK
OK
[20958] [21:56:16] Modem on tty identified itself as: +CGMM: MTK2
[20958] [21:56:16] No information found for  within files/modem_init.db database.
[20958] [21:56:16] Unknown command "STAGE1".
[20958] [21:56:16] Using default PINCHECK.
[20958] [21:56:16] Command "PINCHECK" refers to AT commands: 'AT+CPIN?' OK
[20958] [21:56:16] Will send PINCHECK commands to tty /dev/ttyUSB0: "" '\pAT' OK 'AT+CPIN?' OK '\pAT' OK
[20958] [21:56:16] We are root already. Proceeding.
[20958] [21:56:16] Device /dev/ttyUSB0 is not busy.
[20958] [21:56:16] Got response from tty:
OK
+CPIN: READY
OK
OK
[20958] [21:56:16] Modem on /dev/ttyUSB0 does not need PIN.
[20958] [21:56:16] Unknown command "STAGE4".
[20958] [21:56:16] Command "OPERATOR" refers to AT commands: AT+COPS=3,2 OK 'AT+COPS?' OK
[20958] [21:56:16] Will send OPERATOR commands to tty /dev/ttyUSB0: "" '\pAT' OK AT+COPS=3,2 OK 'AT+COPS?' OK '\pAT' OK
[20958] [21:56:17] Got response from tty:
OK
OK
+COPS: 0
OK
OK
[20958] [21:56:17] Modem not registered to a network yet.
[20958] [21:56:17] Waiting modem to register network (4 seconds).
[20958] [21:56:17] Verbosing: 21% Registering network
[20958] [21:56:17] PID 22151 is still running.
[20958] [21:56:21] Command "OPERATOR" refers to AT commands: AT+COPS=3,2 OK 'AT+COPS?' OK
[20958] [21:56:21] Will send OPERATOR commands to tty /dev/ttyUSB0: "" '\pAT' OK AT+COPS=3,2 OK 'AT+COPS?' OK '\pAT' OK
[20958] [21:56:21] We are root already. Proceeding.
[20958] [21:56:21] Device /dev/ttyUSB0 is not busy.
[20958] [21:56:21] Got response from tty:
OK
OK
+COPS: 0
OK
OK
[20958] [21:56:21] Modem not registered to a network yet.
[20958] [21:56:21] Waiting modem to register network (8 seconds).
[20958] [21:56:21] Verbosing: 22% Registering network
[20958] [21:56:21] PID 22151 is still running.
[20958] [21:56:25] Command "OPERATOR" refers to AT commands: AT+COPS=3,2 OK 'AT+COPS?' OK
[20958] [21:56:25] Will send OPERATOR commands to tty /dev/ttyUSB0: "" '\pAT' OK AT+COPS=3,2 OK 'AT+COPS?' OK '\pAT' OK
[20958] [21:56:25] We are root already. Proceeding.
[20958] [21:56:26] Device /dev/ttyUSB0 is not busy.
[20958] [21:56:26] Got response from tty:
OK
OK
+COPS: 0
OK
OK
[20958] [21:56:26] Modem not registered to a network yet.
[20958] [21:56:26] Waiting modem to register network (12 seconds).
[20958] [21:56:26] Verbosing: 23% Registering network
[20958] [21:56:26] PID 22151 is still running.
[20958] [21:56:30] Command "OPERATOR" refers to AT commands: AT+COPS=3,2 OK 'AT+COPS?' OK
[20958] [21:56:30] Will send OPERATOR commands to tty /dev/ttyUSB0: "" '\pAT' OK AT+COPS=3,2 OK 'AT+COPS?' OK '\pAT' OK
[20958] [21:56:30] We are root already. Proceeding.
[20958] [21:56:30] Device /dev/ttyUSB0 is not busy.
[20958] [21:56:30] Got response from tty:
OK
OK
+COPS: 0
OK
OK
[20958] [21:56:30] Modem not registered to a network yet.
[20958] [21:56:30] Waiting modem to register network (16 seconds).
[20958] [21:56:31] Verbosing: 24% Registering network
[20958] [21:56:31] PID 22151 is still running.
[20958] [21:56:35] Command "OPERATOR" refers to AT commands: AT+COPS=3,2 OK 'AT+COPS?' OK
[20958] [21:56:35] Will send OPERATOR commands to tty /dev/ttyUSB0: "" '\pAT' OK AT+COPS=3,2 OK 'AT+COPS?' OK '\pAT' OK
[20958] [21:56:35] We are root already. Proceeding.
[20958] [21:56:35] Device /dev/ttyUSB0 is not busy.
[20958] [21:56:35] Got response from tty:
OK
OK
+COPS: 0
OK
OK
[20958] [21:56:35] Modem not registered to a network yet.
[20958] [21:56:35] Waiting modem to register network (20 seconds).
[20958] [21:56:35] Verbosing: 25% Registering network
[20958] [21:56:35] PID 22151 is still running.
[20958] [21:56:39] Command "OPERATOR" refers to AT commands: AT+COPS=3,2 OK 'AT+COPS?' OK
[20958] [21:56:39] Will send OPERATOR commands to tty /dev/ttyUSB0: "" '\pAT' OK AT+COPS=3,2 OK 'AT+COPS?' OK '\pAT' OK
[20958] [21:56:39] We are root already. Proceeding.
[20958] [21:56:39] Device /dev/ttyUSB0 is not busy.
[20958] [21:56:40] Got response from tty:
OK
OK
+COPS: 0
OK
OK
[20958] [21:56:40] Modem not registered to a network yet.
[20958] [21:56:40] Waiting modem to register network (24 seconds).
[20958] [21:56:40] Verbosing: 26% Registering network
[20958] [21:56:40] PID 22151 is still running.
[20958] [21:56:44] Command "OPERATOR" refers to AT commands: AT+COPS=3,2 OK 'AT+COPS?' OK
[20958] [21:56:44] Will send OPERATOR commands to tty /dev/ttyUSB0: "" '\pAT' OK AT+COPS=3,2 OK 'AT+COPS?' OK '\pAT' OK
[20958] [21:56:44] We are root already. Proceeding.
[20958] [21:56:44] Device /dev/ttyUSB0 is not busy.
[20958] [21:56:44] Got response from tty:
OK
OK
+COPS: 0
OK
OK
[20958] [21:56:44] Modem not registered to a network yet.
[20958] [21:56:44] Giving up after 24 seconds have passed.
[20958] [21:56:44] Error: Modem unable to register a network.
[20958] [21:56:44] Will now run command: \'/bin/rm -f /tmp/sakis3g.zenity.pipe\'
[20958] [21:56:44] Command returned 0.
[20958] [21:56:45] PID 22151 is not running any more.
** (zenity:23125): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
[20958] [21:59:23] Asking user to confirm: scan Scan for network Modem was unable to register a network. Would you like to manually select a network? Yes No reset
[20958] [21:59:23] Prompting user to select yesscan or noscan.
[20958] [21:59:24] User selected "no" (1).
[20958] [21:59:24] User answered "no".
[20958] [21:59:24] Error: Failed to connect.
** (zenity:23207): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
[20958] [21:59:26] Aborting execution chain due to actor "connect" returning 13.
[20958] [21:59:26] Following actors executed: connect
[20958] [21:59:26] Verbosing: 33% Cleaning
[20958] [21:59:26] Establishing zenity verbose helper.
[20958] [21:59:26] Will now run command: \'/bin/touch /tmp/sakis3g.zenity.pipe\'
[20958] [21:59:26] Command returned 0.
[20958] [21:59:26] Will now run command: \'/bin/chmod 666 /tmp/sakis3g.zenity.pipe\'
[20958] [21:59:26] PID 23301 is still running.
[20958] [21:59:26] Stopping operation with return status: 13
[20958] [21:59:26] Now executing traps.
[20958] [21:59:26] Executing trap "cleanscreen".
[20958] [21:59:26] Will now run command: \'/bin/rm -f /tmp/sakis3g.zenity.pipe\'
[20958] [21:59:27] PID 23301 is still running.
studiozero
Fri Jun 15, 2018 8:31 pm
I had the same "invalid dial command" error using D-Link DWM-157 USB modem. The original post here is >1yr old, but this question appears unanswered on many forums, so here's an attempt to get some helpful info out there.
The cure for me was to add an extra initialization command:
AT+CFUN=1,0
Google CFUN to learn more.
Here's my complete wvdial.conf, using a Vodafone simcard in Germany. (sim pin disabled)
Init1 = ATZ
Init3 = AT+CGDCONT=1,"IP","web.vodafone.de"
Init4 = AT+CFUN=1,0
Baud = 9600
New PPPD = yes
ISDN = 0
Phone = *99#
Password = vf
Username = vf
FWIW, my usb-modeswitch file which seems to work, but I cannot remember how I got it, is /etc/usb_modeswitch.d/2001\:a407 as follows:
D-Link DWM-156 HSUPA 3.75G USB Modem
TargetVendor=0x2001
TargetProduct=0xa407
MessageContent="555342431234567800000000000003f0010100000000000000000000000000"
My complete startup procedure:
umount /media/pi/D-Link*
usb_modeswitch -v2001 -pa407 -c /etc/usb_modeswitch.d/2001:a407
wvdial
I didn't use sakis3g at all, as it seems to be a defunct project. usb-modeswitch and wvdial was all I needed.
Cheers!
