engineer_m
RPI 2 is not accessible after a week
Thu Apr 13, 2017 6:28 am
I have a RPI2 that acts as a web server and contains a web application for heating control. Everything was working fine about 6 months. Now, the RPI2 can't be accessed through ssh client or ftp server. Also, when I enter the URL of the web application it cant be accessed , I can only access the www folder of the web server ( The IT WORKS page ). When i plug off the RPI2 from power, and plug it in again, everything works for about a week ( i can access the web app, ssh is accessible, ftp is accessible). After a week passes the RPI2 gets stuck again. It seem that after a week of runtime i am losing permissions? Any thoughts?
kingosticks
Re: RPI 2 is not accessible after a week
Thu Apr 13, 2017 6:34 pm
Can you still access it using the ip address? Are you running a firewall on the pi, such as iptables? If the answer is yes to both those questions then check you have opened ports 67 and 68 to allow dhcp renewals.
engineer_m
Fri Apr 14, 2017 6:38 am
But i have a STATIC IP ADDRESS. I have not installed any additional firewall on the Pi. And yes, i can still access the www folder of the apache web server (the IT WORKS folder) via url. I cannot access applications in www folder though. Please explain more?
kingosticks
Fri Apr 14, 2017 7:58 am
Then it's a different problem. Sorry, I don't know.
Reinier de Waard
Tue Apr 18, 2017 10:26 am
First sorry for my English I live in the Netherlands. Maybe it will work fine after a restart of the apache server.
Reinier de Waard
Tue Apr 18, 2017 10:27 am
Otherwise reinstalling the apache can work too.
Last edited by Reinier de Waard on Tue Apr 18, 2017 4:25 pm, edited 1 time in total.
Tue Apr 18, 2017 10:37 am
Any relevant messages in 'dmesg'?
engineer_m
Wed Apr 19, 2017 3:46 pm
this is what i get in dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.19-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #858 SMP Tue Mar 15 15:56:00 GMT 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x3a400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80880fc0, node_mem_map b9bb4000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 12 pages/cpu @bafb1000 s20416 r8192 d20544 u49152
[ 0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x98613437 smsc95xx.macaddr=B8:27:EB:61:34:37 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939380K/966656K available (6064K kernel code, 534K rwdata, 1664K rodata, 444K init, 757K bss, 19084K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x807945f0 (7730 kB)
[ 0.000000] .init : 0x80795000 - 0x80804000 ( 444 kB)
[ 0.000000] .data : 0x80804000 - 0x80889b10 ( 535 kB)
[ 0.000000] .bss : 0x8088c000 - 0x809497dc ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000032] Switching to timer-based delay loop, resolution 52ns
[ 0.000311] Console: colour dummy device 80x30
[ 0.001489] console [tty1] enabled
[ 0.001547] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001624] pid_max: default: 32768 minimum: 301
[ 0.002012] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002064] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003345] Initializing cgroup subsys blkio
[ 0.003413] Initializing cgroup subsys memory
[ 0.003471] Initializing cgroup subsys devices
[ 0.003522] Initializing cgroup subsys freezer
[ 0.003590] Initializing cgroup subsys net_cls
[ 0.003696] CPU: Testing write buffer coherency: ok
[ 0.003807] ftrace: allocating 20313 entries in 60 pages
[ 0.052880] CPU0: update cpu_capacity 1024
[ 0.052956] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.052995] [bcm2709_smp_prepare_cpus] enter
[ 0.053152] Setting up static identity map for 0x8240 - 0x8274
[ 0.055665] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.056105] [bcm2709_secondary_init] enter cpu:1
[ 0.056163] CPU1: update cpu_capacity 1024
[ 0.056173] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.056762] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.057118] [bcm2709_secondary_init] enter cpu:2
[ 0.057151] CPU2: update cpu_capacity 1024
[ 0.057160] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.057706] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.057963] [bcm2709_secondary_init] enter cpu:3
[ 0.057992] CPU3: update cpu_capacity 1024
[ 0.058000] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.058091] Brought up 4 CPUs
[ 0.058202] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.058235] CPU: All CPU(s) started in HYP mode.
[ 0.058265] CPU: Virtualization extensions available.
[ 0.059281] devtmpfs: initialized
[ 0.082862] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.083216] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.084433] pinctrl core: initialized pinctrl subsystem
[ 0.085252] NET: Registered protocol family 16
[ 0.090873] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.092007] bcm2709.uart_clock = 3000000
[ 0.097390] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.097452] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.097674] Serial: AMBA PL011 UART driver
[ 0.097877] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.098499] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.174176] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 0.174268] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 0.175020] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.175063] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.175816] SCSI subsystem initialized
[ 0.176081] usbcore: registered new interface driver usbfs
[ 0.176227] usbcore: registered new interface driver hub
[ 0.176416] usbcore: registered new device driver usb
[ 0.177153] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-15 14:47
[ 0.204469] Switched to clocksource arch_sys_counter
[ 0.253340] FS-Cache: Loaded
[ 0.253761] CacheFiles: Loaded
[ 0.266880] NET: Registered protocol family 2
[ 0.268269] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.268443] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.268661] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.268807] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.268896] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.269400] NET: Registered protocol family 1
[ 0.269899] RPC: Registered named UNIX socket transport module.
[ 0.269941] RPC: Registered udp transport module.
[ 0.269973] RPC: Registered tcp transport module.
[ 0.270004] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.271071] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.272526] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.288925] VFS: Disk quotas dquot_6.6.0
[ 0.289339] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.291841] FS-Cache: Netfs 'nfs' registered for caching
[ 0.293048] NFS: Registering the id_resolver key type
[ 0.293149] Key type id_resolver registered
[ 0.293183] Key type id_legacy registered
[ 0.296169] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.296439] io scheduler noop registered
[ 0.296489] io scheduler deadline registered (default)
[ 0.296837] io scheduler cfq registered
[ 0.299458] BCM2708FB: allocated DMA memory fa800000
[ 0.299526] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.305225] Console: switching to colour frame buffer device 82x26
[ 0.310444] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 0.313333] vc-cma: Videocore CMA driver
[ 0.315057] vc-cma: vc_cma_base = 0x00000000
[ 0.316720] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.318320] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.320113] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.339100] brd: module loaded
[ 0.349595] loop: module loaded
[ 0.352038] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
[ 0.355307] Loading iSCSI transport class v2.0-870.
[ 0.357771] usbcore: registered new interface driver smsc95xx
[ 0.359399] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.561296] Core Release: 2.80a
[ 0.562758] Setting default values for core params
[ 0.564256] Finished setting default values for core params
[ 0.766239] Using Buffer DMA mode
[ 0.767746] Periodic Transfer Interrupt Enhancement - disabled
[ 0.769293] Multiprocessor Interrupt Enhancement - disabled
[ 0.770875] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.772432] Dedicated Tx FIFOs mode
[ 0.774337] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
[ 0.777546] FIQ FSM acceleration enabled for :
[ 0.777546] Non-periodic Split Transactions
[ 0.777546] Periodic Split Transactions
[ 0.777546] High-Speed Isochronous Endpoints
[ 0.783981] dwc_otg: Microframe scheduler enabled
[ 0.784051] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80417288
[ 0.785678] WARN::hcd_init_fiq:413: FIQ ASM at 0x804175f8 length 36
[ 0.787319] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89a000
[ 0.788973] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.790577] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.792210] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 0.793823] Init: Port Power? op_state=1
[ 0.795384] Init: Power Port (0)
[ 0.797151] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.798738] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.800309] usb usb1: Product: DWC OTG Controller
[ 0.801850] usb usb1: Manufacturer: Linux 4.1.19-v7+ dwc_otg_hcd
[ 0.803401] usb usb1: SerialNumber: 3f980000.usb
[ 0.805822] hub 1-0:1.0: USB hub found
[ 0.807397] hub 1-0:1.0: 1 port detected
[ 0.809332] dwc_otg: FIQ enabled
[ 0.809345] dwc_otg: NAK holdoff enabled
[ 0.809355] dwc_otg: FIQ split-transaction FSM enabled
[ 0.809397] Module dwc_common_port init
[ 0.809801] usbcore: registered new interface driver usb-storage
[ 0.811517] mousedev: PS/2 mouse device common for all mice
[ 0.813807] bcm2835-cpufreq: min=600000 max=900000
[ 0.815648] sdhci: Secure Digital Host Controller Interface driver
[ 0.817169] sdhci: Copyright(c) Pierre Ossman
[ 0.818996] sdhost: log_buf @ ba813000 (fa813000)
[ 0.894558] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.916681] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.918869] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.920673] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.922579] usbcore: registered new interface driver usbhid
[ 0.924142] usbhid: USB HID core driver
[ 0.926232] Initializing XFRM netlink socket
[ 0.927827] NET: Registered protocol family 17
[ 0.929498] Key type dns_resolver registered
[ 0.931376] Registering SWP/SWPB emulation handler
[ 0.933783] registered taskstats version 1
[ 0.935576] vc-sm: Videocore shared memory driver
[ 0.937060] [vc_sm_connected_init]: start
[ 0.939223] [vc_sm_connected_init]: end - returning 0
[ 0.942297] Waiting for root device /dev/mmcblk0p2...
[ 0.952974] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.959171] mmc0: new high speed SDHC card at address 0007
[ 0.961350] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[ 0.964070] mmcblk0: p1 p2
[ 0.965967] mmcblk0: p2 size 30269440 extends beyond EOD, truncated
[ 1.024620] Indeed it is in host mode hprt0 = 00021501
[ 1.057289] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.060491] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.063198] devtmpfs: mounted
[ 1.065632] Freeing unused kernel memory: 444K (80795000 - 80804000)
[ 1.204540] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.206576] Indeed it is in host mode hprt0 = 00001101
[ 1.404947] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.404960] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.405872] hub 1-1:1.0: USB hub found
[ 1.406014] hub 1-1:1.0: 5 ports detected
[ 1.684568] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.785008] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.787174] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.792586] smsc95xx v1.0.4
[ 1.858974] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:61:34:37
[ 2.127944] udevd[174]: starting version 175
[ 3.658478] bcm2835-rng 3f104000.rng: hwrng registered
[ 3.662886] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 5.116292] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.341576] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 9.231239] random: dd urandom read with 79 bits of entropy available
[ 10.397832] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 11.823556] cfg80211: Calling CRDA to update world regulatory domain
[ 11.961860] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
[ 13.895283] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2134012k SSFS
[ 14.974514] cfg80211: Calling CRDA to update world regulatory domain
[ 16.588897] uart-pl011 3f201000.uart: no DMA platform data
[ 17.336889] random: nonblocking pool is initialized
[ 18.134681] cfg80211: Calling CRDA to update world regulatory domain
[ 21.294553] cfg80211: Calling CRDA to update world regulatory domain
[ 24.454516] cfg80211: Calling CRDA to update world regulatory domain
[ 27.614563] cfg80211: Calling CRDA to update world regulatory domain
[ 30.774569] cfg80211: Calling CRDA to update world regulatory domain
[ 33.934554] cfg80211: Calling CRDA to update world regulatory domain
[ 37.094572] cfg80211: Calling CRDA to update world regulatory domain
[ 40.254626] cfg80211: Calling CRDA to update world regulatory domain
[ 43.414591] cfg80211: Calling CRDA to update world regulatory domain
[ 46.574559] cfg80211: Exceeded CRDA call max attempts. Not calling CRDA
drgeoff
Wed Apr 19, 2017 5:25 pm
Memory leak now in some updated program that wasn't leaking in previous version?
kingosticks
Wed Apr 19, 2017 5:46 pm
Is that dmesg output from when it's still working?
When you say the "IT WORKS" page is still accessible have you done a *full* page refresh in your web browser to make sure you are not seeing a cached version? Whatever is preventing your ssh connection would almost certainly stop an actual web server connection.
Can you ping it after a week?
Can you connect a keyboard and monitor to it?
engineer_m
Wed Apr 19, 2017 8:43 pm
well, since the last freeze in thursday, i have updated with sudo apt-get update and sudo apt-get upgrade. The kernel was previously v3.x. Now it is 4.1.x. Now i am waiting for another freeze. The interesting thing with the SSH when the rpi freezes is that I am able to get initial connection and it asks for my password. If I put a wrong password it behaves like it should and the access is the denied, the reason is of course the wrong password. If I put in the correct password, it just hangs...
engineer_m
Wed Apr 19, 2017 8:48 pm
kingosticks wrote:Is that dmesg output from when it's still working?
Yes, this dmesg is from today. As till today, it has worked for six days without freezing but as I said the problem occurs on weekly basis, so anytime now it might freeze.... I haven't been able to try with a keyboard, as the rpi physical location is in a customer's house in another city. He is getting very annoyed as this problem keeps repeating itself. And before this weird problem it has worked for 6 months without a flaw. Could this be related to sd card corruption?
