PjV
xfreerdp command line and settings file combination
Wed Feb 22, 2017 3:11 pm
I can't find the related topic anymore, but somebody had the same issue as I had.
When you use xfreerdp, and point to an rdp file *and* supply additional command line parameters, it doesn't work as it should.
I found that the parameter after the filename is skipped.
As workaround I now supply a . as 2nd parameter:
xfreerdp /home/pi/fullscreen.rdp . +clipboard /drive:Files,/media/pi/SHAREDFILES -wallpaper /v:somehost
And the xfreerdp version: This is FreeRDP version 1.1.0-beta1 (git n/a)
Re: xfreerdp command line and settings file combination
Thu Feb 23, 2017 6:41 am
Forget using XRDP, freerdp or any RDP. Use RealVNC the results are going to be better in all cases.
PjV
Thu Feb 23, 2017 7:22 am
DougieLawson wrote:Forget using XRDP, freerdp or any RDP. Use RealVNC the results are going to be better in all cases.
Not everything is a nail.
