I can't find the related topic anymore, but somebody had the same issue as I had.
When you use xfreerdp, and point to an rdp file *and* supply additional command line parameters, it doesn't work as it should.
I found that the parameter after the filename is skipped.
As workaround I now supply a . as 2nd parameter:
xfreerdp /home/pi/fullscreen.rdp . +clipboard /drive:Files,/media/pi/SHAREDFILES -wallpaper /v:somehost
