Jokn
RasPi Wifi AP/ TFTP / Ser2Net
Tue Sep 11, 2012 1:40 am
My first project with my shiny new Raspberry Pi was to create a tool to make my job easier. I'm a network technician for a large ISP. Often times I run into equipment that has been installed in difficult to access or non-ideal conditions (outdoor cell tower cabinets). Standing around with a cable connected to my laptop isn't always the easiest or most fun to do. When equipment fails and needs to be replaced and reconfigured, I'd much rather have a wireless way to connect and sit in my truck or a more comfortable/safer spot. Summers here reach 43C and Winters get below freezing at times, especially in the middle of the night when network maintenance is done.
Hardware I used:
Raspberry Pi
Prolific PL2303 USB to Serial adapter
Ralink RT5370 Wifi Adapter
Both USB devices were supported right out of the box. I didn't have to install any specific drivers.
First thing I did was remove the GUI from the Wheezy install and get rid of some packages I didn't need. This step isn't necessary, but I'm kind of OCD about what's installed on my linux machines. The following thread has some useful information: http://www.raspberrypi.org/phpBB3/viewt ... 5&p=126875
Next, I turned the RasPi into a wifi AP using this guide: http://sirlagz.net/?p=589
Once the WiFi AP was up and working, I installed ser2net and configured it for the different console settings I needed based on the devices. Some of the devices I work on don't use the default 9600 baud rate. I used the following guide and adapted it to my needs: http://mellowd.co.uk/ccie/?tag=ser2net
The last step was to get my tftp server setup on the LAN port. I set a static IP on eth0 and copied various files into my tftpboot directory (Cisco IOS and other router files). I used the following guide to setup the tftp. http://www.davidsudjiman.info/2006/03/2 ... in-ubuntu/
Next on my todo list is to find a good solution for a battery pack. There's usually always an AC outlet wherever I'm working, but I'd rather have a battery powered device to cut down on wiring, or for when there is no AC outlet. I'd like to connect a couple cables and then go find a comfortable spot to sit.
MmmPi
Re: RasPi Wifi AP/ TFTP / Ser2Net
Tue Sep 11, 2012 7:55 pm
Nice use. Run into any problems with your setup?
RasPi hooked to a cell tower would make a nice picture for a Roaming RasPi series.
Jokn
Thu Sep 13, 2012 4:43 am
MmmPi wrote:Nice use. Run into any problems with your setup?
So far everything has been working great. It boots up quickly and the TFTP worked to rescue one of my personal routers when I accidentally erased the flash trying to test the TFTP. I'm not sure what a "Roaming RasPi series" is? Here's a picture of my initial tests though.
http://i.imgur.com/vsiEM.jpg
duaneo
Sat Dec 22, 2012 7:22 pm
Has anyone looked into a bluetooth option for when people get up set with you fire up a wifi access point?
--Duaneo
rtroman
Thu May 02, 2013 12:45 pm
hi, i got mine to auto detect when connecting to cisco consoles, by using udev. basiclly get it to see the serial via udev, then run+= a script to start minicom (see udev documentation). I found you had to use a script to call a script to start minicom ? no idea why, and i used screen to "detach" the process from the tty in case i get dissconnected. I also run a script in minicom, to send returns so it loggs in etc. You can capture the output to a file too if that helps.
