lightnin
The glory of static html blogs on pi
Thu Sep 06, 2012 1:28 am
Greetings! After spending a lot of time looking into hosting my own site on the pi, I came across the glory and simplicity of static html blog generators (Pelican, in my case). No need for a database, or any other CPU hogging services. Just an http server and some html to serve is all you need.
Here's an instructable I made that sums it all up:
http://www.instructables.com/id/Host-yo ... i-compute/
Bioshox
Re: The glory of static html blogs on pi
Thu Sep 06, 2012 9:13 am
Wordpress runs just fine, especially with a caching service
Owner of: http://www.fusionstrike.com - I make gorgeous Raspberry Pi Tutorials :)
ndrs
Thu Sep 06, 2012 10:42 am
You should manage to do an "APC-Powered" PHP web. It works really well, at least in mine.
Currently i also have a web server with html coding only. For this purpose it's simply perfect, without loading times (almost).
If you are looking for an html-only web (html/css of course), the Raspberry is an awesome option, no doubt.
Ryatzu
Thu Sep 06, 2012 1:04 pm
Well my problem is dat APC doesn't work with php 5.4 and FastCGI.
You should look at fuelphp. It uses APC caching if you use the caching from the framework.
