Excluding the kernel it is only 5 MB compressed.
It contains:
- Lighttpd
- PHP 5.3.16
- SQLite
- SSH for file transfers
- Supporting applications and libraries (busybox, libcurl, libxml, libjpeg, libpng, etc.)
date
ereg
libxml
openssl
pcre
zlib
ctype
curl
dom
gd
hash
json
SPL
PDO
pdo_sqlite
Reflection
session
SimpleXML
soap
sockets
SQLite
standard
tokenizer
xml
xmlreader
xmlwriter
zip
To install:
- Install Berryboot first.
- In the "add operating system" window, scroll down to the bottom, select "Berrywebserver" (am open to a better name) and press "ok"
- Press "exit" to exit berryboot.
- Upon starting the first time, you will need to enter the password you would like to use twice.
You can then transfer the files of the website you would like to host from your normal computer to the Pi using a file transfer program like FileZilla.
Make sure you set the protocol to "SFTP"
