mad-hatter
Auto startup tightvncserver?
Sun Aug 26, 2012 11:40 am
2012-08-16-wheezy-raspbian
I've got tightvnc server/viewer running between the pi and my windows machine.
I log in via PuTTY, how can I get vncserver to autorun when I log in to the pi?
pi@mypi ~ $ vncserver :1 -geometry 1265x930 -name Win7 -depth 16 -pixelformat rgb565
New 'Win7' desktop is mypi:1
Starting applications specified in /home/pi/.vnc/xstartup
Log file is /home/pi/.vnc/mypi:1.log
pi@mypi ~ $
file contents: /home/pi/.vnc/xstartup
#!/bin/sh
xrdb $HOME/.Xresources
xsetroot -solid grey
#x-terminal-emulator -geometry 80x24+10+10 -ls -title "$VNCDESKTOP Desktop" &
#x-window-manager &
# Fix to make GNOME work
export XKL_XMODMAP_DISABLE=1
hiveda
Re: Auto startup tightvncserver?
Sun Aug 26, 2012 12:17 pm
You can find the instructions to set this up on http://elinux.org/RPi_VNC_Server
We've changed the vncboot-script to this:
USER=root
HOME=/root
export USER HOME
case "$1" in
  start)
        echo "Starting TightVNC"
        #/usr/bin/vncserver :1 -geometry 1280x800 -depth 16 -pixelformat rgb565
        sudo mkdir -p /tmp/.X11-unix
        sudo chmod 1777 /tmp/.X11-unix
        sudo chown root:root /tmp/.X11-unix
        su pi -c '/usr/bin/vncserver'
  stop)
        echo "TightVNC not stopped yet, TODO"
        echo "Usage: /etc/init.d/vncboot {start|stop}"
        exit 1
esac
exit 0
The x11-instructions were needed to prevent error-messages after startx
mad-hatter
Sun Aug 26, 2012 12:56 pm
Thanks for the info.
Regards
