nautilus27
Using Pi 3's bluetooth to send/receive data to smartphone
Fri Jul 22, 2016 6:42 am
I want to connect my Android smartphone to Raspberry Pi 3 via bluetooth and receive gyroscope information to the Pi.
Is it possible to use RPi's internal bluetooth for that? I have HC-05 bluetooth module as well but i'd really like to make use of RPi's features.
nautilus27
Re: Using Pi 3's bluetooth to send/receive data to smartphon
Fri Jul 29, 2016 2:30 pm
I've been trying to find a solution to this on my own since there wasn't any response from the forum. Here's my progess so far:
I made an app using MIT AppInventor2.
It connects a bluetooth connection and then sends gyroscope sensor data (X,Y,Z.) via bluetooth.
I used advices from this thread to make an RFCOMM connection and make it autostart at login: viewtopic.php?p=919420#p919420
My phone connects to Raspberry Pi 3 successfully but I don't know how to read the data and do stuff accordingly. Is there any library I can use in python that lets me read this BT channel?
I need to be able to seperate this data into X, Y and Z values. There are commas after each value and a dot in the end.
Douglas6
Fri Jul 29, 2016 2:39 pm
An RFCOMM channel acts exactly like a serial communications port. So any library that can do serial communication (like PySerial) can be used to read and write to the /dev/rfcomm0 device.
nautilus27
Fri Jul 29, 2016 2:47 pm
Douglas6 wrote:An RFCOMM channel acts exactly like a serial communications port. So any library that can do serial communication (like PySerial) can be used to read and write to the /dev/rfcomm0 device.
Sounds great. Is there any tutorial on PySerial for starters that you suggest?
nautilus27
Fri Jul 29, 2016 3:06 pm
import serial
ser = serial.Serial("/dev/rfcomm0", baudrate=9600, timeout=0.5)
while 1:
    print ser.readline(),
OK, this should've helped me but I get zero response from Raspberry Pi. Perhaps my baudrate is not correct?
Douglas6
Fri Jul 29, 2016 3:07 pm
Docs are here: https://pythonhosted.org/pyserial/. Use Google to find any number of examples.
Douglas6
Fri Jul 29, 2016 3:10 pm
nautilus27 wrote:OK, this should've helped me but I get zero response from Raspberry Pi. Perhaps my baudrate is not correct?
Is the data you are sending terminated with newline (\n) characters?
nautilus27
Fri Jul 29, 2016 3:15 pm
No. Does it have to be?
Douglas6
Fri Jul 29, 2016 3:24 pm
The default readline command will block (wait), filling the buffer until it receives a newline (or the timeout occurs) .
