VPN Server Tutorial
Posted: Tue Aug 14, 2012 6:05 pm
by 5m0k3
There has been a fair amount of interest in using a Raspberry Pi as a VPN Server, but until now there has been no clear step-by-step guide for setting one up. I've finally decided to create such a guide. The tutorial also addresses setting up a dynamic DNS service on your Raspberry Pi. Hopefully you find it useful. If you have any questions, please let me know.
http://wellsb.com/post/29412820494/rasp ... vpn-server
Re: VPN Server Tutorial
Posted: Thu Aug 30, 2012 10:21 pm
by scottcjordan
Two ways documented on my blog: http://unvexed.blogspot.com/2012/08/how ... d-vpn.html and http://unvexed.blogspot.com/2012/08/how ... e-web.html (PPTP and SSH-based, respectively)
Posted: Fri Aug 31, 2012 2:20 pm
by hbarnwheeler
From my understanding, L2TP over IPsec is much more secure than PPTP (see http://en.wikipedia.org/wiki/Layer_2_Tunneling_Protocol). Is there some reason you didn't go this route?
I will be receiving my Raspberry Pi soon and plan to use L2TP, if possible. I found the following tutorials which I hope will work.
http://wiki.debian.org/HowTo/iPhoneVPNServer
http://blog.bertelsen.co/2012/02/debian ... erver.html
Posted: Mon Sep 03, 2012 4:49 am
by errorcode
A PPTP VPN relies on the MS-CHAPv2. MS-CHAPv2 was recently proven to be insecure and can easily be cracked utilizing cloudcracker. Here is a link:
https://www.cloudcracker.com/blog/2012/ ... s-chap-v2/
Posted: Mon Sep 03, 2012 4:27 pm
by errorcode
hbarnwheeler wrote:From my understanding, L2TP over IPsec is much more secure than PPTP (see http://en.wikipedia.org/wiki/Layer_2_Tunneling_Protocol). Is there some reason you didn't go this route?
Actually, IPsec is just as easy to crack as PPTP. OpenVPN should be utilized if possible.
Posted: Mon Sep 03, 2012 5:48 pm
by Jungle-Boogie
errorcode wrote: Actually, IPsec is just as easy to crack as PPTP. OpenVPN should be utilized if possible.
Agreed. Please make a tutorial on using openVPN.
Posted: Mon Sep 03, 2012 11:13 pm
by 5m0k3
The source acknowledges this fact. When I have time, I'll work on an OpenVPN solution.
Keep in mind, PPTP is inherently less secure than an OpenVPN protocol solution. However, it’s much easier to set up on a Raspberry Pi :)
Posted: Wed Sep 05, 2012 12:08 am
by 65coupei6
OpenVPN on the RPI
This is not mine. I just found it and have not tried it yet.
http://sandeepmore.com/blog/2012/08/21/ ... tatic-key/
Posted: Tue Apr 02, 2013 10:51 am
by Piminiuser
65coupei6 wrote:OpenVPN on the RPI
This one will 100% work :) http://raspberrypihelp.net/tutorials/1- ... r-tutorial
Posted: Tue Apr 02, 2013 5:26 pm
by Liquidant
I used this tutorial and I'm happy to say it works great. I can connect to the VPN and access my samba shares on my iphone and stream my movies just how I wanted.
Only problem I've found was this.
At my friends house I connected to his wireless then connected to my VPN so I could show him the streaming of the movies.
This worked great
I proceeded to create a VPN log in for my friend as well as adding him as a user on my RPi and on samba.
when I checked I noticed that the VPN was giving us both the same ip address 192.168.0.235
thus stopping my friend from logging into the RPi with his username and password.
I confirmed this by disconnecting from the VPN and logging my friend in on his iphone.
I have set remote ip to be between 230 - 245 in the pptpd.conf
Any one know why it would connect us to the same ip
Posted: Wed Apr 03, 2013 7:55 pm
by Piminiuser
Liquidant wrote:I used this tutorial and I'm happy to say it works great. I can connect to the VPN and access my samba shares on my iphone and stream my movies just how I wanted.
This worked great
The only thing you did was adding 1 extra username + password in the /etc/ppp/chap-secrets file?
Posted: Fri Apr 05, 2013 5:25 pm
by Liquidant
no got 3 users in the chap-secrets file.
I seem to have fixed it.
I edited the /etc/pptpd.conf file
and instead of setting
localip and remoteip
I just uncommented remoteip and gave it a range from 192.168.0200 to 245
now when I get more than 1 device connecting it issues the ip correctly.
I think this is to do with the arpproxy but I could be wrong. Either way it seems to be working ok now.
Posted: Sun Feb 09, 2014 3:06 pm
by jurmelius
Posted: Sun Feb 09, 2014 4:32 pm
by DougieLawson
