stulevine
Raspberry Pi 3 and wlan0 no longer showing up
Sat Mar 19, 2016 10:03 pm
Ok, so I got my RPi3 a few days ago. The first disappointing issue was that none of my existing RPi2 SD cards would boot. I even upgraded one from Wheezy to Jessie, but no dice. And, as if that wasn't bad enough, I just did an aptitude upgrade and now the on-board wifi interfaceis not showing up. I saw that there was an update to BCM80211 drivers, thought nothing of it until I powered off and then powered on and ifconfig only shows lo and eth0 interfaces. wlan0 is no where to be found, even via iwconfig. Wifi and the wlan0 adapter all showed up and worked fine before today's upgrade. Any insights on how to fix this would be helpful. I see the modules being loaded via lsmod
> lsmod
Module                  Size  Used by
bnep                   10336  2
hci_uart               13533  1
btbcm                   4196  1 hci_uart
bluetooth             317981  7 bnep,btbcm,hci_uart
binfmt_misc             6236  1
brcmfmac              177635  0
brcmutil                5501  1 brcmfmac
cfg80211              407580  1 brcmfmac
rfkill                 16036  3 cfg80211,bluetooth
snd_bcm2835            19802  0
bcm2835_gpiomem         2860  0
snd_pcm                73474  1 snd_bcm2835
snd_timer              18848  1 snd_pcm
i2c_bcm2708             4920  0
bcm2835_rng             1763  0
spi_bcm2835             7074  0
snd                    50779  3 snd_bcm2835,snd_timer,snd_pcm
uio_pdrv_genirq         2944  0
uio                     7753  1 uio_pdrv_genirq
i2c_dev                 5671  0
fuse                   80694  1
ipv6                  338660  34
alexanderre
Contact: Facebook
Re: Raspberry Pi 3 and wlan0 no longer showing up
Thu Mar 24, 2016 12:43 pm
Have the same issue - no wlan0 in ifconfig on RPi 3.
I just took the card from Rpi 2 and put it into my new Rpi 3, ran all updates and upgrades and figured that everything apart from WiFi works.
Any ideas?
gdt
Thu Mar 24, 2016 1:14 pm
If you've previously run Wheezy on that image then you might still have a /etc/udev/rules.d/70-persistent-net.rules which is claiming the wlan0 name. Edit or delete that file.
Jessie works pretty much as described in this proposal. If might be worth booting Jessie with "net.ifnames=1" appended to /boot/cmdline.txt and seeing if the interface is present then.
