valakaushal
IP address issue in pi 2 model
Thu Mar 10, 2016 9:11 am
Hey,
I have purchased pi 2 board.
Now i want to assign one static ip address to my board.
I have used
$sudo nano /etc/network/interfaces
and then i have inserted my IP address, gateway and subnet mask.
I have also edited resolv.conf file to nameserver 8.8.8.8
and then i reboot my board.
After reboot, i used ifconfig command to see the ip address
Problem is even though after doing all this steps, my board has by default ip address (i.e 169.269.227.193)
DirkS
Re: IP address issue in pi 2 model
Thu Mar 10, 2016 9:24 am
What changes did you make?
Are you running Jessie or Wheezy?
On Jessie you set a static address in /etc/dhcpcd.comf
valakaushal
Thu Mar 10, 2016 10:51 am
I am using Jessie.
And i did following changes by typing following command
iface lo inet loopback
iface eth0 inet static
address 172.16.0.29
netmask 255.255.240.0
gateway 172.16.0.1
i have done this changes to interfaces file.
i also made changes by typing
$sudo nano /etc/resolv.conf
nameserver 8.8.8.8
I made these two changes and then reboot my board.
DirkS
Thu Mar 10, 2016 11:11 am
See my above comment about using dhcpcd.conf on Raspbian Jessie.
There s actually a comment at the top of /etc/network/interfaces about this.
valakaushal
Fri Mar 11, 2016 4:03 am
DirkS wrote:See my above comment about using dhcpcd.conf on Raspbian Jessie.
Dear Driks
Please tell me exactly what changes are to be done in /etc/dhcpcd.conf file
valakaushal
Fri Mar 11, 2016 4:12 am
One more thing is, my pi board by default take IP address of 169.254.227.193.
Candyjet
Fri Mar 11, 2016 9:23 am
V, I was also struggling with this. I succeeded following these instructions.
http://www.circuitbasics.com/how-to-set ... pberry-pi/
CJ
DirkS
Fri Mar 11, 2016 9:40 am
valakaushal wrote:One more thing is, my pi board by default take IP address of 169.254.227.193.
That is a default / fallback address in case it cannot get a DHCP or static address.
Regarding the changes:
* get /etc/network/interfaces back to it's original state.
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
* At the end of /etc/dhcpcd.conf add
interface eth0
static ip_address=172.16.0.29/20
static routers=172.16.0.1
static domain_name_servers=8.8.8.8
valakaushal
Sat Mar 12, 2016 9:42 am
Hey guys,
Raspbian wheezy has solved my problem.
DirkS
Sat Mar 12, 2016 10:05 am
valakaushal wrote:Hey guys,
That's very nice of Wheezy.
But I don't think going back to an older version of an OS is a solution...
