specialdo
Re: Samba Performance
Fri Oct 25, 2013 6:03 pm
I have a raspberry model b with 512 mb of ram with raspbian. I made all the updates.
I attached to raspberry a wifi adapter and a 1.5 tb hd powered with ext4 partition. I can't try to plug in ethernet, because the router has the only ethernet port connected to the modem.
transfer with samba is slow. a few minutes ago I added
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF = 65535 SO_SNDBUF = 65535
and now to copy a file on the PC connected to the network, the transfer rate varies from 100 kb / s to 900 kb / s.
before it was fixed to 200 kb / s and a few minutes later the transfer was interrupted.
screenshot of my transfer rate:
1) https://dl.dropboxusercontent.com/u/107 ... /rasp1.png
2) https://dl.dropboxusercontent.com/u/107 ... /rasp2.png
I have these lines in smb.conf:
[shared]
comment = HD Raspberry
path = / mnt / nas
public = yes
guest ok = yes
writable = yes
and my /etc/fstab is:
proc                         /proc                   proc    defaults          0       0
/dev/mmcblk0p1  /boot                    vfat    defaults          0       2
/dev/mmcblk0p2  /                            ext4    defaults,noatime  0       1
/dev/sda2              /mnt/nas              ext4    rw,auto,users     0       0
/dev/sda1             /mnt/USB_1500  ntfs-3g  rw,auto,users     0       0
I'd like to get to speed as 3 mb / s to watch film in streaming with VLC or to copy file from hd on my pc or mac.
can you help me please? you need more information?
bebbo
Fri Nov 15, 2013 2:39 am
that's not about samba... but file system in general:
ntfs-3g:
dd if=/dev/zero of=/mnt/HD/test.tmp bs=500K count=1024
1024+0 records in
1024+0 records out
524288000 bytes (524 MB) copied, 507.767 s, 1.0 MB/s
ext4:
dd of=/media/HD/test.tmp if=/dev/zero bs=500K count=1024
1024+0 records in
1024+0 records out
524288000 bytes (524 MB) copied, 21.4531 s, 24.4 MB/s
ntfs uses CPU... soo... sucks for devices like raspberry!
richardps
Thu Dec 05, 2013 1:22 am
I have RPi v2 (512MB RAM) with Rasbian out of the box and Samba + all updates.
I have 64GB USB 2 Stick on powered USB Hub.
RPi connected to Virgin Media SuperHub via ENET and Windows 7 System connected via .11n WiFi
Already added:
I am getting 4.5MB/s MAX read from Pi to PC. Pi Share is Read-Only (so my kids don't delete stuff)
I am sure I can get better than this but I don't know where the lag is.
dd test from the stick runs at ~20MB/s so the USB access isn't an issue.
CPU Usage during transfer only hits 40% so I don't think this is the bottle-neck.
My WiFi is super-fast with everything else although I don't have another NAS to compare it to.
USB Stick is FAT32 formatted.
I have read through the thread and see so many widely varying results. It is totally usable for my purposes but it isn't fast enough for video over the network as playback is choppy. I guess I just want to know if it is worth chasing a few extra MB/s or where to start looking.
Richard S
Model B - Linux Noob
RoyLongbottom
Thu Dec 05, 2013 10:31 am
I got similar Wi-Fi speeds. Sometimes LAN not much better. More details in:
http://www.roylongbottom.org.uk/Raspber ... m#anchor24
 Source  Dest                             MBytes/Second
 CPU     CPU/drive     MB  Write1  Write2  Write3   Read1   Read2   Read3
 Rpi     Ph Win        16    7.29    8.13    6.78   11.53   11.60   11.58
 Ph Win  Rpi           16   11.29   11.18   10.70    4.22    2.70    1.97
 Rpi     C2 Lin        16    7.79    7.52    7.84   11.62   11.61   11.66
 C2 Lin  Rpi           16    6.53    6.36    6.23    5.58    5.49    6.01
 Rpi     LT Lin        16    3.23    3.24    3.20    3.59    3.50    3.50 WiFi
 Rpi     LT Lin        16    1.78    1.62    1.00    0.92    0.89    0.39 WiFi outside
 Rpi     Rpi           16   57.41   60.05   50.00  155.48  152.66  155.89 cached
 C2 Lin  Ph Win        16   57.76   54.31   55.02   33.82   31.91   32.13 1Gbps
 Ph Win  C2 Lin        16  108.62   89.62  109.83   36.45   22.09   15.30 write later
 Ph Win  C2 Win        16   29.19   38.20   38.18   21.48   14.95   11.59 1Gbps
 C2 Win  Ph Win        16   72.36   68.46   50.16   25.96   18.76   12.71 1Gbps
 Random msecs        Read                   Write
 From MB                4       8      16       4       8      16
 Rpi     Ph Win     0.011   2.272   1.651    3.40    4.12    4.17
 Ph Win  Rpi        1.299   1.208   1.275    1.29    1.37    1.28
 Rpi     C2 Lin     0.637   2.160   0.872    2.42    2.14    2.15
 C2 Lin  Rpi        1.820   0.978   1.259    3.05    2.49    2.45
 Rpi     LT Lin     4.520   5.391   3.234    4.08    3.22    3.16         WiFi
 Rpi     LT Lin    10.264  11.906  11.107    5.16    4.08    4.29         WiFi outside
 Rpi     Rpi        0.012   0.012   0.012   23.03   24.69   25.01         cached
 C2 Lin  Ph Win     0.001   0.002   0.002    1.79    2.04    1.77         1Gbps
 Ph Win  C2 Lin     0.556   0.468   0.423    0.43    0.43    0.43         write later
 Ph Win  C2 Win     0.846   0.875   5.553    1.13    2.41    2.88         1Gbps
 C2 Win  Ph Win     0.613   0.585   0.583    0.88    1.24    1.37         1Gbps
                               milliseconds per file
 200 Files          Write                    Read                  Delete
 File KB                4       8      16       4       8      16    secs
 Rpi     Ph Win      6.63    6.83    7.68    3.88    5.07    5.98    0.28
 Ph Win  Rpi        14.15   14.21   15.76   10.32   10.52   11.47    1.79
 Rpi     C2 Lin      5.74    6.83    8.96    4.87    5.97    6.74    0.60
 C2 Lin  Rpi         9.87   10.55   11.73    7.13    7.52    8.44    1.30
 Rpi     LT Lin      9.79   10.81   13.34    7.69    8.95   11.53    1.07 WiFi
 Rpi     LT Lin     12.26   16.08   18.94    9.30   12.53   15.09    1.54 WiFi outside
 Rpi     Rpi         0.87    0.73    0.67    0.08    0.15    0.19    0.05 cached
 C2 Lin  Ph Win      2.57    2.52    2.61    0.85    0.83    0.86    0.13 1Gbps
 Ph Win  C2 Lin      3.72    3.58    3.60    3.20    3.22    3.31    0.52 write later
 Ph Win  C2 Win      4.92    3.46    3.50    3.22    3.09    3.42    0.40 1Gbps
 C2 Win  Ph Win      3.10    3.12    3.19    3.99    2.93    2.73    0.46 1Gbps
 Ph Win = Phenom Windows 7    C2 Win = Core 2 Vista   C2 Lin = Core 2 Ubuntu 10.1
 LT Lin = Laptop Ubuntu 10.1  RPi    = Raspberry Pi
bassti
Tue Jan 14, 2014 10:22 am
Hi guys,
I still don't get the performance some of you are getting. I have connected a 3TB WD Elements ext3 drive (almost empty) and are copying from a windows machine over 100Mbit/s network.
I've added the
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=65535 SO_SNDBUF=65535
to my smb.conf
The benchmark on the hard drive shows speeds up to 22MB/s. My Pi is clocked at 900MHz. CPU is constantly at 100% with smbd at the top.
Any advise?
richardps
Thu Jan 23, 2014 7:57 pm
Hi All,
Just checking in here. I think the problem is my WiFi location/performance. With the same setup in other parts of the house it's a lot better. I haven't clocked the speeds but one of my kids was streaming video to an iOS device while another copied a video to his Android tablet without disruption. I need to extend my WiFi reach to better service my home office.
Rich
Richard S
cristianhaulica
Tue Feb 25, 2014 9:09 am
My tests with NTFS vs EXT4
TESTS
dd if=/dev/zero of=/media/NAS_MIRROR/test.tmp bs=500K count=1024
dd if=/media/NAS_MIRROR/test.tmp of=/dev/null bs=500K count=1024
dd if=/dev/zero of=/media/NAS_MAIN/test.tmp bs=500K count=1024
dd if=/media/NAS_MAIN/test.tmp of=/dev/null bs=500K count=1024
dd if=/media/NAS_MIRROR/test.tmp  of=/media/NAS_MAIN/test.tmp bs=500K count=1024
dd if=/media/NAS_MAIN/test.tmp of=/media/NAS_MIRROR/test.tmp bs=500K count=1024
rsync -av --progress  /media/NAS_MAIN/test.tmp /media/NAS_MIRROR
EXT4 - results
524288000 bytes (524 MB) copied, 19.4394 s, 27.0 MB/s
524288000 bytes (524 MB) copied, 25.1926 s, 20.8 MB/s
524288000 bytes (524 MB) copied, 19.7097 s, 26.6 MB/s
24288000  bytes (524 MB) copied, 25.3471 s, 20.7 MB/s
524288000 bytes (524 MB) copied, 42.658  s, 12.3 MB/s
524288000 bytes (524 MB) copied, 41.0494 s, 12.8 MB/s
sending incremental file list test.tmp
  524288000 100% 5.36MB/s
NTFS - results
524288000 bytes (524 MB) copied, 151.029 s, 3.5 MB/s
524288000 bytes (524 MB) copied, 30.8276 s, 17.0 MB/s
524288000 bytes (524 MB) copied, 152.822 s, 3.4 MB/s
524288000 bytes (524 MB) copied, 30.5608 s, 17.2 MB/s
524288000 bytes (524 MB) copied, 183.078 s, 2.9 MB/s
524288000 bytes (524 MB) copied, 186.239 s, 2.8 MB/s
  524288000 100% 2.06MB/s 0:04:02
Although I did not performed tests with Samba share, it seems the speed is significantly higher with EXT4.
PS. My main concern was that whenever I has heavy access to NTFS, I saw very high CPU usage with ntfs3g library. With EXT4, I completely uninstalled it. Now the highest CPU usage goes to the actual processing applications (like PHP, srync...)
smuggly
Sat Mar 01, 2014 3:49 pm
Theres a fix you can put in samba conf, I got off google. I have not tried yet but I post it here, It goes @ the bottom of samba.conf. Global Section.
max xmit = 65535
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_SNDBUF=65535 SO_RCVBUF=65535
read raw = yes
write raw = yes
max connections = 65535
max open files = 65535
sudo service samba restart
sudo /etc/init.d/samba restart
AudibleBag
Tue Mar 11, 2014 1:39 pm
I've been looking into this for a bit in the past days.
Default values for max xmit = 65536, for read/write raw = yes. So explicitly setting these probably won't change a thing.
According to the samba people the SO_SNDBUF and SO_RCVBUF are something to experiment with. Higher isn't neccesarily better. (source)
I'm struggeling to get read performance higher than 4mb/s with modest overclock and samba cpu usage in the 90+%. The external drive performs just fine with 25mb/s read speeds.
Planning to do an iperf test between my windows 7 machine and the pi tonight to if link speed could be the issue.
I would really like to be able to stream high quality video with samba. So I'm still hoping for a magic option or some UDP based streaming solution. (Tried VLC but its performance is even worse).
abishur
Tue Mar 11, 2014 4:52 pm
AudibleBag wrote:I've been looking into this for a bit in the past days.
Is the external drive formatted EXT4 or some other format?
Dear forum: Play nice ;-)
AudibleBag
Tue Mar 11, 2014 5:00 pm
abishur wrote:Is the external drive formatted EXT4 or some other format?
It's ext4 mounted with defaults,noatime.
edit:
Ok even with the pi under stress from another process the iperf test shows the network seems to be fine:
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
[  4] local 192.168.0.2 port 5001 connected with 192.168.0.6 port 50354
[ ID] Interval       Transfer     Bandwidth
[  4]  0.0-10.0 sec  56.1 MBytes  46.9 Mbits/sec
marioscube
Mon Mar 17, 2014 1:13 pm
A iperf link speed of 47 megabits/sec is maybe not what we want or expect, but it's what it is (mine is actually lower .... )
This link speed translates to roughly 5 Megabytes / second.
This is with no optimizations in iperf.
The throughput if I copy some media files from my Raspberry Pi to my Windows 7 PC is about 6-6.5 megabytes/second. Perhaps windows does some optimization? With my mac I sometimes reach speeds up to 7.5 megabytes/second, but not always.
4 Megabytes/second should be enough bandwidth for most media files (blueray excluded).
huedrant
Mon Mar 24, 2014 11:21 am
I have OMV (openMediaVault) running and get an amazing ;) speed of 0.6 MB/s. Here's how I tested:
dd count=100 bs=1M if=/dev/urandom of=/media/bla/test
100+0 records in
100+0 records out
104857600 bytes (105 MB) copied, 169.511 s, 619 kB/s
currently, the hub between the raspi and the 2,5" hdd EXT4 is not powered by an extended power supply, but the hdd has additional USB power from another external source.
any ideas how to improve this setup?
update: I just added the mighty line
to smb.conf - and the speed dropped to truly exciting 62KB/s . OMG, omv!
tbar
Wed Mar 26, 2014 3:57 pm
Try connecting the HDD directly to the rpi and not through the hub.
abishur
Mon Mar 31, 2014 1:54 pm
Out of curiosity what is open media vault? I can only assume it's either a DLNA server or a file sharing mechanism like Samba. If it's DLNA have you tried other DLNA servers to see if you get better throughput? If it's just a file sharing mechanism is there a reason why you don't want to use samba?
I use an old model B (one of the 256 boards from back in the day) as a dedicated Samba server. Every so often I reinstall Raspbian from scratch, install Samba and enable my share. Without any additional tweaking to samba or overclocking to the pi, I get very reliable speeds of 7.5 MB/s all day long provided my laptop is physically wired into the network, using WiFi it's more like 2-3 MB/s, but that's a limitation of the router I'm using more so than the Pi.
Beyond that +1 to tbar suggestion of connecting the hard drive directly to the Pi. There a lot of detailed (boring) and technical issues for doing this concerning the way Linux handles the USB stack and the way the Pi's USB port operates, but the long and short is you'll get better performance with the Hard Drive directly connected to the Pi.
teeth_03
Tue Apr 01, 2014 1:53 am
I oddly enough tend to get better writes than reads, about ~10 write and around ~7 read, on a wired network, ext4 formatted drive.
GazD
Fri Apr 04, 2014 7:54 am
I have been reading this thread with interest and thought I would post my results.
I have a WD My Book 2TB formatted in ext4 connected directly to the Pi. DD test comes back as ~25MB/s for both read and write. Samba performance is obviously lower and comes in at 5MB/s for both read and write. I have overclocked my Pi using raspi-config and used the medium overclock (900arm, 250core and 450sdram) I have the following added to my smb.conf file
[global]
        workgroup = HOME
        server string = %h server
        map to guest = Bad User
        obey pam restrictions = Yes
        pam password change = Yes
        passwd program = /usr/bin/passwd %u
        passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:                                        * %n\n *password\supdated\ssuccessfully* .
        unix password sync = Yes
        syslog = 0
        log file = /var/log/samba/log.%m
        max log size = 1000
        socket options = TCP_NODELAY SO_RCVBUF=65535 SO_SNDBUF=65535 IPTOS_LOWDELAY SO_KEEPALIVE
        dns proxy = No
        usershare allow guests = Yes
        panic action = /usr/share/samba/panic-action %d
        idmap config * : backend = tdb
        use sendfile = Yes
        write cache size = 131072
I have tried various variables and some made it drop to speeds below 100kB/s. This seems to be best config for me.
PaNiek
Sat Apr 05, 2014 7:30 pm
@abishur
OpenMedia Vault is a very stable and easy to maintain NAS solution. The successor of FreeNas and can be found at http://www.openmediavault.org/ or http://sourceforge.net/projects/openmediavault/
Since october 2011 I've got it running on an old P-4 box with multiple 2TB disks in a raid configuration.
abishur
Mon Apr 07, 2014 1:53 pm
PaNiek wrote:@abishur
Ohhhhh, so how many hard drives do you have connected to the Pi and which RAID configuration are you using with it?
PaNiek
Tue Apr 08, 2014 12:47 pm
Well, sorry for the misunderstanding, but OMV isn't running on a Pi, but on a Pentium-4 with 4 2TB SATA disks in RAID5.
abishur
Tue Apr 08, 2014 2:34 pm
PaNiek wrote:Well, sorry for the misunderstanding, but OMV isn't running on a Pi, but on a Pentium-4 with 4 2TB SATA disks in RAID5.
ha! Sorry, I thought you were the individual who posted above about the OMV with really slow speeds, but after scrolling back up I see that it was huedrant with those issues. Sorry about that! :lol:
dvkch
Wed May 14, 2014 1:17 pm
Having the same speed issues as all of you (except some lucky ones) I decided to run some tests. I also read some incorrect methods so I'm gonna try and be precise on those.
All tests were run with the following configs :
- RPi B 512, XBian rc1,
gpu_mem_512=256, arm_freq=840, sdram_freq=450, core_freq=400
in config.txt and
in samba.conf (ran though
testparm
- MacBookPro 2.9Ghz, Mavericks 10.9.2 native, Windows 7 under VirtualBox with NAT networking, 1GBps (wired) and 144MBps (wireless) connectivity
- test file: test.mp4 ( 417MB )
- test drive: 3,5" 500GB Sata over USB (has its own power cable), ext4
First: usb speed tests
 Device | R/W |  bs  | count | Speed (MBps)
  zero  |  W  | 500K | 1024  | 16.4
  zero  |  W  |  4M  |  128  | 18.4
 random |  W  | 500K | 1024  |  9.6
 random |  W  |  4M  |  128  |  9.9
  null  |  R  | 500K | 1024  | 21.7
  null  |  R  |  4M  |  128  | 21.9
Conclusions concerning write speed tests:
- using /dev/random is creating a bottleneck
- using bigger blocks is better
Second: SMB speed tests
Wired | OS  | R/W | Speed min-max (MBps)
  NO  |  X  |  W  |     2.6 - 3.2
 YES  |  X  |  W  |     3.4 - 4.2
  NO  |  X  |  R  |     3.6 - 4.5
 YES  |  X  |  R  |     6.1 - 6.7
  NO  |  W  |  W  |     4.3 - 4.8
 YES  |  W  |  W  |     3.7 - 4.5
  NO  |  W  |  R  |     6.0 - 6.9
 YES  |  W  |  R  |     6.4 - 7.1
Conclusions:
- OSX SMB support could be better and suffers from wireless connections
- Windows SMB support works OK on wireless connections
Having also tried VFAT (FAT32) filesystem I guarantee, though not obvious, ext4 is way better. I also found this article concerning FS speed tests on Linux: http://www.ilsistemista.net/index.php/l ... ml?start=4
It show that ext4 and ext3 share basically the same speeds.
In my case I think the major bottleneck is OSX SMB support, and maybe overclocking a bit more the Pi could also help.
For those having 10MB read speed just a quick question: you're testing with windows right ?
I hope this can help, Stan
teeth_03
Sat May 17, 2014 11:14 am
I get around 10-11 on Writes And 7-8 on reads on a wired network with all Windows 7-8 PCs, on a 256 Pi running Raspian, can't remember the GPU split, I know the GPU side is low.
Externally powered Seagate 3TB Hard drive is ext4 and the Samba share is public, anyone can read or write (its at my apartment, could care less about the security).
Don't ask why Writes are better than Reads, I have no idea why.
FM81
Sun May 18, 2014 7:02 am
teeth_03 wrote:I get around 10-11 on Writes And 7-8 on reads on a wired network with all Windows 7-8 PCs ...
How do you measure this? 11MByte per second is near the theoretical limit, what a 100MB-network can give?
My Reading-Speed is the same as you posted, and sometimes I also see a Writing-Speed, which is a very little bit higher than for reading, but in none case such a big difference?
A: What does the command 'cat /dev/urandom', can you tell me please?
B: Yeah, that's very simple: It feeds your cat with radioactive material!
teeth_03
Mon May 19, 2014 6:22 pm
Its what Windows 8 tells me when I transfer large files to my NasPi
