momoz
Turn the Raspberry Pi B+ into a WiFi router using an LTE mod
Thu Feb 11, 2016 8:03 am
I'd like to Turn the Raspberry Pi B+ into a WiFi router using an LTE modem (4G).
To do so, I follow the instruction exist in this website http://raspberrypihq.com/how-to-turn-a- ... fi-router/
Except these instruction is used to turn the Raspberry into a WiFi router using an ethernet but not the 4G modem.
so I tried to modify some point to adapt to the 4G modem. so I do these modification:
1/ sudo nano /etc/network/interfaces (I do the same thing as the website required except I add
iface wwan0 inet dhcp
2/ and to setting up the actual translation between the ethernet port called eth0 and the wireless card called wlan0 :
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
sudo iptables -A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i wlan0 -o eth0 -j ACCEPT
for my case I changed eth0 by wwan0 to obtain:
sudo iptables -t nat -A POSTROUTING -o wwan0 -j MASQUERADE
sudo iptables -A FORWARD -i wwan0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i wlan0 -o wwan0 -j ACCEPT
3/To starting the wireless router I do
sudo service isc-dhcp-server start
sudo service hostapd start
4/When I turn on the wifi of my mobile or my laptop, I found the SSID that I create on hostapd.conf and I can logg in with the password
But the problem I can't access to internet!!!
Is there any thing wrong that I do in the steps that I modified??
Thank you for your help
Best regards
fredoll
Re: Turn the Raspberry Pi B+ into a WiFi router using an LTE
Thu Feb 11, 2016 8:49 am
ip_forward setting ?
sudo sysctl -w net.ipv4.ip_forward=1
momoz
Thu Feb 11, 2016 2:44 pm
the ip forward is done as mentionned in the website:
Open /etc/sysctl.conf with:
sudo nano /etc/sysctl.conf
Scroll down to the last line of the file and add the line:
Next start the translation right away by running:
sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
ondrej
Thu Feb 11, 2016 6:26 pm
provide ifconfig, ip r and iptables-save outputs
momoz
Mon Feb 15, 2016 9:39 pm
Hello Ondrej,
Thank you for your response.
The last couple of days I was trying to understand how to combine the ip route and the ip tables. I do some research on net but just I'm scrambled.
Could you please give me some details about how shall I do??
Thank you
ondrej
Wed Feb 17, 2016 10:22 am
hi momoz,
i already sent you request for print out of ifconfig, ip r and iptables-save commands to help you. for more i advise you to study IP routing and IP tables ;)
momoz
Wed Feb 17, 2016 9:48 pm
Hello ondrej,
Just I apologize because I don't receive a notification tell me that you have sent a request for print out of ifconfig. (I don't received yet)
Re: Turn the Raspberry Pi B+ into a WiFi router using an LTE mod
Tue Jul 25, 2017 10:08 pm
Try this: https://www.raspberrypi.org/documentati ... s-point.md which is known to work as long as your WiFi dongle supports AP mode.
This is a doctor free zone.
madrian
Tue Jul 25, 2017 11:07 pm
Unfortunately there is no new information on that page.
I want to share internet from a 4G LTE modem, If I change commands from wwan0 to WiFi wlan0, then it's working. Interesting, I don't understand why it's not working with the LTE modem wwan0 interface. :evil:
