FruityWiFi v2.3
Posted: Thu Feb 04, 2016 6:47 pm
FruityWifi is an open source tool to audit wireless networks. It allows the user to deploy advanced attacks by directly using the web interface or by sending messages to it.
GitHub: https://github.com/xtr4nge/FruityWifi
Forum: http://fruitywifi.boards.net
FruityShell
Allows you to control FruityWiFi using a metasploit-ish type of shell.
FruityWiFi needs to be up an running and the API module needs to be installed.
https://youtu.be/3ptzmogttgI
FruityDisplay
Allows you to control FruityWiFi using a RPi + adafruit-16x2 LCD Display+Keypad.
FruityWiFi needs to be up an running and the API module needs to be installed if you want to use the modules screen.
https://youtu.be/8lYwreSSnH0
regards,
FruityShell
FruityDisplay
regards,
