Paul_griff
How do I make no-ip run at startup
Fri Aug 03, 2012 12:38 pm
I am running no-ip on my raspberry with no problems, but I need the exact command line to make it run at start up in case of my pi losing power. I have tried a couple of ways to get it to run at startup to no avail so need your help!
Apologies for all the stupid questions!
JeremyF
Re: How do I make no-ip run at startup
Fri Aug 03, 2012 12:45 pm
http://elinux.org/RPi_Debian_Auto_Login
(Modified the instructions from here)
But instead of putting "startx" in /etc/profile , just put the command for starting no-ip.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
SirLagz
Fri Aug 03, 2012 3:25 pm
use noip2 via apt-get
it runs as a daemon and you won't need to worry about running it at manually.
LetHopeItsSnowing
Fri Aug 03, 2012 3:32 pm
I have felt your pain, so much so I wrote it down, if you haven't done so already here is some info about how to install the no-ip client
http://stuffaboutcode.blogspot.co.uk/20 ... using.html
And here is the instructions for making it run at startup
http://stuffaboutcode.blogspot.co.uk/20 ... rt-up.html
LHIS
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
dmknob
Sun Aug 26, 2012 9:44 pm
I change the 2nd link script to run the Sakis3G and make a 3G connection.
If i manually run the script ('sakis3g connect', with the proper /etc/sakis3g.conf) it connects perfect.
With this startup method nothing occurs..
Any idea?
ps.: i use ddclient with no-ip service. Works fine when 3G connects (get the IP from ppp0).
ephestione
Wed Aug 15, 2018 8:15 pm
The problem with running automatically the noip DUC, either from rc.local or crontab @reboot, is that when those two are executed at system startup, the network interface isn't usually up yet, so noip will just terminate.
I solved this by delaying the start of the updater via SU crontab, with:
@reboot sleep 10 && /usr/local/bin/noip2
