AgeT
Reach OwnCloud from outside
Thu Aug 02, 2012 12:13 pm
hello
i managed to get owncloud running , and for my taste it is fast enough
but now it is only reachable from inside of the LAN
how can i realise this :(?
RaTTuS
Contact: Twitter YouTube
Re: Reach OwnCloud from outside
Thu Aug 02, 2012 12:24 pm
you will need to add hole in your firewall of your router
Covfefe
felix123
Thu Aug 02, 2012 12:29 pm
aka "port forwarding"
AgeT
Thu Aug 02, 2012 1:35 pm
so :
static ip
portforwarding
and thats all ?
duncan_ross
Fri Aug 03, 2012 7:37 pm
I think you will need to configure your boundary router to work with one of the dynamic DNS providers, assuming that like most of us you are given a dynamic IP address by your network provider. I persuaded my ADSL router to work with no-ip and opened port 80 so that I could use my RPi as a very simple webserver.
Duncan
AgeT
Sat Aug 04, 2012 7:27 am
The problem is , my router wants ti work with dyndns , which is a paid service...
Paul Webster
Contact: Twitter
Sat Aug 04, 2012 12:21 pm
Dyndns is free - at least for my basic usage.
http://dyn.com/dns/free-vs-vip/
AgeT
Sat Aug 04, 2012 12:27 pm
No, it was free, now you can not create a free account anymore
ghellquist
Mon Aug 06, 2012 1:20 pm
Dynamic ip-adresses may not be very dynamic really. It depends on the provider. I believe I have had the same "dynamic" IP-adress the last 6 months or so.
Alternatively, if dyndns is not free anymore, and that is all the router supplies, you might find an alternative and install that on the raspberry instead.
My working idea about dyndns (and similar services) would be as follows
1) the raspberry client sends "messages" to the server now and then. This message will automatically have the current dynamic ip-adress (this is added by the router that knows the adress).
2) a server on a "well-known adress" saves the info in a database
3) your web client (or whatever) calls the "well-know adress" and is redirected to the raspberry
There are of course details and details but conceptually it is simple.
// gunnar
RaTTuS
Mon Aug 06, 2012 1:27 pm
http://www.no-ip.com/services/managed_d ... c_dns.html
will help if dyn-dns is not free anymore
I've not checked mind you
Covfefe
AgeT
Tue Aug 07, 2012 10:30 am
Actually, i figured out i was sitting behind 2 routers
what was a misfortune in the beginning , is now a bless.
as my second router is a fritz!box, i am able to use no-ip.com as a dyndns provider
no my owncloud is running perfectly , and i have a 100 gb cloud , reachable from everywhere , WUHU !
Thanks a lot guys
p.s. , my dynamic ip changes up to 2 times a day, so i really had to use a dyndns .
ghans
Tue Aug 07, 2012 10:39 am
@ghellquist
I've implemented a cheap , lazily coded noip service on my own.
PHP , Perl , curl , traceroute and cron.
Works like a charm . Gotta love UNIX tools (especially when they are already available).
It's only dependant on Googles public DNS and the server where my PHP script is stored.
Is there any way to know when your external IP changed without checking periodically ?
ghans
Slashplus
Thu Feb 07, 2013 8:00 am
Dynu dynamic DNS allows you to download the client and manage as many accounts as you like. I have been using it for a year or so. It is stable and pretty fast.
