root@raspberrypi:~# /etc/init.d/ramlog start
[FAIL Error: /var/log is in use... failed!
The list of open files: (You need to close below daemons if you want to start/stop ramlog manually)
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
rsyslogd 1937 root 1w REG 179,2 405830 2789 /var/log/syslog
rsyslogd 1937 root 2w REG 179,2 249542 2438 /var/log/kern.log
rsyslogd 1937 root 5w REG 179,2 22169 3560 /var/log/debug
rsyslogd 1937 root 6w REG 179,2 234511 3565 /var/log/messages
rsyslogd 1937 root 7w REG 179,2 1114 1381 /var/log/bandwidth
rsyslogd 1937 root 8w REG 179,2 408101 2437 /var/log/daemon.log
rsyslogd 1937 root 9w REG 179,2 33440 2785 /var/log/auth.log
console-k 2273 root 8w REG 179,2 146247 24 /var/log/ConsoleKit/history
Test result: ramlog cannot be started or stopped at the moment.
root@raspberrypi:~#
What I really miss is the log for ramlog during startup. /var/log/messages doesn't show anything for ramlog.
