dipole
Re: Raspcontrol - A Web Control Centre for the Pi
Sun Oct 28, 2012 12:44 pm
dipole wrote:I'm using lighttpd and placed the raspcontrol folder in my /var/www. when I browse to it I get a 503 error. Does anyone know what the problem is? Php works fine at my website hosted in var/www root. should I perhaps run this on a different port? Does anyone have instructions on how to do that?
503 is Server unavailable and can have a number of causes. Since you are using lighttpd, open a terminal window on the Pi and do
tail -f /var/log/lighttpd/error.log
after that, try to access your website and see if there are any errors on the terminal window.[/quote]
[email protected] ~ $ tail -f /var/log/lighttpd/error.log
2012-10-28 06:25:11: (server.c.1230) logfiles cycled UID = 0 PID = 5432
2012-10-28 08:42:49: (mod_fastcgi.c.2881) establishing connection failed: Connection refused socket: tcp:127.0.0.1:9000
2012-10-28 08:42:49: (mod_fastcgi.c.2887) backend is overloaded; we'll disable it for 1 seconds and send the request to another backend instead: reconnects: 0 load: 1
2012-10-28 08:42:51: (mod_fastcgi.c.2829) fcgi-server re-enabled: tcp:127.0.0.1:9000
sjfaustino
Sun Oct 28, 2012 4:53 pm
dipole wrote: [email protected] ~ $ tail -f /var/log/lighttpd/error.log
OK, that means that you have something that is taking so long that lighttpd thinks it broke, so it tries the old "have you tried switching it off and on again?" ;)
What do you have running on your Pi? can you do a paste of TOP?
Also, do you have the mod_status module loaded so we can see what's happening?
Just so that you can see what is possible, I moved my website from a VPS to a Pi (currently on a 120Mb cable line at my home, ht tp ://p tani me. dyn dns. org <- remove the spaces to get the full url) to test the speed and it's at least 2x faster in most places.
I'm shipping the Pi to a datacenter nest week and hosting the website from there :D
jaraeez
Tue Oct 30, 2012 7:50 am
Hope someone can help.
I've added the raspcontrol to /var/www & done the following
cd /var/www/
rm -r raspcontrol
wget https://github.com/Bioshox/Raspcontrol/zipball/master
unzip master
mv Bioshox-Raspcontrol-* raspcontrol
rm master
My problem is that when I go to localaddress/raspcontrol I get the following
<?php
	// This file is for users who don't use the PHP Server
	header('Location: app');
I guess I'm stuck from here. I added a test.php file to /var/www which came back fine???
TIA
scorp
Tue Oct 30, 2012 8:27 am
jaraeez wrote: My problem is that when I go to localaddress/raspcontrol I get the following
<?php
TIA
What kind of web server do you have installed? Does it support PHP? I had similar message when I was trying to run php web page on different development board with web server which supported only html, php was not installed.
jaraeez
Tue Oct 30, 2012 10:44 am
OK apologises.. a simple refresh of the browser I was using came back fine :oops:
jaraeez
Tue Oct 30, 2012 11:47 pm
One thing I've noticed is the network option on the page
 Network
| Received: 0 MB · Sent: 0 MB · Total: 0 MB
Although 'ifconfig' for the ethernet shows
RX bytes:122136699 (116.4 MiB)  TX bytes:121519444 (115.8 MiB)
& all data is external so eth0 is the correct one.
I've added command to the sudoer file as instructed - any ideas?
Cheers
sjfaustino
Wed Oct 31, 2012 12:34 am
jaraeez wrote:One thing I've noticed is the network option on the page
 Network
Cheers
That might be because of some issue with the sudoer. I'm changing that part anyway. Haven't had much free time lately but should be able to commit the code in a couple of days.
My goal is to not need to run anything as sudo (so no need for sudoer and no possible security hole) on the monitoring side.
jaraeez
Wed Oct 31, 2012 1:15 am
 Network
Cheers
No worries :) - not a deal breaker - I'll wait for your update.
Cheers
munklefish
Thu Nov 08, 2012 9:38 pm
urfankhaliq wrote:hi just browse to /var/www and do the following
sudo wget https://github.com/Bioshox/Raspcontrol/zipball/master
sudo unzip master
sudo mv Bioshox-Raspcontrol-* raspcontrol
sudo rm master
that will install it for u
I installed this using the above commands but see tats its now possible to run via php server than apache. How can i remove all that was setup from the above and then install the php version??
Thanks.
http://www.codeclinic.de
Bioshox
Fri Nov 09, 2012 12:07 am
sudo unzip master
sudo rm master
Thanks.
You can simply do a 'git pull' in the Raspcontrol directory and that will pull down the latest versin.
Then run ./start.sh and you're set!
Owner of: http://www.fusionstrike.com - I make gorgeous Raspberry Pi Tutorials :)
munklefish
Tue Nov 13, 2012 1:53 pm
Raspcontrol has great potential but lacks several things id like to see, as im sure others would too. I see from git hub that several people are working hard to implement thse features and more, but they are not yet included in the main gitrepo.
Is this likely to change soon?
If not, how can i update my raspcontrol installation directly from the active repos????
Thanks.
sjfaustino
Wed Nov 14, 2012 9:08 pm
munklefish wrote:Raspcontrol has great potential but lacks several things id like to see, as im sure others would too. I see from git hub that several people are working hard to implement thse features and more, but they are not yet included in the main gitrepo.
As far as I'm concerned, I can do a pull request to the main Repo at any time but I think my "vision" of raspcontrol may not be the same as the original author. What I intend to do is to focus more on the monitor and not the control part.
Since the code is public, even if I don't do any pull request, the original author can always change his code with my changes, I just won't get credited in github.
I'm still making changes to the code, one of the major ones is to show all the hardware connected to the USB port with images (if available, we can always add more imges in time), power used, description and a link to the raspberry.org wiki on how to install it.
In theory this means that all you have to do is plug-in something and you instantly get a link on how to install it. Nice, right?
I just haven't had much personal time available lately :(
munklefish wrote:how can i update my raspcontrol installation directly from the active repos?
sudo unzip master
sudo rm master
Replace Bioshox with the user you want, as an example, mine is sjfaustino, MrWaffle's is MrWaffle :)
Just go to Bioshox's on github and see who forked it and what they changed so far.
munklefish
Wed Nov 14, 2012 10:42 pm
Thanks for the reply sj.
Are you and mrwaffle working together so to speak or is this going in different directions for all involved???
munklefish
Wed Nov 14, 2012 11:57 pm
Running those commands kept moving the whole /sjfaustino-Raspcontrol-76fa0cc folder inside the existing raspcontrol folder. So i deleted the raspcontrol folder but cant rename /var/www/sjfaustino-Raspcontrol-76fa0cc to /var/www/raspcontrol
HELPPP!!
sjfaustino
Thu Nov 15, 2012 3:47 pm
munklefish wrote:Running those commands kept moving the whole /sjfaustino-Raspcontrol-76fa0cc folder inside the existing raspcontrol folder. So i deleted the raspcontrol folder but cant rename /var/www/sjfaustino-Raspcontrol-76fa0cc to /var/www/raspcontrol
HELPPP!!
open a terminal window and do:
sudo mv /var/www/sjfaustino-Raspcontrol-76fa0cc /var/www/raspcontrol
munklefish
Thu Nov 22, 2012 8:34 pm
Ok ill give that a go, thanks.
munklefish
Fri Nov 23, 2012 7:37 pm
[quote="sjfaustino"
[/quote]
That worked thanks.
Bioshox
Sun Nov 25, 2012 10:37 am
mcgyver83
Tue Dec 04, 2012 6:45 pm
I really like raspcontrol but I have a couple of questions:
how can I keep update my instance?
how do you retrive the "Warranty" information?
why I have a orange triangle signal close to CPU info?
mcgyver83
Fri Dec 28, 2012 8:54 pm
mcgyver83 wrote:I really like raspcontrol but I have a couple of questions:
Up :-)
Bioshox
Sun Dec 30, 2012 12:47 am
It's an Open Source project, view the source on GitHub and see how it works!
:D
mcgyver83
Wed Jan 02, 2013 2:48 pm
Ok, you are right but I'm not a python user/developer so an explanation should be great...
It tooks the same time you spent to answer... :D
randrade
Wed Jan 02, 2013 3:25 pm
Hi mate.
Just wanted to tell you this works perfectly for me, thanks a lot! Very useful :D
Bioshox
Sun Apr 28, 2013 9:14 am
It's been along time in getting updates, however some lovely people from the community have contributed fiercely to the development of Raspcontrol and I'm happy to announce a better, sexyer version than ever before!
https://github.com/bioshox/Raspcontrol
john564
Sun Apr 28, 2013 10:47 am
not working for me, can you view "details"
Not Found
The requested URL /raspc/Raspcontrol-master/details was not found on this server.
