sjfaustino
Re: Raspcontrol - A Web Control Centre for the Pi
Thu Jul 26, 2012 8:50 pm
Looks nice so far :)
I'm currently using the vpsinfo script together with vnstat and mysqlreport since it's what I've used for years.
You can see it running live on my RPi at http://mrmister.dyndns.org/vpsinfo/vpsinfo.php
sjfaustino
Fri Jul 27, 2012 5:21 pm
sjfaustino wrote:Looks nice so far :)
Also, something like loadavg would be nice, you can see it running here as well: http://mrmister.dyndns.org/loadavg
Bioshox
Sat Jul 28, 2012 2:34 pm
We've just released a website, you can find it here: http://raspcontrol.com
There will be a community and blog coming soon where everyone will be able to suggest ideas and contribute :D!
Owner of: http://www.fusionstrike.com - I make gorgeous Raspberry Pi Tutorials :)
empire
Sat Jul 28, 2012 10:23 pm
I am currently away for a week, so I probably wont get much time to contribute until next saturday :-)
http://rpi-blog.com - Raspberry Pi guides, tips, tricks, and resources :-)
scorpion_tr
Tue Jul 31, 2012 7:19 am
Firstly thank you for this great control centre :)
But I think Network section doesn't show the true values. I've downloaded a lot of stuf yesterday night which is around 10GB, and the values shown on Raspcontrol page are below;
Ethernet | Received: 1095.5 MB · Sent: 1532.86 MB · Total: 2628.36 MB
Bioshox
Tue Jul 31, 2012 8:01 am
scorpion_tr wrote:Firstly thank you for this great control centre :)
This was an issue I was thinking about last night, the values are correct but I'm pretty certain they cut off when they hit over 1024MB (needs confirming), but it could also be that you have Restarted your Raspberry Pi, as these values do reset.
LeroyZ84
Tue Jul 31, 2012 8:12 am
maybe use vnstat? http://humdi.net/vnstat/
www.­djredmar.­com:­8080
scorpion_tr
Tue Jul 31, 2012 9:30 am
Bioshox wrote:This was an issue I was thinking about last night, the values are correct but I'm pretty certain they cut off when they hit over 1024MB (needs confirming), but it could also be that you have Restarted your Raspberry Pi, as these values do reset.
No I haven't restarted, it has been running for more than 65 hours. All of them are more than 1024MB and haven't cutted yet.
Latest stats about data transfer;
Ethernet | Received: 1105.07 MB · Sent: 1539.09 MB · Total: 2644.16 MB
Bioshox
Tue Jul 31, 2012 9:32 am
No I haven't restarted, it have been running for more than 65 hours. All of them are more than 1024MB and haven't cutted yet.
Did you download these locally? If this this will be on your LocalLoopback and won't show via Ethernet traffic
scorpion_tr
Tue Jul 31, 2012 9:34 am
I downloaded 10GB of data via transmission-bt last night.
Bioshox
Tue Jul 31, 2012 9:36 am
scorpion_tr wrote:I downloaded 10GB of data via transmission-bt last night.
Could you SSH into your Raspberry Pi and run 'sudo ifconfig'
and copy and paste it into here please :)
scorpion_tr
Tue Jul 31, 2012 9:40 am
I hope this helps to find the problem :)
[email protected]:~$ sudo ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:0a:47:d4
          inet addr:192.168.1.12  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::ba27:ebff:fe0a:47d4/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:12072087 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8414650 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1159810366 (1.0 GiB)  TX bytes:1614779670 (1.5 GiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:2519 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2519 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:163378 (159.5 KiB)  TX bytes:163378 (159.5 KiB)
Edit: Strangely it also shows 1GB data transfer :D So I think there is nothing wrong with raspcontrol? :)
empire
Tue Jul 31, 2012 9:04 pm
scorpion_tr wrote:I hope this helps to find the problem :)
Indeed. When I wrote the network script I made it take the values from ifconfig -- If your ifconfig is showing 2.5GB total used then Raspcontrol will too. It may be a bug in the OS/Kernel -- Which OS are you using? Have you used the firmware updater recently?
urfankhaliq
Thu Aug 02, 2012 3:18 pm
since updating my raspcontrol the memory usage is showing 93% used with very little free memory!?
Its not doing much other then a couple of files shares that are not even being accessed at this time
Any one else experience this?
LeroyZ84
Thu Aug 02, 2012 3:34 pm
urfankhaliq wrote:since updating my raspcontrol the memory usage is showing 93% used with very little free memory!?
i think this is cached ram
please try on your console:
[email protected]:~# free -m
             total       used       free     shared    buffers     cached
Mem:           215        142         73          0         17         92
http://www.djredmar.com:8080/raspcontrol/ There is my RaspControl
Baldrick1
Thu Aug 02, 2012 3:40 pm
If you run an ifconfig you'll see the same numbers for the values that include the cache. The "real" values excluding the cache will be much lower and is the number you're expecting to see.
This has been logged as a suggestion on github already
https://github.com/Bioshox/Raspcontrol/ ... nt-7410792
urfankhaliq
Thu Aug 02, 2012 3:42 pm
Thanks,
This is what I get when i do free -m
[email protected]:/home/pi# free -m
Mem: 183 171 12 0 15 98
-/+ buffers/cache: 56 126
Swap: 99 1 98
and currently my raspcontrol is showing 171MB used too and 12 MB free
why is my pi using so much memory when its not doing anything??
urfankhaliq
Thu Aug 02, 2012 3:53 pm
LeroyZ84 wrote:http://www.djredmar.com:8080/raspcontrol/ There is my RaspControl
How come yours has 215MB of memory and mine only has 183 MB of memory?
LeroyZ84
Thu Aug 02, 2012 3:58 pm
urfankhaliq wrote:Thanks,
Swap: 99 1 98
it's your 98 MB Cached RAM
EDIT: please see my request to show that a percentage is used as cache:
Because i solderded some extra RAM on my device ;-)
No, i set the memory split to 32MB for my GPU. In raspbian you can do this with raspi-config, and there you can set the memory split
urfankhaliq
Thu Aug 02, 2012 4:05 pm
OK thanks,
ill be running the raspi-config when i get home to change that! :)
Bioshox
Thu Aug 02, 2012 8:41 pm
It seems many of you don't like Cached RAM being shown as used RAM on the Control Panel.
I will do some updates tonight and push it live tomorrow for updating to exclude these!
empire
Thu Aug 02, 2012 9:49 pm
Bioshox wrote:It seems many of you don't like Cached RAM being shown as used RAM on the Control Panel.
Indeed. I removed cached memory as one of my first commits with the intention of (eventually) showing the actual and cached RAM as two separate colors on the graph. It would be neat if this could be done, rather than completely removing cached memory (again :P)
urfankhaliq
Fri Aug 03, 2012 2:28 am
hi can someone help me understand why raspcontrol only displays 25gb SD card when I have a 32GB SD card?
below is my fdisk -l output
[email protected]:/home/pi# fdisk -l
WARNING: GPT (GUID Partition Table) detected on '/dev/mmcblk0'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/mmcblk0: 32.5 GB, 32462864384 bytes
4 heads, 16 sectors/track, 990688 cylinders, total 63404032 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000714e9
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 8192 122879 57344 c W95 FAT32 (LBA)
/dev/mmcblk0p2 122880 63404031 31640576 83 Linux
Thanks in advance
EDIT: Sorry my bad. its actually showing 29.7GB! its 25 free lol which is probably right cos you wont get the full 32 GB right?
Bioshox
Fri Aug 03, 2012 11:01 am
Is there any chance you could 'Re-Commit' this so to speak, and I'll work on it display both and being able to clear them?
urfankhaliq wrote:hi can someone help me understand why raspcontrol only displays 25gb SD card when I have a 32GB SD card?
Thanks in advance
Correct, you never get the actual amount free unfortunately :(
tytoons
Fri Aug 03, 2012 2:03 pm
This is fantastic! Really easy to setup, no problems.
