FruityDisplay + FruityWiFi
Posted: Sat Oct 10, 2015 5:53 pm
Site: http://www.fruitywifi.com
GitHub: https://github.com/xtr4nge/FruityDisplay
Forum: http://fruitywifi.boards.net/thread/73/fruitydisplay
Video: https://www.youtube.com/watch?v=8lYwreSSnH0
FruityDisplay v1.0
Allows you to control FruityWiFi using a adafruit-16x2 LCD Display+Keypad.
FruityWiFi needs to be up an running if you want to use the modules screen.
SCREENS
- Home: Welcome screen.
- Modules: List of modules available. START|STOP modules
- Commands: List of commands available. ADD|REMOVE commands in init.conf
- Config: [TO BE IMPLEMENTED]
- Services: [TO BE IMPLEMENTED]
- About: FruityWiFi version and FruityDisplay version.
- Exit
SETUP & REFERENCES
https://learn.adafruit.com/adafruit-16x ... i?view=all
https://learn.adafruit.com/adafruits-ra ... guring-i2c
CONFIG (init.conf)
DEBUG: To debug the screen options without using the LCD display.
SCREEN_MODULES: ENABLE|DISABLE modules on screen. [True|False]
SCREEN_COMMANDS: ENABLE|DISABLE commands on screen. [True|False]
PREFIX: Prefix to be added before an option name on screen.
[api] Setup API details (server and token) to access FruityWiFi.
[white_list] When this option is enabled (True), only the modules in the list are loaded into the LCD.
[black_list] When this option is enabled (True), the modules in the list are excluded from the LCD.
Note: white_list and black_list can be combined.
[commands] Setup commands list. Commands can be ADDED|REMOVED using format: {name}||{command}
DEPENDENCIES
FruityDisplay v1.0
SCREENS
- Exit
SETUP & REFERENCES
CONFIG (init.conf)
DEPENDENCIES
apt-get -y install python-smbus
apt-get -y install i2c-tools
apt-get -y install python-requests
apt-get -y install python-configobj
apt-get -p install python-pip
pip install --upgrade requests
