MissCutiePi
Partkeepr : getting it up and runnng
Wed Sep 16, 2015 8:04 pm
I'm new to Linux and Pi and I got me a Pi to get Partkeepr up and running. I would like to use it for inventory in my home.
It's meant for inventory of electronic parts but is versatile and can be used to keep inventory of just about anything.
http://www.partkeepr.org
http://demo.partkeepr.org
I found out it requires a so called LAMP server, Linux, Apache, MySql and PHP
As I am new to Linux and Pi I thought it would be a nice project to explore.
It does have some requirements though:
https://wiki.partkeepr.org/wiki/Installer
I'm pretty sure I'll run into some problems so I would like to start this thread to get me and anyone else through it.
I found some tutorials:
http://www.geothread.net/building-a-lam ... -computer/
http://www.penguintutor.com/linux/raspberrypi-webserver
http://www.instructables.com/id/Turning ... ng-Apache/
And in another post on this board:
viewtopic.php?p=675522#p675522
DougieLawson wrote:You'll need to install a "LAMP stack", that's Linux, Apache2, MySQL and PHP5. (You've got the "L" with Raspbian Linux.)
Easiest way is
sudo apt-get install phpmyadmin
which should pull in MySQL server, MySQL client, Apache and PHP5 and gives you a MySQL management tool.
Then follow in instructions on the Partkeepr WiKi.
Should this get me started? Keeping all those requirements (https://wiki.partkeepr.org/wiki/Installer) in mind ?
***=== New to Linux and Pi ===***
MissCutiePi
Re: Partkeepr : getting it up and runnng
Thu Sep 17, 2015 12:45 pm
Ok,
So here is what I did so far:
installed: Apache, MySQL and FTP following:
http://www.instructables.com/id/Turning ... all-MySQL/
http://www.instructables.com/id/Turning ... stall-FTP/
http://www.instructables.com/id/Turning ... alization/
installed phpmyadmin following:
http://raspipress.com/2012/09/tutorial- ... pberry-pi/
I am currently following this guide:
http://technologyrealm.blogspot.nl/2014 ... tu-or.html
I get stuck at step 4:
    sudo pear install pear.phpunit.de/PHPUnit pear.phpunit.de/phpcpd pear.phing.info/phing pear.doctrine-project.org/DoctrineORM pear.doctrine-project.org/DoctrineSymfonyYaml pear.doctrine-project.org/DoctrineSymfonyConsole pear.twig-project.org/Twig
    sudo pear install --alldeps phpmd/PHP_PMD-alpha
I installed phpunit using: "sudo apt-get phpunit" That went fine i guess.
Now for: phing, doctrine components and twig
How do I install these ?
Thanks !
BMS Doug
Thu Sep 17, 2015 12:56 pm
MissCutiePi wrote:Ok,
Thanks !
Did you follow step 3 without problems?
3. Update PEAR
pear update-channels
sudo pear upgrade
if so then rather than using apt-get to install the other components you would use pear:
means run (as superuser) the pear program to install PHPUnit from the webaddress pear.phpunit.de/PHPUnit
Each seperate entry (seperated by a space) will be installed, so you will be using pear to install PHPUnit, phpcpd, phing, DoctrineORM, DoctrineSymfonyYaml, DoctrineSymfonyConsole, Twig
Doug.
MissCutiePi
Thu Sep 17, 2015 2:18 pm
I was trying to run those pear install command as user "Pi"
After using"sudo bash" I was able to complete the commands without errors.
Also, when running partkeepr setup you'll get instructions on how to solve the errors encountered
Everything going fine so far
BMS Doug
Thu Sep 17, 2015 2:32 pm
MissCutiePi wrote:I was trying to run those pear install command as user "Pi"
Good to hear, if you have any more problems just ask.
Doug.
MissCutiePi
Thu Sep 17, 2015 9:19 pm
Everything turned out fine.... almost
I followed the steps here:
Then started testing partkeepr.
One of the key features of PARTkeepr is... to add PARTS :) But it doesn't do that now.
Not sure where to start looking for what's wrong :(
EDIT:
Adding fields to the database is helping, populating root category, storage locations and so on
Partkeepr does have its quirks, you just have to fiddle around a little to get to know the software
BMS Doug
Fri Sep 18, 2015 8:28 am
MissCutiePi wrote:Everything turned out fine.... almost
EDIT:
I might have to try Partkeepr one day (but I have many other things to do first).
Doug.
dpenezic
Tue Nov 07, 2017 7:16 am
just to add notice , i did try with latest raspbian /PHP/mariadb/apache and usability is issue. Applications use a lot of resources, and i don suggest to use it for anything else then exercise of SW instalation.
