Huawei E169
Does anybody know how to adapt viewtopic.php?f=36&t=18996&p=806992#p806992 to work with a Huawei E169/620/800 which loads as 12d1:1001 across ttyUSB0-ttyUSB2?
Re: Huawei E169
https://github.com/sk-vpohybe/stopa-mon ... -E620-E800PlanB wrote:Does anybody know how to adapt viewtopic.php?f=36&t=18996&p=806992#p806992 to work with a Huawei E169/620/800 which loads as 12d1:1001 across ttyUSB0-ttyUSB2?
https://shkspr.mobi/blog/2012/07/3g-int ... pi-success
http://www.sakis3g.com
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
Re: Huawei E169
Thnx for the links but I've tried then already. Sakis terminates early when it gets an error response to a pin request & wvdial connects OK but hangs after the 2nd ary DNS is issued. I was hoping I could maybe get somewhere with Huawei's HiLink.
Re: Huawei E169
If you have a RPi B+ or later, you could increase the USB BUS from 600ma to 1200ma if you have a decent 5V2A PSUPlanB wrote:Thnx for the links but I've tried then already. Sakis terminates early when it gets an error response to a pin request & wvdial connects OK but hangs after the 2nd ary DNS is issued. I was hoping I could maybe get somewhere with Huawei's HiLink.
https://projects.drogon.net/testing-set ... berry-pi-b
Re: Huawei E169
Nah not a power supply problem, I've jigged it so the red power light doesn't flicker. Just out of my depth I think, heaps harder than WiFi. Mr. Engman you need to bring your deft hand to this me thinks!
Re: Huawei E169
The device is recognised
& properly connected
strangely though I can't seem to get to it to try some AT cmds
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 008: ID 045e:0750 Microsoft Corp. Wired Keyboard 600
Bus 001 Device 012: ID 12d1:1001 Huawei Technologies Co., Ltd. E169/E620/E800 HSDPA Modem
[ 23.070167] usbserial: USB Serial support registered for GSM modem (1-port)
[ 23.076875] option 1-1.4:1.0: GSM modem (1-port) converter detected
[ 23.129662] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB0
[ 23.147071] option 1-1.4:1.1: GSM modem (1-port) converter detected
[ 23.208793] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB1
[ 23.221767] option 1-1.4:1.2: GSM modem (1-port) converter detected
[ 23.274769] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB2
[ 23.382577] scsi 5:0:0:0: Direct-Access WCDMA MMC Storage 2.31 PQ: 0 ANSI: 2
[ 23.410017] sd 5:0:0:0: Attached scsi generic sg0 type 0
root@harbinger:/home/pi# /dev/ttyUSB0
bash: /dev/ttyUSB0: Permission denied
root@harbinger:/home/pi# sudo /dev/tty/USB0
sudo: /dev/tty/USB0: command not found
Re: Huawei E169
Is the device being set to a USB Mass Storage Device ?
usb_modeswitch toggles device state:
http://manpages.ubuntu.com/manpages/kar ... tch.1.html
Re: Huawei E169
It's in modem mode, the problem seems to be the default route. Normally pppd would end with something like
Mine ends with
The existing default route is my wifi router but i can't figure out why it still wants to use that because I've modified /etc/network/interfaces for the 3g dongle
--> secondary DNS address 85.237.225.250
--> pppd: [10]gv[01]
--> Script /etc/ppp/ip-up run successful
--> Default route Ok.
not replacing existing default route via 10.0.0.138
local IP address 10.168.205.247
remote IP address 10.64.64.64
primary DNS address 10.4.81.103
secondary DNS address 10.4.182.20
Script /etc/ppp/ip-up started (pid 3040)
Script /etc/ppp/ip-up finished (pid 3040), status = 0x0
iface ppp0 inet wvdial
allow hotplug wwan0
iface wwan0 inet dhcp
