mawa85
SD card copy station
Wed Jul 18, 2012 5:35 am
I want to use my PI as an automated SD card copy station during my holidays.
In detail:
I want to stick my SDcard from my camera in a USB card reader and the rPI should automatically incremental copy the new images to a connected USB disk.
I want to go with a debian / raspbian distribution.
Could anyone hint me in the right direction in terms of what is needed to succeed so ?
I thought about rsync, but I'm not sure if there is a better solution.
CCitizenTO
Re: SD card copy station
Wed Jul 18, 2012 9:32 am
cp/mv would do the job ;)
All you need is a shell script to fire when you plug the stuff in.
If you were going to be able to connect to a TV and have a keyboard I'd say dispense with the need for all that and just use the command line to move things over.
mawa85
Wed Jul 18, 2012 11:21 am
thanks for your reply and your hints.
I don't want to connect mouse / keyboard or a TV.
I just found out that I can set udev rules to run scripts, thats probably the way to go.
I will give it a try.
Thanks.
obarthelemy
Wed Jul 18, 2012 11:52 am
Assuming
1- the pictures on your SD card are all in the same directory
2- have unique names, even if you delete your SD (ie, they're not all named pic00001, pic00002... on each and every new SD you put in)
3- are numerous and biggish, so you want to avoid re-copying already copied ones
I would
1- setup a shell script that
1a- checks if there's a card inserted, aborts if there is not, otherwise
1b- checks that the SD is a camera SD card (maybe you can name them different, or check the directory structure, or look for your pics' filename template...)
1b- runs rsync to copy the new pics, and only those, to your USB key
2- setup a cron job to run that script every 15s
In my experience, automatically copying stuff is very disaster-prone. A backup is off-line, so this doesn't really count as a backup until you've checked it, taken the stick out, and put it somewhere different and safe. You might at least want to make the copies read-only to be safer.
There might be an event raised when an SD card is inserted, but I've no clue how that works.
Wed Jul 18, 2012 1:38 pm
mawa85 wrote: I just found out that I can set udev rules to run scripts, thats probably the way to go.
That's what I do on my Debian laptop. When I connect my camera to a USB port a udev rule is triggered which runs a script using rsync to update a NFS share that my wife can access too :)
The udev rule uses the model number of the camera to trigger the script:
(in /etc/udev/rules.d/010-local-rules)
KERNEL=="sd*1",ATTRS{model}=="DMC-FZ7 ",RUN="/usr/local/bin/update_photos.sh"
Various useful shell variables are passed to the script, like ACTION (which should be "add"), ID_MODEL and DEVNAME.
Hope that helps a bit.
mawa85
Fri Jul 20, 2012 5:41 am
Thanks froy all your help, I will hopefully have some time at the weekend to look into it :-)
mawa85
Fri Jul 20, 2012 8:20 am
Maybe I can extend the project to add WiFi in hostapd and install Ajaxplorer to remotly copy and sort the images with my smartphone.
