Pi 2 & Synology box
Posted: Sat Jul 04, 2015 9:53 am
by CCoates
Ive been trying all morning to get the Nas box mounted using all sorts of dffering guides
Is there an easy way to do this??
Re: Pi 2 & Synology box
Posted: Sat Jul 04, 2015 9:59 am
by CCoates
The Nas box is a Synology DS112j
Posted: Sat Jul 04, 2015 7:44 pm
by drgeoff
What OS on the RPi?
Synology NASs support NFS which is the native network file system in Linux. You do have to enable it on the Synology.
Posted: Sat Jul 04, 2015 9:38 pm
by CCoates
Raspbian install from Noobs, I have created a mounting folder. And followed a tutorial but no luck
Posted: Sun Jul 05, 2015 7:47 pm
by CCoates
drgeoff wrote:What OS on the RPi?
I enabled this, all the guides mention it
Posted: Sun Jul 05, 2015 8:39 pm
by morgad
fwiw I have the following line in my /etc/fstab
192.168.1.3:/volume1/dp /home/pi/dp nfs user,nfsvers=4,rw,auto,hard,intr,rsize=8192,wsize=8192,_netdev 0 0
which gives directory lines in the following format
-rwxrwxrwx 1 4294967294 4294967294 367041766 Jan 1 2012 discoveries-prep-orig.zip
drwxrwxrwx 926 4294967294 4294967294 20480 Jun 4 20:10 discoveries-scan
drwxrwxrwx 3 4294967294 4294967294 4096 Jun 20 14:04 Downloads
drwxrwx--- 11 4294967294 4294967294 4096 Jun 22 19:19 Dropbox
where the 4294967294 should read 'pi', no ideas if it works as have not used nfs in anger - just the samba connction to my Windows box
@drgeoff - why do you think Synology supports nfs *properly*? - I saw a note somewhere that to get uid/guid working correctly you had to have a working kerberos server
my 414slim also has problems with -
* ssh (can log in as root, but not a normal user)
* ntp (their config file is rubbish - it ignores any servers you have on your LAN, and they also violate the terms of use for the ntp pool)
* dropbox (sometimes completly ignores files if more than one put at remote end at same time, only fixed by unlinking and re-linking
and these are just the bits I have used so far :(
best regards
Dave
Posted: Sun Jul 05, 2015 10:12 pm
by drgeoff
morgad wrote:
@drgeoff - why do you think Synology supports nfs *properly*? - I saw a note somewhere that to get uid/guid working correctly you had to have a working kerberos server.
Show me the word "properly" in what I wrote. :)
The Synology NAS units which run DSM are Linux boxes.
http://raspberrypi.stackexchange.com/qu ... nology-nas
Posted: Wed Jul 08, 2015 9:09 pm
by CCoates
UPDATE:
I have now managed to mount the drive.
However it is forgotten after each reboot so each time I am having to re run the folloing code in LX Terminal
sudo mount -t nfs 192.168.0.17:/volume1/kodi /mnt/kodi
Is there anyway round this?
Posted: Wed Jul 08, 2015 9:59 pm
by myoung008
CCoates wrote:sudo mount -t nfs 192.168.0.17:/volume1/kodi /mnt/kodi
Add the following to your /etc/fstab:
192.168.0.17:/volume1/kodi /mnt/kodi nfs defaults 0 0
That may or may not be what you're actually looking for, but it is equivalent to your mount command.
