goodgammer1234
Ethernet v.s. WiFi
Sat Jul 31, 2021 1:13 am
so on speed test when i run in multiple connection mode WiFi is faster then Ethernet but signal mode Ethernet is faster why is that i also get 0 upload speed on both
pcmanbob
Re: Ethernet v.s. WiFi
Sat Jul 31, 2021 2:35 pm
So are we to guess all the details of your set up then ? :?
If you want help you have to provide information in detail about your setup etc...
what pi
what OS
what is your wired connection is 100/1000mbs
what you wifi connection type is
how you are testing the speed
goodgammer1234
Sat Jul 31, 2021 10:12 pm
sorry it was my Ethernet cable i was using a yellow one witch is for cameras instead of the gray one witch is for normal Ethernet it is much better but i was using pi4 2gb running twister os i was using 5g wifi and https://www.speedtest.net/ don't know the rest
CaFran1
Sun Aug 01, 2021 3:41 am
Did you try another speedtest like nperf or bitcuco? https://bitcu.co/velocidad-internet/, maybe you will obtain another parameters.
Sun Aug 01, 2021 3:50 am
Using the web browser Speedtest is unreliable, there is a command line version, search the forum as this has been discussed in detail.
Take what I advise as advice not the utopian holy grail, and it is gratis !!
pcmanbob
Sun Aug 01, 2021 9:18 am
This is the one one fruitoftheloom is suggesting, and the one I use https://github.com/sivel/speedtest-cli,
Don't used the one in the the system's package list its out of date.
goodgammer1234
Tue Aug 03, 2021 6:37 pm
thanks for the advice i will keep it in mind next time
