medalto
installing /configuring drupal(9)
Sun Jul 25, 2021 9:28 am
Ive upgraded php to 7.4 and php.info tells me apache is using it .
the Drupal installation told me i needed
  • dom
    gd
    SimpleXML
    xml
apt install php7.4-gd , php7.4-xml etc gave me the required modules
the remaining requirement is
"Your web server does not appear to support any common PDO database extensions. "
its listed as a module
pi@raspberrypi:~ $ php -m | grep PDO
PDO
pi@raspberrypi:~ $
but i cant get it to be recognised
pi@raspberrypi:~ $ a2enmod php7.4-common
ERROR: Module php7.4-common does not exist!
pi@raspberrypi:~ $ sudo apt install php7.4-common
Reading package lists... Done
Building dependency tree
php7.4-common is already the newest version (7.4.21-1+0~20210702.48+debian9~1.gbp9b7c1f).
The following package was automatically installed and is no longer required:
php7.0-gd
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
pi@raspberrypi:~ $ sudo apt install php7.4-pdo
Note, selecting 'php7.4-common' instead of 'php7.4-pdo'
php7.0-gd
pi@raspberrypi:~ $ sudo a2enmod php7.4-common
pi@raspberrypi:~ $
Anyone know what to do next ?
medalto
Re: installing /configuring drupal(9)
Sun Jul 25, 2021 10:50 am
A bit of trial and error , and comaring my ubuntu that works with drupal,
the solution is
sudo apt-get install php7.4-mysql
medalto
Tue Jul 27, 2021 7:45 pm
thanks - got that bit sorted. the remaining persistent requirements is gd module
pi@raspberrypi:~ $ sudo apt-get install php7.4-gd
php7.4-gd is already the newest version (7.4.21-1+0~20210702.48+debian9~1.gbp9b7c1f).
0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
pi@raspberrypi:~ $ sudo a2enmod php7.4-gd
ERROR: Module php7.4-gd does not exist!
pi@raspberrypi:~ $
any suggestions ?
trejan
Tue Jul 27, 2021 8:10 pm
a2enmod enables Apache modules so doesn't know anything about PHP modules. You need to use phpenmod and the module name without the version.
medalto
Tue Jul 27, 2021 9:12 pm
pi@raspberrypi:/home/pi $ php -v
PHP 7.4.21 (cli) (built: Jul 2 2021 15:33:47) ( NTS )
Copyright (c) The PHP Group
Zend Engine v3.4.0, Copyright (c) Zend Technologies
with Zend OPcache v7.4.21, Copyright (c), by Zend Technologies
pi@raspberrypi:/home/pi $ sudo apt-get install php7.4-gd
pi@raspberrypi:/home/pi $ sudo phpenmod gd
WARNING: Module gd ini file doesn't exist under /etc/php/7.3/mods-available
trejan
Tue Jul 27, 2021 11:06 pm
You've got PHP 7.3 and 7.4 installed. 7.4 isn't in the normal repo so you've added something.
You need to tell phpenmod which version of PHP you're trying to change e.g. "phpenmod -v 7.4 gd"
medalto
Sat Jul 31, 2021 7:30 pm
thanks
I started with installing drupal 9, which requires php8.
So i installed php 8
it drupal9/php8 needs mariaDB 10.3
So I tried to upgrade from 10.1 to 10.3
And it told me 10.3 cant run on the pi .
So i then tried to roll back to drupal8 which needs php7.4
Hence the multiple copies of php that I have !
Now sorted !
