Zummey
Find devices connected to switch
Thu Jun 24, 2021 12:10 pm
Hello, I'm trying to setup a network of raspberry pi's. I have a cisco 2960 poe 48 port switch and a couple of pi's.
The main device is a raspberry pi 3 and the other a raspberry pi zero with a rj45 to usb adapter.
They are both plugged into the switch with a poe splitter and are both powered.
I can access the main raspberry remotely over wifi and I'm currently trying to connect to the zero from the main pi.
How do I list the devices on this local network on the main raspberry pi?
B.Goode
Re: Find devices connected to switch
Thu Jun 24, 2021 12:16 pm
There is some possibly relevant documentation from Raspberry Pi here - https://www.raspberrypi.org/documentati ... address.md
Zummey
Thu Jun 24, 2021 12:24 pm
I tried nmap and arp - a but it doesn't list the zero. Does that mean my zero is not configured correctly?
B.Goode
Thu Jun 24, 2021 1:42 pm
That's one possibility.
Or maybe it isn't running? (Does it have a local display/keyboard to verify this?)
What arrangements are in place for IP address configuration on your shared LAN? (Because a c2960 is only a switch, it probably won't be providing 'hub' services such as a dhcp server.)
Does your model of c2960 have an admin/management interface? Can you interrogate that for details of the devices connected to it?
Zummey
Thu Jun 24, 2021 2:44 pm
I can manage the switch through a browser and was able to verify both the raspberry's are connected:
Now I need to assign static ip's to these ports I assume but I have no networking experience so I'll have to do some digging.
B.Goode
Thu Jun 24, 2021 5:47 pm
I can't comment on the 18 hidden MAC addresses, but I only see ONE RPi board in the part of the list you have displayed.
Edit: to add - as pointed out by another poster - that would be because there is indeed only ONE device whose Ethernet MAC has an RPi OUI. All is as it should be. And yes, of course, a shared LAN infrastructure is a pre-requisite...
pcmanbob
Thu Jun 24, 2021 6:32 pm
As you are using a usb to RJ45 network adapter to connect your pi to the switch this the device the switch will list as connected , not the pi.
Your pi is not connected to the switch , it is connected to the usb adapter that is what is connected to the switch, the switch does not know about any devices , your pi zero , that are connected to the adaptor.
epoch1970
Thu Jun 24, 2021 6:40 pm
By looking for IP addresses.
In particular between from your pi3 running Raspios you can reach your pi0 running Raspios with "ping <pi0-host-name>.local".
Zummey
Thu Jun 24, 2021 7:36 pm
I managed to make it happen. In case anyone else comes across the same situation, here are the steps I took:
- access the management area of the switch
- create a vlan with a specific subnet
- assign all switch ports as static access ports to that vlan
- assign a static ip to the raspberry within the subdomain of the vlan in /etc/dhcpcd.conf
