Pijim
Net Bios vs LLMNR issues?
Thu Jun 17, 2021 2:29 pm
I have just bought a compact router (https://www.tp-link.com/uk/home-network ... l-wr902ac/) for a project I am doing that needs a small wifi network for a Pi4 and a number of Zeros to be able to communicate. I can connect them all to the network, but if I try and use VNC to connect between them it won't let me, nor does it seem that the remote GPIO system works. I can connect to them all from a windows 10 laptop connected to the network which also has VNC installed. I have tried using both hostnames and ip addresses to do the connection. Is it something to do with the fact that the router potentially doesn't support Net-Bios? Is there something I could install on the Pi's to get around this?
drgeoff
Re: Net Bios vs LLMNR issues?
Thu Jun 17, 2021 2:38 pm
Can you ping between the RPis?
thagrol
Thu Jun 17, 2021 3:13 pm
Unlikely. Netbios is pretty much a dead protocol these days. Using IP addresses bypasses it anyway.
You describe the device as a router. That implies it has two sides with NAT between them. Which side of the NAT/firewall the respective devices are could be a factor.
Another possibility if some dievices are WiFI and some are wired is a routing issues between wired and WiFi networks.
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
Pijim
Fri Jun 18, 2021 5:40 am
Thanks for that, I'll have a go at pinging them and see what happens.
All the pi's are on the same "side" of the router, connected to a wifi network, no cables.
I'd hoped to be able to get them working with hostnames instead of ip addresses as I also end up moving them between two wifi networks. One works with hostnames quite happily, but can't recreate it with the smaller more mobile wifi adapter.
thagrol
Fri Jun 18, 2021 10:55 am
Might be a DNS/DHCP issue.
Have you tried hostname.local?
