PhilE
Re: CYW43455 (3B+, 4B, CM4) WiFi feedback thread
Thu Jan 21, 2021 3:47 pm
Your routing question is better asked in a separate topic. Take some time to explain your setup, what you expect to happen and what the reality is.
I can't recommend specific WiFi adaptors, but searching for "best wifi adaptor for raspberry pi" returns many promising pages.
Waldnerr
Thu Jan 28, 2021 3:46 pm
Hi all , is this WiFi clm_blob file needed after recent wifi firmware update or it's something different ??
Thanks a lot !
PhilE
Thu Jan 28, 2021 3:56 pm
The clm_blob file defines the channels that are available in each region, the rules associated with them, and how much power should be used for each one. It should be independent of firmware version, but you are advised to use the latest clm_blob.
Waldnerr
Thu Jan 28, 2021 4:45 pm
Ok , thanks a lot !
NanoApe
Sun Mar 14, 2021 8:17 am
After updating, I set reg to CN by using `iw reg set CN`, but some some channels(52, 56, 60, 64) are still missing.
Related issue: https://github.com/raspberrypi/firmware/issues/1359
dasl
Fri Apr 16, 2021 6:15 pm
Hi, just wondering if there's an estimate on when this new clm_blob file will be released more generally and out of the "testing" phase? If I understand correctly, it is not yet available by upgrading raspbian -- it still has to be manually applied for now. https://www.raspberrypi.org/documentati ... pdating.md
EDIT: I see that on a recently provisioned raspberry pi of mine, the clm_blob file has the new version now. So I guess this is no longer in "testing" phase and has now been released.
I confirmed this via the following steps:
In this post: viewtopic.php?f=36&t=291824&start=25#p1768601
PhilE said we should actually use the 43456 on the 4B (announcement thread was here: viewtopic.php?f=117&t=291688 ). In other words, he was suggesting we use the clm_blob file designed for the pi 400 on the pi 4B.
Downloading that brcmfmac43456-sdio.clm_blob file, I see the sha1sum is:
% sha1sum ~/Downloads/brcmfmac43456-sdio.clm_blob
0faafcdcadc5e0a9bb3e86dbb119356e7c3f448e  /Users/dasl/Downloads/brcmfmac43456-sdio.clm_blob
And on a newly provisioned raspberry pi 4B of mine, I see the same sha1sum in the 43455 file (note the last digit 5 vs 6!):
% sha1sum /lib/firmware/brcm/brcmfmac43455-sdio.clm_blob
0faafcdcadc5e0a9bb3e86dbb119356e7c3f448e  /lib/firmware/brcm/brcmfmac43455-sdio.clm_blob
