helder50
Ampps
Thu Mar 26, 2020 5:09 pm
After installing Ampps in Raspbian i can't get it to work, after the command sudo ./Ampps in the location i get this error:
./Ampps: 1: ./Ampps: Syntax error: "(" unexpected
Can you help?
B.Goode
Re: Ampps
Thu Mar 26, 2020 5:45 pm
Welcome to the Raspberry Pi forums.
Can you help?
It is probably not possible to help without further detail.
Can you post here the content of the file Ampps ?
Re: Ampps
Thu Mar 26, 2020 5:56 pm
Can you help?
What did you actually install ?
All I can find is an x86-64 Linux Download:
https://ampps.com/download
Retired disgracefully.....
......to an uncomplicated life !
B.Goode
Re: Ampps
Thu Mar 26, 2020 7:41 pm
Apart from 'softaculous' - whatever that is - there is a Raspberry Pi 'official' project that accomplishes pretty much the same thing using their supported Raspbian Buster Operating System, not Centos.
https://projects.raspberrypi.org/en/pro ... -wordpress
helder50
Re: Ampps
Thu Mar 26, 2020 8:13 pm
Hi, in attach the file Ampps and the installation.
https://drive.google.com/drive/folders/ ... sp=sharing
I want to use my raspberry to use as as web hosting but just for my home and explore. Thats why the softaculous because it has many web apps.
helder50
Re: Ampps
Thu Mar 26, 2020 9:24 pm
Hi saw that tutorial, I’m searching something with more than just the Wordpress.
Any suggestion?
Re: Ampps
Fri Mar 27, 2020 4:44 am
Yes as already stated the file you downloaded is for x86 CPU Architecture.
The Raspberry Pi SBC is ARM CPU Architecture.
