MathiasS
Router + Wifi AP + LTE Internet
Sat Nov 16, 2019 11:10 pm
Trying to configure my pi (Raspberry Pi 2 Model B Rev 1.1/jessie) as a three-way intersection, wlan0 and eth0 is my LAN and eth1 is my internet (LTE)
I got the eth0 to internet to work
Hotspot and DHCP working on wlan0 but I can´t get internet on wlan0 and I can´t get eth0 and wlan0 to talk to each other.
im using iptables to connect eth0 to eth1:
sudo iptables -t nat -A POSTROUTING -o eth1 -j MASQUERADE
sudo iptables -A FORWARD -i eth1 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i eth0 -o eth1 -j ACCEPT
/etc/dhcp/dhcpd.conf:
# Sample configuration file for ISC dhcpd for Debian
# The ddns-updates-style parameter controls whether or not the server will
# attempt to do a DNS update when a lease is confirmed. We default to the
# behavior of the version 2 packages ('none', since DHCP v2 didn't
# have support for DDNS.)
ddns-update-style none;
# option definitions common to all supported networks...
#option domain-name "example.org";
#option domain-name-servers ns1.example.org, ns2.example.org;
default-lease-time 600;
max-lease-time 7200;
# If this DHCP server is the official DHCP server for the local
# network, the authoritative directive should be uncommented.
authoritative;
# Use this to send dhcp log messages to a different log file (you also
# have to hack syslog.conf to complete the redirection).
log-facility local7;
# No service will be given on this subnet, but declaring it helps the
# DHCP server to understand the network topology.
#subnet 10.152.187.0 netmask 255.255.255.0 {
# This is a very basic subnet declaration.
#subnet 10.254.239.0 netmask 255.255.255.224 {
#  range 10.254.239.10 10.254.239.20;
#  option routers rtr-239-0-1.example.org, rtr-239-0-2.example.org;
# This declaration allows BOOTP clients to get dynamic addresses,
# which we don't really recommend.
#subnet 10.254.239.32 netmask 255.255.255.224 {
#  range dynamic-bootp 10.254.239.40 10.254.239.60;
#  option broadcast-address 10.254.239.31;
#  option routers rtr-239-32-1.example.org;
# A slightly different configuration for an internal subnet.
#subnet 10.5.5.0 netmask 255.255.255.224 {
#  range 10.5.5.26 10.5.5.30;
#  option domain-name-servers ns1.internal.example.org;
#  option domain-name "internal.example.org";
#  option routers 10.5.5.1;
#  option broadcast-address 10.5.5.31;
#  default-lease-time 600;
#  max-lease-time 7200;
# Hosts which require special configuration options can be listed in
# host statements.   If no address is specified, the address will be
# allocated dynamically (if possible), but the host-specific information
# will still come from the host declaration.
#host passacaglia {
#  hardware ethernet 0:0:c0:5d:bd:95;
#  filename "vmunix.passacaglia";
#  server-name "toccata.fugue.com";
# Fixed IP addresses can also be specified for hosts.   These addresses
# should not also be listed as being available for dynamic assignment.
# Hosts for which fixed IP addresses have been specified can boot using
# BOOTP or DHCP.   Hosts for which no fixed address is specified can only
# be booted with DHCP, unless there is an address range on the subnet
# to which a BOOTP client is connected which has the dynamic-bootp flag
# set.
#host fantasia {
#  hardware ethernet 08:00:07:26:c0:a5;
#  fixed-address fantasia.fugue.com;
# You can declare a class of clients and then do address allocation
# based on that.   The example below shows a case where all clients
# in a certain class get addresses on the 10.17.224/24 subnet, and all
# other clients get addresses on the 10.0.29/24 subnet.
#class "foo" {
#  match if substring (option vendor-class-identifier, 0, 4) = "SUNW";
#shared-network 224-29 {
#  subnet 10.17.224.0 netmask 255.255.255.0 {
#    option routers rtr-224.example.org;
#  subnet 10.0.29.0 netmask 255.255.255.0 {
#    option routers rtr-29.example.org;
#  pool {
#    allow members of "foo";
#    range 10.17.224.10 10.17.224.250;
#  pool {
#    deny members of "foo";
#    range 10.0.29.10 10.0.29.230;
#wlan0 and eth0
subnet 192.168.1.0 netmask 255.255.255.0 {
	range 192.168.1.10 192.168.1.30;
	option broadcast-address 192.168.1.255;
	option routers 192.168.1.1;
	option domain-name "local";
	option domain-name-servers 8.8.8.8, 8.8.4.4;
#not used, from old config with diffrent subnet on eth0 and wlan0
subnet 192.168.0.0 netmask 255.255.255.0 {
	range 192.168.0.10 192.168.0.29;
	option broadcast-address 192.168.0.255;
	option routers 192.168.0.1;
/etc/network/interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet static
    address 192.168.1.1
auto eth1
allow-hotplug eth1
iface eth1 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
    address 192.168.1.2
bls
Re: Router + Wifi AP + LTE Internet
Sat Nov 16, 2019 11:23 pm
authoritative;
#host passacaglia {
# set.
#host fantasia {
#class "foo" {
#  pool {
#  pool {
#wlan0 and eth0
auto lo
auto eth0
allow-hotplug eth0
    address 192.168.1.1
auto eth1
allow-hotplug eth1
auto wlan0
allow-hotplug wlan0
    address 192.168.1.2
Don't think it will work with both eth0 and wlan0 (on the pi) in the same subnet. Change eth0 address to 192.168.0.1 and the router in dhcpd config from 192.168.1.1 to 192.168.0.1 and you'll be in better shape. Also, you'll retain more of your sanity if you remove or comment out stuff in dhcpd conf that you're not using.
You also didn't mention whether you've set net.ipv4.conf.all.forwarding = 1. Packets won't get forwarded between the two networks without this...
MathiasS
Sat Nov 16, 2019 11:39 pm
I got it to work if i remove eth0 from INTERFACES="eth0 wlan0"
or if i set static address to my client with route 192.168.1.1 (eth0), if I use route 192.168.0.1 I can´t connect to the 192.168.1.0 subnet
/etc/default/isc-dhcp-server
# Defaults for isc-dhcp-server initscript
# sourced by /etc/init.d/isc-dhcp-server
# installed at /etc/default/isc-dhcp-server by the maintainer scripts
# This is a POSIX shell fragment
# Path to dhcpd's config file (default: /etc/dhcp/dhcpd.conf).
#DHCPD_CONF=/etc/dhcp/dhcpd.conf
# Path to dhcpd's PID file (default: /var/run/dhcpd.pid).
#DHCPD_PID=/var/run/dhcpd.pid
# Additional options to start dhcpd with.
#	Don't use options -cf or -pf here; use DHCPD_CONF/ DHCPD_PID instead
#OPTIONS=""
# On what interfaces should the DHCP server (dhcpd) serve DHCP requests?
#	Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACES="wlan0"
MathiasS
Sat Nov 16, 2019 11:48 pm
authoritative;
#host passacaglia {
# set.
#host fantasia {
#class "foo" {
#  pool {
#  pool {
#wlan0 and eth0
auto lo
auto eth0
allow-hotplug eth0
    address 192.168.1.1
auto eth1
allow-hotplug eth1
auto wlan0
allow-hotplug wlan0
    address 192.168.1.2
Sorry about not removing the commented lines.
I didn´t know about net.ipv4.conf.all.forwarding = 1 , now I changed the router to 192.168.0.1 and it´s all working, but before i removed eth0 from INTERFACES="wlan0" I got served address 192.168.1.10 on a wlan device.
