dorian-ny
Re: How do I mount NAS Network Shares
Sat Nov 09, 2019 4:34 am
crooss your fingers and hope for the best.
let us know how it blows
Donnelly
Sat Nov 09, 2019 3:02 pm
dorian-ny,
Rerbooted. Fingers crossed.
No joy.
PLEX does not see the share. Closed PLEX.
I then used command: sudo mount -a
No errors.
Started PLEX, and PLEX saw the share and ran movie file(s).
hmmm....next steps?
Thanks,
Dave
Thanks,
Dave
dorian-ny
Sat Nov 09, 2019 3:09 pm
damn. the script starts after networking but it is likely networking up simply initializes networking and doesn't wait for it to be accessible.
Will have to modify script to make sure we have network access before mounting.
Donnelly
Sat Nov 09, 2019 3:23 pm
dorian-ny,
Ok. Here is something strange.
Prior to the script being implemented, I would navigate to the /mnt/Media/pi folder and see the share contents. When I navigate to /mnt/Media/pi now, there are no contents. Yet, PLEX will play media files from the share. uh?
Thanks,
Dave
Thanks,
Dave
dorian-ny
Sat Nov 09, 2019 3:29 pm
The script doesn't do anything other then execute a "mount -a"
Donnelly
Sat Nov 09, 2019 3:32 pm
dorian-ny,
ok...but I should be able to see the share contents - right? Maybe a new issue...to be addressed after the mount issue.
Thanks,
Dave
Thanks,
Dave
dorian-ny
Sat Nov 09, 2019 3:36 pm
There seems to be a network-online service so
in /lib/systemd/system/mount-network-shares.service replace
After=network.target
with
After=systemd-networkd-wait-online.service
Requires=systemd-networkd-wait-online.service
then execute
sudo sudo systemctl daemon-reload
Donnelly
Sat Nov 09, 2019 4:04 pm
dorian-ny,
Will do. Have to step out for a couple of hours. Will adjust when I get back.
Thanks,
Dave
Thanks,
Dave
Donnelly
Sat Nov 09, 2019 6:20 pm
doria-ny,
Ok - i'm back.
made suggested change
with
then executed
no errors
then rebooted.
no joy.
using file manager, showed nothing in directory /mnt/Media/pi
then executed sudo mount -a
went back to using file manager, navigated to directory /mnt/Media/pi...now all the files in the share are visible...and media files will play.
Also verified PLEX functions normally.
OPS !! MY BAD !
Then I noticed I did not make the full substitution/correction. I left out "Requires=systemd-networkd-wait-online.service".
So - went back, edited /lib/systemd/system/mount-network-shares.service replaced and verified (!) I made the correct...corrections.
executed sudo sudo systemctl daemon-reload
no errors
rebooted.
no joy.
PLEX does not see or play media files.
Also - now...nothing shows up in /mnt/Media/pi.....? (pls note from above - it did have contents. The script is changing something...??)
next steps?
Thanks,
Dave
Thanks,
Dave
Donnelly
Sat Nov 09, 2019 6:58 pm
dorian-ny,
Just for clarity....here is what the script looks like:
[Unit]
Description=mount network shares
[Service]
Type=simple
User=root
WorkingDirectory=/home/pi
ExecStart=/bin/mount -a
[Install]
Wantedby=multi-user.target
standing by....
Dave
Thanks,
Dave
dorian-ny
Sat Nov 09, 2019 7:25 pm
can you do a
journalctl | grep systemd-net
Donnelly
Sat Nov 09, 2019 7:32 pm
yup. done. now...how do i copy to post results here?
Thanks,
Dave
Donnelly
Sat Nov 09, 2019 7:46 pm
Results:
Nov 09 10:13:36 PMS systemd-networkd[148]: enumeration completed
Nov 09 10:13:36 PMS systemd-networkd-wait-online[163]: ignoring: Lo
Nov 09 10:13:37 PMS systemd-networkd-wait-online[163]: ignoring: Lo
Nov 09 10:13:39 PMS systemd-networkd-wait-online[163]: ignoring: Lo
Nov 09 10:13:42 PMS systemd-networkd-wait-online[163]: ignoring: Lo
Nov 09 10:13:47 PMS systemd-networkd-wait-online[163]: ignoring: Lo
Nov 09 10:13:47 PMS systemd-networkd[148]: eth0: Gained carrier
Nov 09 10:13:49 PMS systemd-networkd[148]: eth0: Gained IPv6LL
Nov 09 10:13:46 PMS systemd-networkd-wait-online[163]: ignoring: Lo
Thanks,
Dave
dorian-ny
Sat Nov 09, 2019 11:07 pm
add to line following After=systemd-networkd-wait-online.service
execute
Donnelly
Sat Nov 09, 2019 11:08 pm
dorian-ny,
working it....
Thanks,
Dave
Donnelly
Sat Nov 09, 2019 11:10 pm
dorian-ny,
that line is already there. Pls see post of 10:58am today for what script currently looks like.
Thanks,
Dave
Donnelly
Sat Nov 09, 2019 11:13 pm
dorian-ny,,,
you have had me execute sudo sudo systemctl daemon-reload.
but in your last post you say: sudo systemctl daemon-reload.
Should there be 1 or 2 "sudo"....in the command?
Thanks,
Dave
dorian-ny
Sun Nov 10, 2019 12:11 am
#sorry sometimes I misspell the correct commands are
sudo systemctl enable mount-shares
Donnelly
Sun Nov 10, 2019 12:43 am
No problem.
I running errands.....will be back in a couple of hours or so.
When I get back.......what sequence of steps should I do?
Thanks,
Dave
Donnelly
Sun Nov 10, 2019 2:25 am
dorian-ny,
I am back.
executed both commands.
no errors
error: Failed to enable unit: Unit file mount-shares.service does not exist.
I verified the file does exist in the /lib/systemd/system
Rebooted system.
executed commands:
no errors
standing by for next steps.
Thanks,
Dave
Donnelly
Thu Nov 14, 2019 4:07 pm
dorian-ny,
Any suggested next steps?
Thanks,
Dave
