maffy
Raspberry pi 4b creates hotspot that has no internet
Fri Oct 25, 2019 3:27 pm
Hello, I am a beginner at raspberry pi. However, I've crossed a huge problem. For the last month, I've been trying to set up raspberry pi's hotspot that has internet. However, it doesn't have one.
The raspberry pi creates an access point (hotspot) and I am able to connect to it from my laptop, however, there is no internet ( I am unable to visit any sites or do anything with that internet)
I've tried many different guides such as:
https://www.raspberrypi.org/documentati ... s-point.md
https://learn.sparkfun.com/tutorials/se ... -point/all#
and etc.
And none of them works.
My setup is :
Raspberry pi 4b
OS: raspbian buster
USB dongle: Huawei e3372
my raspberry pi's configs are:
Routes:
dhcpcd.conf file:
interface wlan0
static ip_address=192.168.4.1/24
nohook wpa_supplicant
dnsmasq.conf file:
interface=wlan0
dhcp-range=192.168.4.2,192.168.4.20,255.255.255.0,24h
hostapd.conf file:
interface=wlan0
driver=nl80211
ssid=NameOfNetwork
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=AardvarkBadgerHedgehog
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
Daemon Conf:
DAEMON_CONF="/etc/hostapd/hostapd.conf"
sysctl.conf file:
net.ipv4.ip_forward=1
iptables:
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
They are saved in:
/etc/ipatbles.ipv4.nat
I would appreciate any information regarding this topic.
Thanks in advance.
Edit note:
The raspberry pi itself has internet - it can ping to 8.8.8.8 without any problems. But the hotspot itself has no internet.
epoch1970
Re: Raspberry pi 4b creates hotspot that has no internet
Fri Oct 25, 2019 4:57 pm
Your ethernet (?) interface with the default gateway appears to be called eth1, not eth0.
Try
sudo iptables -t nat -A POSTROUTING -o eth1 -j MASQUERADE
maffy
Sat Oct 26, 2019 4:56 pm
All of the above suggestions are not working. The first IP table change to change for eth1 has no effect.
And the second answer has all the same things, that are happening in our case and is not able to provide any internet access
maffy
Sun Oct 27, 2019 6:15 pm
Quick edit note: when I am using the second suggestion and typing the command - "hotspot try" I am getting an error - dhcp is waiting for ipaddr for wlan0. Can anyone suggest what is the problem here?
dorian-ny
Sat Nov 02, 2019 2:23 am
Does the wireless client have an ip adress? can it ping the raspberry?
issue a iptables -L -n so we can see the firewall config
maffy
Thu Nov 07, 2019 7:42 pm
hello, thank you for the reply, here is the firewall photo:
Sorry for the late reply.
dorian-ny
Thu Nov 07, 2019 7:55 pm
Have you enabled ip forwarding?
cat /proc/sys/net/ipv4/ip_forward
do a
netstat -M
as well
maffy
Thu Nov 07, 2019 8:27 pm
yes, I have done that in, however i am getting this thing - here is a photo.
dorian-ny
Thu Nov 07, 2019 8:34 pm
That's strange forwarding is enabled but it says no support for masquarading
Try
sudo iptables -t nat -L -n -v
maffy
Thu Nov 07, 2019 8:40 pm
Any ideas, why this is happening?
dorian-ny
Thu Nov 07, 2019 8:41 pm
try
You also don't seem to have a default route in dnsmasq.conf
add
domain=lan # Local wireless DNS domain
address=/gw.lan/192.168.4.1 #or whatever the wlan0 ip is
maffy
Thu Nov 07, 2019 8:51 pm
Your previous edited post with something - echo 1 and etc helped me!
Could you re-edit that post and sent the whole text here, because maybe someone will use it in the future
dorian-ny
Thu Nov 07, 2019 8:58 pm
This enable ip_forwarding on boot: edit /etc/systctl.conf
uncommend line
#net.ipv4.ip_forward=1 (remove #)
echo 1 > /proc/sys/net/ipv4/ip_forward
This enables forwarding without reboot
readd iptables forwarding
dorian-ny
Thu Nov 07, 2019 9:01 pm
FYI any particular reason you are running the wifi in G mode?
perhaps you shoud update your hostapd conf to run N instead
change hw_mode=g to
hw_mode=a
and add
# N
ieee80211n=1
maffy
Thu Nov 07, 2019 9:09 pm
I was just following the guide which showed me to write hw_mode = g. Is there a difference between g and a modes?
dorian-ny
Thu Nov 07, 2019 9:24 pm
wifi g is very old and lmited to 56mbs
Any device made in the past 5 to 10 years should be fine with N
you can also enable N in 5ghz channels which will give you 300mbs (most devices made in the past 5 years will support 5ghz)
with
change
channel=7 to channel=40
# N
ieee80211n=1
require_ht=1
ht_capab=[MAX-AMSDU-3839][HT40-][SHORT-GI-20][SHORT-GI-40]
maffy
Thu Nov 07, 2019 9:28 pm
Okay! Thank you for the incredible feedback and for your precious time. You've helped me a lot with this project.
maffy
Fri Nov 08, 2019 11:23 am
]Additional question. I've came across one problem.
When I add this line in IP tables:
and
It works, however. I want to make my IP tables to go through tor.
I've found a guide - https://lifehacker.com/how-to-anonymize ... 1793869805
and when I add these lines -
sudo iptables -t nat -A PREROUTING -i wlan0 -p tcp --dport 22 -j REDIRECT --to-ports 22
sudo iptables -t nat -A PREROUTING -i wlan0 -p udp --dport 53 -j REDIRECT --to-ports 53
sudo iptables -t nat -A PREROUTING -i wlan0 -p tcp --syn -j REDIRECT --to-ports 9040
Here are my IP tables and routes :
The wifi stops working but has an access point. Any ideas on how I can fix this problem to work?
dorian-ny
Fri Nov 08, 2019 3:08 pm
First lest make sure tor is running properly.
Do a
sudo systemctl status tor
and
cat /var/log/tor/notices.log
maffy
Fri Nov 08, 2019 4:15 pm
sudo systemctl shows that tor is active
ant here is cat log:
dorian-ny
Fri Nov 08, 2019 10:17 pm
hmm there doesn't seem to be anything obviously wrong.
Lets see whats working and whats not.
From client (assuming windows) open cmd.exe
ping -n 2 192.168.4.1
ping -n 2 1.1.1.1
tracert -d 1.1.1.1
nslookup www.google.com
maffy
Sat Nov 09, 2019 7:28 am
Here is a photo you requested.
dorian-ny
Sat Nov 09, 2019 2:17 pm
well that shows internet to be working so I assume you haven't started tor.
start tor and redo test
maffy
Sun Nov 10, 2019 6:58 pm
Tor is running :
and routes and other things:
