BigSur
2048 bit RSA too quick to generate?
Sat Apr 14, 2018 11:21 pm
Here's my setup:
- Raspberry Pi 3 B+
- Raspbian Stretch 2018-3-13
- Open VPN installed via PiVPN script (curl -L https://install.pivpn.io | bash)
- I opted for the new 2.4 standard as I'll only have up-to-date clients connecting.
The 2048 bit RSA private key generated in under 20 seconds. On my test system (Raspbian for desktop in a VM on a Quad i7) it took about 7 minutes to generate. Here's the output from this install:
Generating a 2048 bit RSA private key
writing new private key to '/etc/openvpn/easy-rsa/pki/private/xxxxxxxxxxxxxxx.for.my.privacy
FWIW, there were no errors, and the ovpns profile is fine, and the VPN connects great. I'm concerned there may be a potential hole here as it just seemed to generate too quickly!
Any opinions are appreciated.
ShiftPlusOne
Re: 2048 bit RSA too quick to generate?
Sat Apr 14, 2018 11:27 pm
Don't know how they're generated, so just taking a guess, but perhaps the VM didn't have enough entropy whereas actual running hardware did? Isn't that a common problem with generating keys in VMs?
BigSur
Sun Apr 15, 2018 12:48 am
Thanks for the reply!
This is my first attempt at setting up OpenVPN and I’ve read others’ stories about it taking hours. I’m hoping some first hand experiences on similar hardware will provide some perspective.
IanS
Mon Apr 16, 2018 9:12 am
I have a Pi 2B acting as an OpenVPN gateway. From memory, generating keys on that was a 'sit and wait' delay for 1024 bit, but a 'go for a large coffee' for 2048 bits. Neither was close to 'come back in the morning'. Obviously a model 3 will be somewhat faster. Can you post the exact command you are using?
BigSur
Mon Apr 16, 2018 10:37 pm
Hey IanS, I don't know the exact command as it was all part of the PiVPN script.
(https://raw.githubusercontent.com/pivpn ... install.sh)
It was so fast to generate, it only printed 2 lines of progress and then completed. Must have been under 20-30 seconds. Could a Pi 3 be that much faster than a 2?
jahboater
Tue Apr 17, 2018 8:43 am
ARMv8 has some special hardware instructions for doing this, which if used, make the process a couple of orders of magnitude faster. But I don't know if they are available in 32-bit mode.
