algoalgoalgo
How to connect two Raspberry pi zero with Raspberry3?
Tue Feb 13, 2018 12:21 pm
i tried to connect both raspberrypi zero([email protected]) and raspberrypi zero Wireless([email protected]) with raspberry pi 3([email protected]) via usb.Take a pictures from raspbery pi zero's cameras and send them raspberry pi 3 via ssh.
(Firstly i made a proper configuration(create empty ssh file /boot and edit cmdline.txt and config.txt) both raspberry pi zero )
[email protected]:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.101  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::c1e9:f16f:fe75:57e3  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:92:65:7f  txqueuelen 1000  (Ethernet)
        RX packets 106  bytes 8042 (7.8 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 36  bytes 4912 (4.7 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 169.254.211.188  netmask 255.255.0.0  broadcast 169.254.255.255
        inet6 fe80::6bf3:7c50:8b01:f374  prefixlen 64  scopeid 0x20<link>
        ether a6:d6:5b:ed:4f:df  txqueuelen 1000  (Ethernet)
        RX packets 91  bytes 6919 (6.7 KiB)
        TX packets 35  bytes 5791 (5.6 KiB)
usb1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 169.254.3.120  netmask 255.255.0.0  broadcast 169.254.255.255
        inet6 fe80::6583:f6eb:6584:3fd4  prefixlen 64  scopeid 0x20<link>
        ether 26:78:bf:dd:ea:cc  txqueuelen 1000  (Ethernet)
        RX packets 74  bytes 6366 (6.2 KiB)
        TX packets 38  bytes 6037 (5.8 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:c7:30:2a  txqueuelen 1000  (Ethernet)
(raspberry pi 3 connected internet with ethernet cable)
[email protected]:~ $sudo ssh [email protected]
(succesfully connected.)
ssh : connect to host rspz.local port 22: No route to host
[email protected]:~ ping rspzw.local
(succesfully ping)
[email protected]:~ ping rspz.local
Destination host unreachable
modified 3 of them /etc/ssh/sshd_config
Port 22
port 26
[email protected]:~ $sudo ssh [email protected] -p 22
(succesfully connected)
[email protected]:~ $sudo ssh [email protected] -p 26
ssh : connect to host rspz.local port 26: No route to host
how can i connect both with raspberry pi 3 (via ssh )
SurferTim
Re: How to connect two Raspberry pi zero with Raspberry3?
Tue Feb 13, 2018 1:38 pm
Both usb devices have the same subnet. Run this from a console:
route
The device with the lowest metric will be used for that subnet.
My advice is use different subnets on each usb device.
Edit: Or bridge the two usb interfaces. I haven't tried this.
