o5i
How to setup static eth0 and dhcp wlan0 on stretch?
Thu Oct 12, 2017 9:46 am
I have tried to setup the eth0 connection to a static ip using the dhcpcd.conf but it seems dhcpcd ignores the settings.
# Static IP configuration for eth0.
interface eth0
static ip_address=192.168.1.1/24
I have tried changing the interfaces too but in that case i loose the wlan connection so i left how it was.
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
        wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
auto eth0
allow-hotplug eth0
iface eth0 inet manual
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether b8:27:eb:7a:02:7f brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:2f:57:2a brd ff:ff:ff:ff:ff:ff
    inet 192.168.2.13/24 brd 192.168.2.255 scope global wlan0
    inet6 fe80::de6e:c202:6579:d8f1/64 scope link
How to fix this?
SurferTim
Re: How to setup static eth0 and dhcp wlan0 on stretch?
Thu Oct 12, 2017 10:23 am
This should be the only uncommented line in /etc/network/interfaces
Remove everything else, reboot and post the output of ifconfig.
Edit: This applies only to Stretch! Jessie has entries in /etc/network/interfaces.
coopi
Sun Oct 15, 2017 5:51 pm
Quite some people face the same problem that Stretch' dhcpcd does not handle fix ip well this days.
I have just built an Access Point (uap0, need fix ip itself) + wireless client (wlan0, get ip from router) on my zero w. As a temporary fix, I only put wlan0 in /etc/network/interfaces and have ip commands (i.e. ip link set dev uap0 up, ip addr add ...) in script that run by /etc/rc.local to setup fix ip for uap0.
Even though my AP is working properly (Android phone connect to it can get access to internet), I still get "failed" error when running systemctl status dhcpcd. I think it is a stretch's problem and have to wait till them to fix it.
SurferTim
Sun Oct 15, 2017 6:37 pm
@coopi: Post a link to the setup you are using, or what you are trying. Normally dhcpcd service will fail if you put anything like "iface wlan0" in /etc/network/interfaces.
coopi
Sun Oct 15, 2017 6:58 pm
Okay, just for reference cause it is not directly relevant to the topic I think.
I have
auto lo
auto wlan0
iface wlan0 inet dhcp
append to the default lines w/o comment out the interfaces.d one inside /etc/network/interfaces.
I have the fixed ip uap0 constructed in a script for my hostapd.conf. Only quote some relevant lines below
iw dev wlan0 interface add uap0 type __ap
ip addr add 192.168.50.1/24 broadcast 192.168.50.255 dev uap0
And, yes, dhcpcd.service is reported failed. But my wlan0 does receive ip assinged to it.
SurferTim
Sun Oct 15, 2017 9:23 pm
This is for an AP and client on the same wireless interface. I think I have everything here. I'm still testing it.
This is for Stretch ONLY!
DO NOT MODIFY /etc/network/interfaces FILE! The only uncommented line in that file should be
First, insure your OS is up to date.
sudo apt-get update
sudo apt-get upgrade
Open /etc/wpa_supplicant/wpa_supplicant.conf with a text editor.
Save as /etc/wpa_supplicant/wpa_supplicant-wlan0.conf.
Add this to wpa_supplicant-wlan0.conf
network={
   ssid="MySSID"
   psk="MyPassphrase"
There should be no network entries in wpa_supplicant.conf!
Then install the modules.
sudo apt-get install dnsmasq hostapd
Edit /etc/rc.local and add this above "exit 0". Note that is two underscores.
The /etc/dhcpcd.conf addition:
interface uap0
static ip_address=192.168.4.1/24
The /etc/dnsmasq.conf file. This is all that should be in this file.
interface=uap0
dhcp-range=192.168.4.20,192.168.4.100,255.255.255.0,12h
The /etc/hostapd/hostapd.conf file. Change the ssid and wpa_passphrase.
interface=uap0
driver=nl80211
ssid=RPiNet
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=mypassphrase
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
Edit /etc/default/hostapd, uncomment and change this:
DAEMON_CONF="/etc/hostapd/hostapd.conf"
Edit /etc/sysctl.conf and uncomment
net.ipv4.ip_forward=1
My iptables rule.
sudo iptables -t nat -A  POSTROUTING -o wlan0 -j MASQUERADE
Then make the iptables rule permanent.
sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
Then in /etc/rc.local, add this below the iw line:
iptables-restore < /etc/iptables.ipv4.nat
reboot
Edit: You may need to reboot twice. The first reboot may not bring up wlan0 connected, but the second reboot should.
pitibonom
Sat Jan 13, 2018 5:48 pm
hmmmm seem it don't work but....
sounds like it's on the way 8-D
what i'm supposing is that there is a titanic mess between dhcp thingies.
dhcpd wich is a client
dnsmasq wich is a server aaaaand maybe..... something like a client, but not, but maybe XD
interfaces file ( would be nice from the devs to hear ( or not ) that this file is unused on stretch ! or maybe yes ? or maybe maybe ??? )
okay guys.... am a dev engineer ( not a net one ) but..... maybe dont exist in comp dev :P
so ?
(clients)wlan0 <---> eth0(internet)
how to ?
anyone got balls ? 8-D
honestly i tried more than 30 tutos and more than 100 trys & redo and am really pissed-off
if anybody got a real setup that works..... i love it !
and i dont care reinstalling raspbian stretch again and again till all things work !
come and get some !!! ;))
regards
SurferTim
Sat Jan 13, 2018 10:08 pm
I can't tell what you want by that last reply...maybe...maybe not...
You should put entries in /etc/network/interfaces only if you are setting up a bridge access point.
https://www.raspberrypi.org/documentati ... s-point.md
pitibonom
Sun Jan 14, 2018 11:28 am
Hello surfertim :)
finally i got it working !!!!! thanks to you and i must thanks you very much !!!!
i'd say you wrote the only solution on the whole web for having a raspberry pi 3 with Raspbian stretch, working as an access point !
do you mind if i ask you tons of questions about your answer ? because i really like to understand things ;)
but first of all, about your latests post, bridging is a good solution :)
i tried the tuto you gave me, and it works like a charm. the only problem is that it prevents me from accessing my RPi SSH server.
i gonna test and tidy the mess i put on my RPi ;) and i'll post here my whole setup files as another WORKING example.
thanks again a lot for your valuable help !!!
and sorry for my previous post :/ after more than 1 week of tries and redo all days long, i really was pissed off to have nothing working.
SurferTim
Sun Jan 14, 2018 1:01 pm
Ask away! That's why I'm here.
The bridge setup should not interfere with ssh in either direction. Ensure you assign any static network settings to the bridge, not wlan0 or eth0, in /etc/dhcpcd.conf.
Who is online
Users browsing this forum: No registered users and 8 guests
