Khov
Cannot access RASPBERRY from out of local network
Mon Sep 11, 2017 9:33 pm
Hi everyone,
I want to create a little website with my PI. For this I have began with this tutorial https://readwrite.com/2014/06/27/raspbe ... e-hosting/.
All what I have done :
  • Install Apache on ma PI
    sudo apt-get install apache2 php5 libapache2-mod-php5
  • Restart Apache on ma PI
    sudo service apache2 restart
  • Test the connection to my server with the IP address of my PI on my local network and it works
  • I have turned my IP address into a fix IP adress. I have done this with my ISP OS which is FREEBOX OS (I'm in France)
  • I have created a PORT redirection to connect my PI remotely through internet
So, to summarize, I have created a server which is working. I can connect to it with the IP address (which is fixed) of the PI from the local network. But I cannot connect to my PI out of my local network. I write 192.168.0.xx:9898 and the browser never stop to run without going on my PI server.
Thank you if you can help me!
klricks
Re: Cannot access RASPBERRY from out of local network
Mon Sep 11, 2017 9:44 pm
192.168.0.xx:9898 is a local IP address.
You need to use the public IP address as shown in your routers status page or use an on-line port scan tool: http://www.t1shopper.com/tools/port-scan/
Go here for my RPi writeup. Basic config, Serial Port add-on etc:
http://blackeagle12.net/Comp/RPi/Rpi.html Click contact icon then world icon --->
Khov
Mon Sep 11, 2017 10:25 pm
Thanks a lot for your answer.
I have tried to connect to my public IP with the website you send me, but it responds this :
Scanning ports on 82.241.xxx.xx
82.241.xxx.xx isn't responding on port 9898 (websm).
I don't understand what I have missed to do. Thanks if you know what I have not done.
klricks
Mon Sep 11, 2017 11:23 pm
Does the Internet IP address shown in your routers status page match the IP address shown in the on-line scanner (82.241.x.x)?
Khov
Thu Sep 14, 2017 10:08 am
Thanks again for your help. I have finally understood my mistake. I'm a beginner in network.
  • My mistake was that I wrote on the URL browser the local IP of my Raspberry (first error). As you told me, I should have used the public IP of my router.
  • My second mistake was that I didn't have changed the listening port of my Rapsberry. It was still listening on the port 80 whereas I indicated on the OS of my router another port number.
Hope this explanation could help other ones with the same mistake...
Who is online
Users browsing this forum: No registered users and 7 guests
