I have installed OpenVPN using PiVPN (http://www.pivpn.io/), which (supposedly) took care of server installation and config files.
I have confirmed that the server is running by running
service openvpn status
I have run nmap:
servers@raspberrypi:~ $ nmap localhost
Starting Nmap 6.47 ( http://nmap.org ) at 2017-06-18 19:06 CDT
Nmap scan report for localhost (127.0.0.1)
Host is up (0.0029s latency).
Other addresses for localhost (not scanned): 127.0.0.1
Not shown: 993 closed ports
PORT STATE SERVICE
22/tcp open ssh
25/tcp open smtp
80/tcp open http
587/tcp open submission
5222/tcp open xmpp-client
5269/tcp open xmpp-server
5280/tcp open xmpp-bosh
Nmap done: 1 IP address (1 host up) scanned in 0.56 seconds
servers@raspberrypi:~ $ netstat -a
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 *:xmpp-client *:* LISTEN
tcp 0 0 localhost:submission *:* LISTEN
tcp 0 0 *:http *:* LISTEN
tcp 0 0 *:xmpp-server *:* LISTEN
tcp 0 0 *:ssh *:* LISTEN
tcp 0 0 localhost:smtp *:* LISTEN
tcp 0 0 *:5280 *:* LISTEN
tcp 0 0 *:5281 *:* LISTEN
tcp 0 244 10.0.1.11:ssh 10.0.1.4:59532 ESTABLISHED
tcp6 0 0 [::]:xmpp-client [::]:* LISTEN
tcp6 0 0 [::]:http [::]:* LISTEN
tcp6 0 0 [::]:xmpp-server [::]:* LISTEN
tcp6 0 0 [::]:ssh [::]:* LISTEN
tcp6 0 0 [::]:5280 [::]:* LISTEN
tcp6 0 0 [::]:5281 [::]:* LISTEN
udp 0 0 *:51398 *:*
udp 0 0 *:mdns *:*
udp 0 0 *:41278 *:*
udp 0 0 *:bootpc *:*
udp 0 0 10.8.0.1:ntp *:*
udp 0 0 10.0.1.11:ntp *:*
udp 0 0 localhost:ntp *:*
udp 0 0 *:ntp *:*
udp 0 0 *:openvpn *:*
udp6 0 0 [::]:mdns [::]:*
udp6 0 0 [::]:44843 [::]:*
udp6 0 0 [::]:dhcpv6-client [::]:*
udp6 0 0 2602:304:cf8e:9178::ntp [::]:*
udp6 0 0 localhost:ntp [::]:*
udp6 0 0 fe80::20f:60ff:fe08:ntp [::]:*
udp6 0 0 [::]:ntp [::]:*
udp6 0 0 [::]:49802 [::]:*
raw6 0 0 [::]:ipv6-icmp [::]:* 7
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node Path
unix 2 [ ] DGRAM 5385 /run/systemd/notify
unix 2 [ ACC ] STREAM LISTENING 5387 /run/systemd/private
unix 2 [ ] DGRAM 5914 /run/wpa_supplicant/wlan0
unix 2 [ ] DGRAM 5402 /run/systemd/shutdownd
unix 13 [ ] DGRAM 5404 /run/systemd/journal/dev-log
unix 2 [ ACC ] SEQPACKET LISTENING 5408 /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 5412 /run/systemd/journal/stdout
unix 5 [ ] DGRAM 5414 /run/systemd/journal/socket
unix 2 [ ACC ] STREAM LISTENING 10626 /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 10628 /var/run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 12168 /var/run/sendmail/mta/smcontrol
unix 2 [ ] DGRAM 6027 /var/run/thd.socket
unix 2 [ ACC ] STREAM LISTENING 6041 /var/run/dhcpcd.sock
unix 2 [ ACC ] STREAM LISTENING 6043 /var/run/dhcpcd.unpriv.sock
unix 2 [ ] DGRAM 7646 /run/systemd/journal/syslog
unix 3 [ ] STREAM CONNECTED 7044
unix 3 [ ] STREAM CONNECTED 11785
unix 3 [ ] DGRAM 6406
unix 3 [ ] STREAM CONNECTED 7068
unix 2 [ ] DGRAM 13554
unix 3 [ ] STREAM CONNECTED 7024
unix 3 [ ] STREAM CONNECTED 7146 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 13359
unix 3 [ ] STREAM CONNECTED 7069
unix 3 [ ] STREAM CONNECTED 7070 /var/run/dbus/system_bus_socket
unix 2 [ ] DGRAM 7650
unix 3 [ ] STREAM CONNECTED 13407
unix 3 [ ] DGRAM 6405
unix 3 [ ] STREAM CONNECTED 10890
unix 3 [ ] STREAM CONNECTED 7072 /var/run/dbus/system_bus_socket
unix 2 [ ] DGRAM 5881
unix 3 [ ] STREAM CONNECTED 11916
unix 2 [ ] DGRAM 7035
unix 2 [ ] DGRAM 14337
unix 3 [ ] STREAM CONNECTED 6008 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13556
unix 3 [ ] STREAM CONNECTED 6007 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 6010 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 6026
unix 3 [ ] STREAM CONNECTED 6018 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13557
unix 3 [ ] STREAM CONNECTED 7071 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 7037
unix 3 [ ] STREAM CONNECTED 7038
unix 2 [ ] DGRAM 10996
unix 2 [ ] DGRAM 12152
unix 2 [ ] DGRAM 7076
unix 3 [ ] STREAM CONNECTED 12413 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 10779
unix 2 [ ] DGRAM 6402
unix 2 [ ] DGRAM 6045
unix 2 [ ] DGRAM 7062
unix 2 [ ] DGRAM 11724
unix 3 [ ] STREAM CONNECTED 10742
unix 2 [ ] DGRAM 6020
Additionally, running an external port scan on my public IP address shows that 1194 is "blocked".
Attempting to connect to the server yields a "Connection timeout: server poll timeout" error.
I'm not really sure what to do at this point, and Google has yielded no results. Any help is appreciated!
Thanks!
EDIT: I should also mention that the firewall is set up correctly.
servers@raspberrypi:~ $ sudo ufw status
WARN: uid is 0 but '/lib' is owned by 1000
WARN: /lib is group writable!
Status: active
To Action From
1194/udp ALLOW Anywhere
22 ALLOW Anywhere
25/tcp ALLOW Anywhere
80 ALLOW Anywhere
587/tcp ALLOW Anywhere
5222/tcp ALLOW Anywhere
5269/tcp ALLOW Anywhere
5280/tcp ALLOW Anywhere
1194/udp ALLOW Anywhere (v6)
22 ALLOW Anywhere (v6)
25/tcp ALLOW Anywhere (v6)
80 ALLOW Anywhere (v6)
587/tcp ALLOW Anywhere (v6)
5222/tcp ALLOW Anywhere (v6)
5269/tcp ALLOW Anywhere (v6)
5280/tcp ALLOW Anywhere (v6)
