MrWonkerz
RPI2: OSMC vs. OpenElec vs. Xbian
Fri Feb 13, 2015 11:00 am
I got my Raspberry Pi 2 this Monday. And i use it as Media Center connected with a extern HD and use Samba to allow acces to my extern HD from my laptop and desktop computer.
What I have:
  • - OpenElec installed
  • - Samba activated
  • - SSH activated
The OpenElec has a ReadOnly Filesystem and I have to do a couple changes on it. Thats why i look for a other System.
OpenElec works smoothly and i am very happy how stable it is, but i have to do some advanced stuff so i'm searching for an alternativ System.
Has anyone tried Xbian or OSMC with the Raspberry Pi 2?
Are they stable and as smooth as OpenElec?
Which one do you prefere?
Kind Regards
MrWonkerz
kusti8
Re: RPI2: OSMC vs. OpenElec vs. Xbian
Fri Feb 13, 2015 3:38 pm
I use xbian since it is still based on raspbian which I can use for hacking. You can simply ssh into it and it works well. It is still fast. Got a AP to use in the car to stream movies and a shutdown button working with it.
Edit: the 2 version is only available on their website.
rikardo1979
Fri Feb 13, 2015 7:18 pm
there is new video on youtube
Raspberry PI 2 First Look With Xbian Kodi:XBMC
https://www.youtube.com/watch?v=QFWmCC0ebjQ
juantiritas
Thu May 12, 2016 7:29 am
I had the same problem, and the solution is OSMC :D
Try it, is similar to Openelec, but not readonly file system.
SANGER_A2
Mon May 23, 2016 1:06 pm
I too will put in a vote for OSMC. I had major crashes often with OpenElec playing videos on my RPi2 over my wired network and poor performance (no it wasn't a problem with my power supply). I tried both XBian and OSMC. Xbian wouldn't let me setup a static IP address on initial setup or later on so I skipped it and went with OSMC. So far it's brilliant. Much faster than OpenElec (with the OSMC skin), imported my library no problem. Loving it so far.
Return to “Media centres”
