bite_your_idols
Re: Netflix on Pi 2
Wed Mar 01, 2017 1:42 pm
kusti8 wrote:
bite_your_idols wrote:
Yes they are right there. I tried manually, following your steps and using deb file. Both ways libs are in its place but chrome has no windevine plugin and netflix gives me error: M7701-1003
Probably cause I didn't compile it with widevine support. Use v51 in the meantime.
ok, thanks! I will wait, I was just testing it, I daily use LibreELEC and I read devs are trying to implement chromium and windevine in testbuilds.
MrWillie
Re: Netflix on Pi 2
Wed Mar 01, 2017 2:07 pm
bite_your_idols wrote: ok, thanks! I will wait, I was just testing it, I daily use LibreELEC and I read devs are trying to implement chromium and windevine in testbuilds.
If you're interested in testing some more, you can use a fresh installation of the latest Raspbian with PIXEL and the instructions should work.
bite_your_idols
Re: Netflix on Pi 2
Wed Mar 01, 2017 2:41 pm
Yes, that's what I did. Burn latest Raspbian with Pixel in a SD and try to make it work following your steps. I get libs in theis place but no windevine plugin showed in chrome://plugins and netflix idint work.
Then I burn the image again, use deb file and I get libs and netflix-launcher shortcut but no windevine plugin and netflix didn't work.
goofy7
Re: Netflix on Pi 2
Thu Mar 02, 2017 9:48 am
hi im new here, i just get rpi 3 and can confirm that when i install from noobs can't use this method (deb etc) plugins are in folder but not registred in browser, same way if i send them via ssh to folder.
kusti8
Re: Netflix on Pi 2
Mon Mar 06, 2017 1:40 am
I've compiled it with widevine and confirmed it now works
viewtopic.php?p=1125013#p1125013
eusobao
Re: Netflix on Pi 2
Mon Apr 10, 2017 2:08 pm
How I Use v51?? I downloaded Netflix Launcher but gives me the same error.
HELP!!!
Re: Netflix on Pi 2
Mon Apr 10, 2017 2:18 pm
eusobao wrote:How I Use v51?? I downloaded Netflix Launcher but gives me the same error.
HELP!!!
In the link above yours he is using Chromium version 56 ;)
Retired disgracefully.....
eusobao
Re: Netflix on Pi 2
Mon Apr 10, 2017 2:19 pm
HELP!!!
So, I just update the chromium?
EdwardSwiss
Re: Netflix on Pi 2
Fri May 26, 2017 8:26 am
I have done the updates and upgrade of Rasperian plus installed the Netflix browser as described in this discussion but I still get a error C7701-10003.
I have a PI 3. What do I wrong that I can't start watching a movie? Am not in USA but in Switzerland
kusti8
Re: Netflix on Pi 2
Sat May 27, 2017 11:43 am
EdwardSwiss wrote:I have done the updates and upgrade of Rasperian plus installed the Netflix browser as described in this discussion but I still get a error C7701-10003.
Go to my link and posted above and follow those instructions.
Return to “Media centres”
