SSilver2k2
Contact: Website AOL
Compiled NeoGeo Emulator Download
Sun Jun 24, 2012 9:58 pm
Lo all,
Just posted another howto along with the binaries and config file for gngeo on my blog.
http://blog.sheasilverman.com/?p=73
So far I have run Metal Slug X, King of Fighters 98, and Samurai Showdown 2 perfectly.
SVC Chaos (one of the last games to be made for the system) wouldn't run, but I'm thinking that has to do with how big the cartridge size was at the time. Maybe using a hacked neogeo BIOS like unibios will fix it, but that's something for another day.
Let me know if you have any questions, comments, or suggestions. This is exciting :)
Edit:
Some extra info: http://gngeo.berlios.de/?page=faq - this is the official page for gngeo which has a great FAQ.
My blog of various geeky things - http://blog.sheasilverman.com
PiPLAY - http://piplay.org
DeskCade.com - Mini Raspberry Pi Arcade Cabinet
ChaPPy
Re: Compiled NeoGeo Emulator Download
Sun Jun 24, 2012 11:05 pm
Hi Shea
Good work mate! I also love the NeoGeo games but will have to wait a bit more to get my Raspberry Pi..
ChaPPy
BakaOsaka
Mon Jun 25, 2012 9:33 am
Hi, good to see some emulators being developed for the Pi!
I have an issue though,
Whenever I try to boot a rom after following your instructions, the emulator appears to freeze, and doesn't load. Any advice?
Thanks!
SSilver2k2
Mon Jun 25, 2012 10:11 pm
BakaOsaka wrote:Hi, good to see some emulators being developed for the Pi!
Thanks!
What step are you getting too?
BakaOsaka
Tue Jun 26, 2012 12:46 pm
What I've done is copy the required files to my Pi, Chmod'd ./gngeo so I can run it, put my BIOS/Roms into the required directories, and copied the config. I then execute ./gngeo for a second time, the GUI shows up, I select my Rom file, the GUI half-closes (as if it's loading) however even after leaving it, nothing happens.
pXc
Wed Jun 27, 2012 2:32 pm
hi ! :)
What is the format of the config file? because you only pasted the text on your blog :(
SSilver2k2
Wed Jun 27, 2012 11:26 pm
I'm assuming you mean what file extension. There is none it's just a text file called "gngeorc"
pXc
Thu Jun 28, 2012 10:40 am
yes that's what i meant :)
Thank you
BakaOsaka
Sat Jun 30, 2012 12:58 pm
Hey there, I managed to get the emulator to run fine, with audio through HDMI as well. However I tried runinng it with aoss sound, and ever since doing that I can get no audio output from gngeo at all. Do you know how I may be able to fix this?
Thanks!
pault
Tue Jul 03, 2012 2:12 pm
BakaOsaka wrote:What I've done is copy the required files to my Pi, Chmod'd ./gngeo so I can run it, put my BIOS/Roms into the required directories, and copied the config. I then execute ./gngeo for a second time, the GUI shows up, I select my Rom file, the GUI half-closes (as if it's loading) however even after leaving it, nothing happens.
I have got the same problem with mine, how did you get round this BakaOsaka?
BakaOsaka
Tue Jul 03, 2012 2:26 pm
Sadly I haven't yet, audio works fine in other applications such as omxplayer/FCEU so I guess it's just the emulator, but I've tried redownloading it to a different location and it still does it. Nothing in the config reflects any change either.
pault
Tue Jul 03, 2012 2:27 pm
BakaOsaka wrote:Sadly I haven't yet, audio works fine in other applications such as omxplayer/FCEU so I guess it's just the emulator, but I've tried redownloading it to a different location and it still does it. Nothing in the config reflects any change either.
Not the audio problem, the one with the GUI half closing.
pault
Tue Jul 03, 2012 2:45 pm
Ah, I have sorted it now. The config file in .gngeo needs to be called gngeorc, not gngeorc.txt
raisedbyfinches
Fri Jul 06, 2012 8:08 am
How is KoF98? Is there any lag?
Now I can't wait to get my RPi and try to get my arcade stick(s) working with it (provided the power needed to run it isn't too high for the pi - I'd look that up but am in work).
You made my day. :D
SSilver2k2
Fri Jul 06, 2012 5:13 pm
No lag that I have seen with KoF98 :D
raisedbyfinches wrote:How is KoF98? Is there any lag?
You made my day. :D
Dakor
Thu Apr 18, 2013 10:28 am
For those without sound:
run as root.
it gives me sound and a performance boost.
Note: you have to put the config file in the .gngeo folder of the home directory of the root.
Return to “Media centres”
