Downloading/unpacking rpi.gpio
Running setup.py egg_info for package rpi.gpio
Installing collected packages: rpi.gpio
Running setup.py install for rpi.gpio
building 'RPi.GPIO' extension
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c source/py_gpio.c -o build/temp.linux-armv6l-2.7/source/py_gpio.o
unable to execute gcc: No such file or directory
error: command 'gcc' failed with exit status 1
Complete output from command /usr/bin/python -c "import setuptools;__file__='/home/xbian/build/rpi.gpio/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-lwkpXt-record/install-record.txt:
running install
running build
running build_py
running build_ext
Command /usr/bin/python -c "import setuptools;__file__='/home/xbian/build/rpi.gpio/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-lwkpXt-record/install-record.txt failed with error code 1 in /home/xbian/build/rpi.gpio
Storing complete log in /root/.pip/pip.log
